Greetings,
I need to order some centering rings in order to reduce the size of the wheels from (Mazda)67.1mm down to (Honda) 64.1mm for the winter wheels & tires to fit correctly. Everything else being equal as these winter wheels are Tire Rack steelies with winter tires in which the tires are also equal in size(195-65-15) and the wheel/hub lugs being 114.3mm.
My question is, are the plastic centering rings OK to use or should I just order aluminum?
