- Joined
- Jan 16, 2017
- Messages
- 91
Hey guys
My mothers car needs some new pads, and I'm going to throw rotors on while I'm at it. The pedal pulsates pretty bad, and they look like they could use a set. I thought the drums were the culprit, but I've gone through 3 sets, and recently discovered the slide pins on the driver front caliper was siezed a little, so if I had to guess, the rotor got hot, or at least I hope.
Honest to god going to be my first brake job, even though I've done a rack on this thing amongst a ton of other work, so please bear with me.
Can you use silicone paste on the pins if they've been lubed with normal grease in the past? I'm looking at grabbing some of this: Sil-Glyde brake lubricant
Here is a set of Centric rotors and pads, This is the set of rotors and pads I was thinking about getting, let me know what you think I'm trying to be as frugal as possible I'm working with a tight budget
Now for the wheel stud, about a year and a half ago, one of the studs broke off when I torqued the wheel down to 80 ft lbs. I feel bad about it, but I've left the 4/5 lug nuts on there.
Is it even possible to replace the wheel studs in the front without removing the wheel hub? I don't doubt being able to get the stud out, since it's broken, but getting a new one in concerns me. I've heard they make some shorter studs, but I can't seem to find any for my application.
If you need any additional information, please let me know, I look forward to hearing back. If I don't reply right away, I might have dozed off, long night.
