4EAT Subaru
by HowAboutThis. 02/16/19 10:38 AM
delete
by beanoil. 02/16/19 10:37 AM
First oil change
by Bill_W. 02/16/19 10:18 AM
Mobil M1-110A
by Purpfox. 02/16/19 10:17 AM
Oil recommendation for 2018 titan 4x2
by Ttown. 02/16/19 10:10 AM
M1 filters?
by dogememe. 02/16/19 09:44 AM
Granatelli Indy 500 and STP :)
by shanneba. 02/16/19 08:01 AM
2010 Chevy Corvette, Castrol GTX Magnatec 5w30
by montero1. 02/16/19 07:22 AM
veloster wheels on my sonata
by JustinH. 02/16/19 07:05 AM
Beast chewing on garage door seal
by LeakySeals. 02/16/19 03:01 AM
Weird Residue in New Fram Ultra
by mphilleo. 02/16/19 01:40 AM
0w20 vs 0/5w30 (yes I know another viscosity thread)
by SnowDrifter. 02/15/19 11:42 PM
skid plate
by mobilaltima. 02/15/19 10:32 PM
The Last Gladiators (French)
by Marco620. 02/15/19 08:54 PM
Rural King 5W30 Citgo Superguard blend 5qt jug $9.91
by tenderloin. 02/15/19 08:34 PM
Meet Watson!
by spasm3. 02/15/19 08:16 PM
krzyq, Huberthagans, 3dfever, Mahmoud, Happycamper
67248 Registered Users
101 registered members (97prizm, 2002 Maxima SE, Ag76, 53' Stude, Al, 4WD, 9 invisible), 2,185 guests, and 52 spiders.
Topics298,270
Posts4,988,433
Members67,248
Most Online2,474
Feb 10th, 2019
NAPA 4070 Coolant Filter Results #4818118
07/19/18 11:58 AM
07/19/18 11:58 AM
Fort Lauderdale, FL
DoubleWasp Offline OP
Fort Lauderdale, FL
This filter was installed on a particularly nasty engine. Even after doing a strong citric acid flush twice, this engine persisted in dropping heavy material into the coolant.
Only thing I could figure is that this engine must have enough "dead spots" in the coolant jackets that water flow through the block just can't hit them when flushing after a cleaning. In the future, we will be using a pulsating system to do the final flush. A lot of research indicates that the surging nature of a pulsating system overwhelms the flow area enough to blow out spots of dead flow in a cooling system.
The engine here is a closed cooled marine engine that circulates engine coolant through its engine, as well as its exhaust manifolds.
In order to assure maximum effectiveness of this system, the block drains and manifold drains were replaced with threaded nipples, all plumbed to the filter head, mounted below the level of the skirt of the block. Long story made short: Both lighter and heavier contaminates are left with nowhere to settle. Anything that seeks the lowest point in the cooling system finds its way being sucked toward the coolant filter. These nipples also create a flow path where there was not one before. The lowest points of the entire system are under suction. This is not a "bypass" course. Every single drop of coolant that goes through the drain nipples goes through the coolant filter. Period. The return from the coolant filter is also not a bypass. It is connected directly to the suction port of the circulation water pump (The one circulating engine coolant, not the raw water pump that sucks in sea water).
This go around, the coolant remained free of contaminants. Clear, and no sediment in the coolant reservoir.
The filter?
In the last pic, you can see how absolutely pasted the filter media is. You can also see how clean the center tube is, even after contaminating it a little with my sad filter cutting and draining skills. Would have drained it by punching a hole in the bottom, but didn't want to lose any sediment, for maximum appreciation of the nastiness.
In the future, I plan to use the block drains on both land and marine engines for coolant filter installs. Maybe drill out the restrictor cap for a little more flow. I've cut them out completely before to use them as full flow filters in heater core lines to protect heater cores, so they will flow a lot in modified full flow mode.
Re: NAPA 4070 Coolant Filter Results [Re: DoubleWasp] #4818135
07/19/18 12:16 PM
07/19/18 12:16 PM
Upstate NY
Donald Online content
Donald  Online Content
Upstate NY
What is the history of the engine? Its cooling system needs to be maintained like any car or truck.
2015 Ford F250 w/Powerstroke
Re: NAPA 4070 Coolant Filter Results [Re: DoubleWasp] #4818171
07/19/18 01:05 PM
07/19/18 01:05 PM
VW Fanboy Island
maxdustington Offline
VW Fanboy Island
Wow, nice C&P dude. Someone must have skipped changing the coolant.
