I recently had the third oil change on my Crosstrek. Every oil change done at the dealership, and it's always filled to the maximum dot indicator. This time it was different, and overfilled.
The OM calls for 5.1 US quarts, but the dealership indicates 6 quarts used on the invoice. I verified with the service tech that they use oil in bulk barrels, and not individual quart containers. The service tech also said that there is a leeway to go over a bit or under a bit, and that this is not a problem.
What do you guys and gals think about the overfill, problem or not? Should I have them redo it with 5.1 quarts.
As shown in the picture, the level is over the maximum fill dot indicator.
