Originally Posted By: koffy
I’ll try wit the pedal half way, maybe it works,,,, I’m definitely replacing all the fluid,,, I just want to keep air from entering the MC and abs unit
Right, I went ahead and bled the system when I got done with my repairs but it was nice it didn't keep spilling out all the time. Plus my ABS requires you to short out some pins on the system to open it up for bleeding if you let it run dry.
