Originally Posted By: 28oz
Originally Posted By: ARCOgraphite
You ABSOLUTELY need gable end vents with forced expulsion on one gable. That be a thermostat controlled fan Hopefully you have UNBLOCKED soffit vents also.
I'm looking at putting in a thermostat controlled fan in one (or more) of my gable vents. I've blown in more insulation and added some reflective barriers.....both of which have helped.....but, I think more can be done. I'm curious, does it matter which gable vent you use (I have them on every side of the house except the south facing)? If it matters, how do you determine the best gable vent to put one in?
Spend some time studying the topic on the interweb. It's been a few years since I did, but if you are not very careful you can create problems with powered gable fans. If memory serves, I think the gist of the problem is that an exhaust fan can create negative pressure in the attic. This can disrupt natural venting (ridge/soffit) AND it can "suck" conditioned air out of the living space through any unsealed cracks. This in turn can create negative pressure in the living space and draw in hot moist air from outside. Not good.
A few articles I found in a few seconds: https://www.energyvanguard.com/blog/75600/The-1-Reason-Power-Attic-Ventilators-Don-t-Help
http://www.greenbuildingadvisor.com/blogs/dept/musings/fans-attic-do-they-help-or-do-they-hurt
Cujet's advice about radiant heat is spot on also. Managing attic heat is much different in the south vs the northern climates.
