delete
by beanoil. 02/16/19 10:37 AM
97 registered members (240_Ed, ABerns, Astro_Guy, 4WD, 14 invisible),
2,229
guests, and 48
spiders. |
Key:
Admin,
Global Mod,
Mod
Topics298,272
Posts4,988,480
Members67,248
Most Online2,474 Feb 10th, 2019
2008 Honda Odyssey oil and filter?
#4817468
07/18/18 04:11 PM
07/18/18 04:11 PM
Posts: 160 Olathe, KS
CARJ
OP
OP
Olathe, KS
I'm going to start doing oil changes on a friend's Odyssey. I know it takes 4.2 qts of 0w-20. They usually take it to a quick lube place for whatever synthetic oil they get. The van is used for around town plus family trips. I would guess 10k miles a year. I do a yearly oil change on one of their other cars (a Ford Focus) and would like to do the same with the van. Thoughts on a good oil to accomplish this? Thinking that I would use a Fram XG for the filter.
**Edit. I do happen to have a fair amount of PPHM 5w-30. What about using that?
2004 Toyota 4Runner | 182k | Castrol GTX HM 5w-30, PH8A 2012 VW Passat | 86k | PPHM/Redline 5w-30, XG9911
Re: 2008 Honda Odyssey oil and filter?
[Re: CARJ]
#4817499
07/18/18 04:56 PM
07/18/18 04:56 PM
Posts: 2,380 OBX & Central FL
NormanBuntz
OBX & Central FL
The Odyssey was specced for 5w-20 oil through the 2010 model year. Honda later decided that 0w-20 was acceptable for those years. But I prefer to use 5w-20 in the 2007-2010 engines unless you live in a location with frigid winters. Another plus for using the 5w-20 is if the van has higher mileage.
So I'd use whatever SN rated synthetic is on sale, and go by the OLM or one year for your change interval. My 2007 Ridgeline now gets about 5-6K miles a year and uses virtually no oil between changes.
2017 Honda Odyssey SE, 18K 2013 Honda Accord LX, 59K 2007 Honda Ridgeline RTS, 89K 2007 Infiniti M35, 107K
[Re: CARJ]
#4817506
07/18/18 05:10 PM
07/18/18 05:10 PM
Posts: 20,958 MA, Mittelfranken.de
Trav
If its a VCM engine throw the book away and use 5w30 or 0w40 in that engine. No, the engineers didn't get it right on this engine, the clowns who dreamed up with this nightmare (they have been sued for it) need to go back working at a McDonald's drive through like they did in high school. Get a VCM muzzler for it.
[Re: CARJ]
#4817517
07/18/18 05:20 PM
07/18/18 05:20 PM
Posts: 310 Bucks, PA
zfasts03
Bucks, PA
My `06 EXL Odyssey with cylinder deactivation holds 4 3/4 quarts to bring it to the full line for an oil change with filter. I have run everything from 0w-20 to 5w-30 and others run 0w-40 with success. The only difference I can tell is the engine is a little noisier with the lighter oils, but seems slightly more peppy with the 20 wts. as well.
Don't run the oil too long as these engines with cylinder deactivation are tough on oil. Mine is varnished/little sludge even though I follow the OLM and run full syn. oil. I have 141,000 on mine, owned since new.
03 Corvette Z06 -Amsoil 5w-30 SS 07 Honda Accord 2.4L -Amsoil 5w-20 SS 16 Suburban 5.3L -M1 0w-20, XG10575 18 4Runner TRD Off Road - Amsoil 0w-30 SS, TRD filter
[Re: Trav]
#4817533
07/18/18 05:54 PM
07/18/18 05:54 PM
Posts: 1,321 Ohio
hallstevenson
Ohio
If its a VCM engine
Get a VCM muzzler for it. We had an '05 Odyssey w/o VCM. I believe they added it in '06. Regarding muzzlers, you're a mechanic, yes ? If so, do you recommend your customers add one ? If our Odyssey had VCM, I would have added one myself. Just curious how you deal with it.
[Re: CARJ]
#4817546
07/18/18 06:06 PM
07/18/18 06:06 PM
Posts: 1,998 Ca.
UncleDave
Ca.
Old VCM inhales - to many stages and new at the time loose algorithms.
New (2017) VCM has been great so far. Engagement is barely if at all perceptible.
Only 2 choices 6 and 3 which is easier to tune the engine mount and map loads to.
The old 6-4-3 was all over the map and the mounts never kept up.
Ive seen little to no oil consumption after the first 3500 miles (break in) so it doenst seem to be causing any consumption.
UD
Uncle Dave Cat 3126/2 MB3500/Titan/RX400H/17 Ridgeline 700HP V10/ 725HP BBC/ Raptor 700/ KFX450/ YZ250/Onan 8K/ Cat3011C
[Re: CARJ]
#4817555
07/18/18 06:14 PM
07/18/18 06:14 PM
zfasts03
Bucks, PA
Mine uses 1/2 qt every 2500 miles like clockwork (regardless to brand or weight of oil). I average a 5000 mile OCI. So I add 1/2 qt. half way through the OCI.
[Re: Trav]
#4817724
07/18/18 10:12 PM
07/18/18 10:12 PM
Posts: 161 Midwest
mtndew_dad
Midwest
Touring, EX and EX-L have VCM. LX did not. My 2006 EX-L has 190,000 miles and the VCM spool valve, valve train and valve covers have no sludge build up at all with only a slight varnish. I have used Fram Ultra filters and either Mobil One or Pennzoil Platinum 5w20 for every oil change, following the maintenance reminder intervals. Keep a close eye on the PVC. I have cleaned or replaced it 4-5 times, so once every 40k miles or so. I have had no problem with the VCM system or engine mounts so I consider myself lucky!
[Re: Kira]
#4817845
07/19/18 05:53 AM
07/19/18 05:53 AM
Trav
Variable Cylinder Management
The system turns off cylinders at times to theoretically improve fuel economy but in reality its almost useless and possibly does damage to the engine and other parts depending on driving conditions, the muzzler disables the system.
[Re: CARJ]
#4817861
07/19/18 06:19 AM
07/19/18 06:19 AM
Posts: 1,154 Ohio
Dave Sherman
Ohio
It plugs inline with the coolant temperature sensor, and adds enough resistance to fool the ECU into thinking the coolant temperature isn't high enough to activate VCM. Supposedly it doesn't throw the coolant temperature reading off enough to cause check engine lights.
2015 Honda Pilot EX AWD Valvoline 0W-20 Bosch filter 1977 MG Midget Valvoline VR-1 20W-50 Bosch Filter
