Originally Posted By: Bjornviken
Originally Posted By: Gokhan
Originally Posted By: Shannow
pseudo scientific stuff
You refuse to understand the base-oil quality index BOQI.
It's very simple: BOQI ~ 1/CCS/NOACK takes into account both the CCS (cold-crank-simulator viscosity) and NOACK simultaneously. The only way you can have
both the CCS and NOACK low is to increase the base-oil quality. You can have a Group I base stock with a low NOACK but its CCS will be very high. Likewise, a Group I base stock could have a very low CCS but its NOACK would be way too high. Even within the same base-stock family (base-stock slate), a higher BOQI is associated with a higher viscosity index and lower oxidation. You can research that. This is simply because BOQI relates to molecular structure such as higher paraffinic content through simultaneously better CCS and NOACK performance.
It's empirical and heuristic, yes. Nevertheless, it works. BOQI relates directly to the base-oil quality, which is primarily the oxidation performance, of a base oil.
Unfortunately, my title for this thread was confusing. A thinner oil on its own of course doesn't mean anything. What I meant was that the 0W-xx oils have very high BOQI indexes in general, which lead to lower oxidation.
This is not surprising at all: In order to make a 0W-20, you need absolutely the best base stocks because otherwise you will not meet the very strict CCS requirements (-35 C CCS performance) at the same time with the NOACK requirement (these days around as little as 9 - 10%).
So, when you buy a 0W-20, you know that you're buying the best base oil, which will therefore have the best oxidation performance. Look at the M1 AFE, M1 EP, and M1 AP 0W-20 MSDS's and compare them with the respective MSDS's for 5W-20 or 5W-30. You will see that 0W-20 has much more PAO than 5W-20 or 5W-30 and I've already explained the reason.
Last but not least, this doesn't only apply to 0W-20. Mobil 1 0W-40 SN (Group III+ + PAO) has BOQI = 68 and Mobil 1 0W-40 SM (PAO) had BOQI = 69 (data from the
M1 presentation). I don't have the data for Mobil 1 FS 0W-40 SN (GTL + PAO). These are very high BOQI values, readily surpassing those for most premium synthetic 5W-xx oils.
Price over here
Mobil 1 0w-20 esp cost 70€
Mobil 1 0w-40 FS cost 40€
Cheapest oils are 5w-40
I agree with you that thinner oils are higher quality oils and you save money on fuel
Absolutely! BOQI
does predict the base-oil quality (PAO, GTL) and you pay for the PAO and GTL that goes into the 0W-xx's.
Yes, most 5W-40's (PCMO and HDEO) I've seen are made of the cheapest base stocks they can get away with and are loaded with a very high dose of the cheapest VII, which makes the oil even worse, potentially leading to deposits and sludge. There are probably some good 5W-40's though. Most 0W-40's are good bu there are exceptions there, too.