03 Jetta AWP/09A 205k kms
Edge 0W40 + Mann 719/30
Re: NAPA 4070 Coolant Filter Results [Re: maxdustington] #4818178
07/19/18 01:16 PM
07/19/18 01:16 PM
NY, USA
windeye Offline
windeye  Offline
NY, USA
where does the "stuff" come from? do you have iron block that just rot away?
2000 Mazda MPV LX, 202,500 miles
2007 Mazda 3 Touring, 112,800 miles
2013 Toyota Camry XLE, 100,800 miles
Re: NAPA 4070 Coolant Filter Results [Re: windeye] #4818187
07/19/18 01:25 PM
07/19/18 01:25 PM
Georgia
GregGA Offline
GregGA  Offline
Georgia
Put one on my 87 Jeep 4.0 about 3 years ago. While not as nasty as yours, I had several teaspoons of grit.Could be that's why my last water pump lasted only 3 years. All is well now. A good add on project!
Re: NAPA 4070 Coolant Filter Results [Re: DoubleWasp] #4818220
07/19/18 02:16 PM
07/19/18 02:16 PM
Fort Lauderdale, FL
Fort Lauderdale, FL
No idea on history of the engine. It's run at least 3000 hours since 1988. Verified original engine.
This is an iron block GM 454 with iron heads, and iron exhaust manifolds. The cooling system also has a giant cupronickel heat exchanger that I am pretty sure weighs at least 100 lbs.
The previous exchangers died due to a combination of age, and abuse/neglect. At a cool $1800 A piece, great lengths are being taken to prevent future issues. When sediment gathers in the heat exchangers, it causes an imbalance in thermal loads that fractures the tubes. Not fun.
We are of course using a stout HDEC due to the multiple metals in the system: Iron, aluminum, cupronickel, brass, copper, stainless steel, and solder.
She doesn't even think of crossing 160 since all services performed.
Re: NAPA 4070 Coolant Filter Results [Re: DoubleWasp] #4818269
07/19/18 03:56 PM
07/19/18 03:56 PM
Cincinnati, OH, USA
bullwinkle Offline
bullwinkle  Offline
Cincinnati, OH, USA
That's similar to what my F-450 caught on the first coolant filter-inside of the filter looked like a sandbox, coolant in it when I bought it had ancient green turned brown, not sure if it ever had SCAs in it or not. Subsequent changes have been a lot better. Guessing you replace it with a blank/no SCA filter and leave it on?
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: NAPA 4070 Coolant Filter Results [Re: GregGA] #4818270
07/19/18 03:59 PM
07/19/18 03:59 PM
Jupiter, FL
thescreensavers Offline
Jupiter, FL
i've been thinking of adding one to my XJ, how did you plumb yours? Using the block drains sounds like a great idea. Got to think about how to do that on the XJ.
2017 Camaro SS 1LE (Motul 8100 X-clean 5W40)
1997 Jeep XJ 4x4 (15W40 HDEO Maxlife)
Re: NAPA 4070 Coolant Filter Results [Re: DoubleWasp] #4818296
07/19/18 05:10 PM
07/19/18 05:10 PM
Fort Lauderdale, FL
Fort Lauderdale, FL
Yes. 4070 has no SCA. Part numbers for SCA filters start at 4071, and work their way up numerically by amount of SCA.
This engine is now using ELC coolant, so no SCA is ever needed.
Using the block drains is not hard. Find out the block drain thread, but barbed nipples that will screw in. Buy appropriate nipples for the filter head. My advice? If you are doing a block drain setup, make sure that you include shut-off valves in the fittings between the filter head and the nipple. The NAPA 4019 filter head is standard pipe thread. Just hit up your plumbing section at a decent hardware store and get the valves and nipples you need. Why? If you have the filter head hooked to the block drains, every filter change will dump the entirety of your cooling system.
But, if you ever do want to dump the whole thing, just remove the filter and open both valves.
Re: NAPA 4070 Coolant Filter Results [Re: DoubleWasp] #4818359
07/19/18 07:19 PM
07/19/18 07:19 PM
NY, USA
windeye Offline
windeye  Offline
NY, USA
if it's iron block and iron head, you need to use old American green coolant that protects iron which has a much higher pH. modern coolants are formulated for aluminum block and head, its pH is just above neutral.
Re: NAPA 4070 Coolant Filter Results [Re: DoubleWasp] #4818396
07/19/18 08:51 PM
07/19/18 08:51 PM
Fort Lauderdale, FL
Fort Lauderdale, FL
The ELC we are using is designed for iron truck engines with huge brass/copper radiators, and other mixed metal systems. That is exactly what this cooling system is.
Moderated by  ekpolk
