Adjust my home water pressure down? I recently learned that you can control the water pressure coming in to your home with a regulator. I never knew that until my rental property had a pipe leak in the yard and i found a valve that regulates pressure. That got me thinking and I decided to check the pressure at a hose bib on my residence. It shows 70 psi. I read you shouldn’t have more than 60 psi. In my yard I found two little boxes that have some valves I’m assuming and I don’t know what they are or if I can use them to adjust my pressure. Pictures below.
