Originally Posted By: Blaze
Originally Posted By: thescreensavers
Originally Posted By: Mr Nice
Originally Posted By: Chris142
The rotors on my jeep were warped @6k. Dealer resurfaced them and they were warped again by 11k. I replaced them with autozone gold pads and auto zone rotors. These lasted 90k!
Sad that AutoZone rotors lasted much longer than factory parts.
He also changed the pad, usually braking vibration is a pad problem.
Blaze
Check out StopTech Sport Pads, for your truck it should be 309.14140 for the fronts, these will dust but will handle the heat from towing and have great initial bite. For Rotors I like Centric blanks.
Rockauto has em both
http://www.rockauto.com/xx/cart/?cartid=096ca1e25946a8e26b8971192aa306d1
Thanks, now I'm confused on rotors? Solid over slotted for trucks and towing?
You want solid, OEM comes solid.
Slotted looks cooler so that's why people buy it, for racing it might be worthwhile but on the street/towing nah the pad is more important. Slotting could cause noise and will reduce brake pad life.
If you want to buy slotted you can but will likely notice nothing.
