Hi all:
So I know the general consensus is that using a Top Tier gasoline will keep fuel injectors clean. But what if Top Tier gasoline wasn't always used in the car, or, like in my case, that car was not driven a lot in its early years of ownership and probably had some old gas run through it when it was rarely driven during winter snow months. I know from the AAA report on Top Tier gas that using a Top Tier gas even on an engine that was "dirtied" by using sub-standard gas apparently cleans up injectors, but do we know to what extent? What I'm getting at, is how does one really know the current status of injector performance? Isn't it reasonable that there is a continuum of dirt or fouling from say perfect and new all the way to clogged, and in between symptoms may not be necessarily obvious but yet detrimental (for example less than original acceleration and the like that has became so slight and gradual since the car was new it may not be noticeable)?
After my 95 Maxima experienced its first fuel injector failure and I had it replaced, I got to wondering about this topic. The car was indeed misbehaving in terms of rough idle and acceleration and there was certainly a big improvement when the injector was replaced but again, this was for a fully failed injector. So how do I really know the condition of the rest of the injectors? I believe the mechanic checked resistance but how sensitive is that to the condition of the injector or is it like "OK" vs. full fail?
With all this in mind, I wrote to a few fuel injector cleaning outfits. I believe Trav on this board also does this for a business in Europe if I'm not mistaken so hope he chimes in. The general response was they are not fond of injector cleaners. Some even said that if there are deposits after the filter, they may actually end up in the injector and make things worse. One response said there is a small filter in the injector as a last chance catch that you don't want to get clogged by dislodged debris working its way down there as a result of the cleaner.
I had been tempted to use some fuel system cleaner but now am not so sure.
Looking forward to responses to this topic.
