You're right probably don't need the most expensive oil, just need one fit for purpose. Do you see any issue with the 75w90 given that it's 50% higher viscosity?
50% higher viscosity than what?
Higher than the factory 75w85
I am not following you. How can 75W-90 be 50% higher viscosity over 75W-85?
Motorcraft @ 100°C is 11.5cSt while the 75w90s are 15.5-16.5cSt at 100°C,
66cSt vs 100-120cSt @40°C
