Is ford admitting to their filters tearing?
by advocate. 02/16/19 12:13 PM
Caliper piston replacement.
by LeakySeals. 02/16/19 11:30 AM
Speed Bleeders - Used Them?
by john_pifer. 02/16/19 11:19 AM
4EAT Subaru
by HowAboutThis. 02/16/19 10:38 AM
delete
by beanoil. 02/16/19 10:37 AM
First oil change
by Bill_W. 02/16/19 10:18 AM
Mobil M1-110A
by Purpfox. 02/16/19 10:17 AM
Oil recommendation for 2018 titan 4x2
by Ttown. 02/16/19 10:10 AM
M1 filters?
by dogememe. 02/16/19 09:44 AM
Granatelli Indy 500 and STP :)
by shanneba. 02/16/19 08:01 AM
2010 Chevy Corvette, Castrol GTX Magnatec 5w30
by montero1. 02/16/19 07:22 AM
veloster wheels on my sonata
by JustinH. 02/16/19 07:05 AM
Beast chewing on garage door seal
by LeakySeals. 02/16/19 03:01 AM
Weird Residue in New Fram Ultra
by mphilleo. 02/16/19 01:40 AM
0w20 vs 0/5w30 (yes I know another viscosity thread)
by SnowDrifter. 02/15/19 11:42 PM
skid plate
by mobilaltima. 02/15/19 10:32 PM
krzyq, Huberthagans, 3dfever, Mahmoud, Happycamper
67248 Registered Users
95 registered members (advocate, 4WD, 2009Edge, 69Torino, Aero540T, 11 invisible), 2,237 guests, and 58 spiders.
Topics298,274
Posts4,988,512
Members67,248
Most Online2,474
Feb 10th, 2019
Alignment: loading suspension in sloped driveway #4817145
07/18/18 09:14 AM
07/18/18 09:14 AM
Anaheim, CA
zorobabel Offline OP
Anaheim, CA
My Maxima and Corolla are FWD and the only easily adjustable alignment spec is the front toe.
I've read that it's best to load the suspension when checking alignment, and I've done it by coming to a stop with the handbrake in the past.
For the next alignment check, I'm thinking of parking the car - front high - in a sloped driveway, putting the tranny in park, not engaging the emergency/parking brake and just letting the car roll back a tiny bit - stopping by the tranny lock teeth. This should have the same effect on toe as driving trying to overcome air drag. Then measure away (and hope for 0 toe).
What do you think?
1997 Maxima 195k, Castrol GTX Synblend 5W-30, FL400S
2004 Corolla 196k, VWB 5w20 + SSS 10w40, MGL4967
Re: Alignment: loading suspension in sloped driveway [Re: zorobabel] #4817184
07/18/18 10:09 AM
07/18/18 10:09 AM
Toronto Canada
WobblyElvis Offline
WobblyElvis  Offline
Toronto Canada
You are putting an unknown load on the front steering/suspension doing it as you suggested. Who know what the results will be?
I would not put any load on the front wheels if you are adjust the toe in/out. Leave the transmission in neutral and let the rear wheels hold the car in place. Use the chocks on the rear wheels or the parking brake.
You will adjust it to have a little toe out in this configuration, just like the book says.
Re: Alignment: loading suspension in sloped driveway [Re: zorobabel] #4817219
07/18/18 11:09 AM
07/18/18 11:09 AM
Modesto,CA
mehullica Offline
mehullica  Offline
Modesto,CA
Toyota recommends no load in all their cars during a wheel alignment
Re: Alignment: loading suspension in sloped driveway [Re: zorobabel] #4817251
07/18/18 11:39 AM
07/18/18 11:39 AM
America's Dairyland
LotI Offline
LotI  Offline
America's Dairyland
All manufacturers require the car to be on a level surface when doing the alignment. All cars have their own specs too and the suspension must be in a relaxed state, among many other things.
You don't have the ability to unbind the suspension when on a driveway so don't waste your time.
03 Honda Interceptor
11 Kawasaki KLR 650
12 Ford E450
17 VW GTI
[IMG]http://badges.fuelly.com/images/sig-us/803455.png[/IMG]
Re: Alignment: loading suspension in sloped driveway [Re: zorobabel] #4817306
07/18/18 12:23 PM
07/18/18 12:23 PM
N.H, U.S.A.
ARCOgraphite Offline
N.H, U.S.A.
Most modern alignments on HUNTERS I have gotten have been poor and I had to retouch in the DW. So whats worng with the system? Tires ?Calibration? Operator? Nitrogen struts? or all of the preceding? I've seen racks HUNTER) B4 and After cal printouts and they have been TERRIBLY out. This is a RACK calibration, NOT chassis B4 and after. I thought the laser system was somehow self compensating self calibrating. Had good alignments with the old BAER (BEAR) String systems.
2019 VW Jetta S,6M OCI#0 1136mi-Castrol Edge Prof? VW508+OE Filter; '17 Subaru Crosstrek CVT OC#6 43467mi-Valvoline Adv 0w20 + SOA Filter
Re: Alignment: loading suspension in sloped driveway [Re: zorobabel] #4817307
07/18/18 12:24 PM
07/18/18 12:24 PM
Canyon County Idaho
CT8 Online content
CT8  Online Content
Canyon County Idaho
The best way is to bring the car to a great alignment shop.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Alignment: loading suspension in sloped driveway [Re: zorobabel] #4817308
07/18/18 12:25 PM
07/18/18 12:25 PM
N.H, U.S.A.
N.H, U.S.A.
Id say try it and report back. You may find BIG toe differences on suspension with worn bushings. I find most cheap mac strut cars front ends to be absolute, unsafe garbage .. WHEN NEW.
AND I' 1/2 Scot and saying this!
Re: Alignment: loading suspension in sloped driveway [Re: zorobabel] #4817379
07/18/18 01:28 PM
07/18/18 01:28 PM
Saskatchewan, Canada
Johnny2Bad Offline
Johnny2Bad  Offline
Level surface, no suspension load except you may opt to put a body of similar weight to you or substitute some appropriate weight (how much rice can you eat?) in the driver's seat if the normal mode of operation is single driver / no passenger.
'57 FL Straight 50 wt
'90 Miata 1.8L w/Rotrex Supercharger [Mobil1 0W-40]
'96 Ram 1500 [3.7L Mobil1 0W-20 / 1L 15W-50]
'01 PT Cruiser [Mobil1 0W-40]
Moderated by  ekpolk
