Originally Posted By: Gokhan
Originally Posted By: Shannow
And it gives six fully synthetic, PAO based oils six wildly different answers regarding the "basestock quality".
Wildly?
(1) The NOACK values you used are expressed in a single significant figure, which means you can express the BOQI only to a single significant figure (50, 60, 70, etc.).
OK, I'll cede that...not that it's important here 50 to 70 for the six formulations...all of which have 100% PAO basestocks...160, 140, 100 for the individual basestocks...I stand by "wildly".
And thus looking at your ranking using the BOQI...it changes things to. Is the "zero" at the end of each NOACK a significant figure or not ?
They ALL happen to end in a zero, which is pretty amazing if it's a measured zero.
(3) There is also no guarantee of accuracy on either CCS or NOACK for these internal research oils.
Surely the data sheet for the base oils themselves can be trusted ??
(2) They are all above 50, which is only attainable by PAO and GTL -- so, it checks.
(3) The VII content seems to decrease BOQI, as it increases the CSS and probably the NOACK as well -- not a bad thing because we don't like higher VII content either.
Again, I'll use "wildly", as there's no correlation between them other than the numbers are different.
I'll posit that my CCS/MRV ratio (no I'm not going to patent it) gives a better understanding of the impact of VII on the oil...
(4) There is no such thing as PAO base stocks with different viscosities in the same base-stock slate should have the same BOQI. In fact, if a base stock has a lower CCS without the NOACK being too high, this should indicate a better base stock.
If it's an index of "Base Oil Quality", then SURELY spectrasyn same manufacturer, same product line would at least be "close" to each other.
(5) BOQI is a benchmark that should be considered on its own -- tells you how good your CCS and NOACK are -- and the quality and type of the base oil is correlated with it -- not necessarily precisely given by it.
You can see the CCS, MRV, and NOACK...that tells you what and "how good" they are...and I disagree with the last point...the WILD variance does not allow anything to be drawn from the number.
Originally Posted By: Taleb
Wen you develop your opinions on the basis of weak evidence, you wll have difficulty interpreting subsequent information that contradicts these opinions, even if this new information is obviously more accurate
