ECU Cooling
by ET16. 07/17/19 05:58 AM
How's your idle?
by SteveSRT8. 07/17/19 05:47 AM
A01s From Korea branded FourGreen?
by David1. 07/17/19 05:01 AM
New pennzoil rebate 7/16-12/31/19
by pdxglocker9mm. 07/17/19 03:11 AM
'82 BMW 733i M30 - Which Oil
by TXCarGeek. 07/17/19 02:07 AM
Aother MEGA score+Free Mobil 1 oil change
by GMguy84. 07/17/19 12:39 AM
I think I need therapy...
by tony1679. 07/16/19 11:53 PM
Hellcat engine in a Miata
by hate2work. 07/16/19 09:59 PM
Alignment shop questions
by Jeff999. 07/16/19 09:45 PM
ZF Aftermarket, Why Change Your ATF
by BMWTurboDzl. 07/16/19 08:10 PM
Goodyear Wrangler DuraTrac
by NHRATA. 07/16/19 08:05 PM
5 qt Castrol GTX Magnatec 5w-30 $10.30 on Amazon
by gallydif. 07/16/19 07:59 PM
My new rig - 1987 Ford Econoline 27' Glendale RV
by caprice_2nv. 07/16/19 07:44 PM
Air Compressor OCI?
by Vern_in_IL. 07/16/19 07:35 PM
Looking for an SUV
by dgunay. 07/16/19 07:29 PM
Castrol GTX Magnatec 5w30
by Envoyguy. 07/16/19 07:21 PM
2019 Subaru Dual X-Mode
by buster. 07/16/19 06:36 PM
Wear Metal Max?
by tsm750. 07/16/19 05:54 PM
Harbor Freight 25% off Thurs - Sunday
by JC1. 07/16/19 05:52 PM
80% Furnace exhaust silencer?
by PandaBear. 07/16/19 05:10 PM
MBhuntington, captainfloss, Lyndol, Belczek, Bronco628
68681 Registered Users
65 registered members (Al, Bailes1992, AZjeff, 2015_PSD, 6 invisible), 887 guests, and 17 spiders.
Topics291,976
Posts5,014,334
Members68,681
Most Online2,967
Mar 10th, 2019
Page 2 of 2 1 2
Re: Suggestions on HM Oil to treat consumption [Re: shurguywutt] #4816203
07/17/18 09:31 AM
07/17/18 09:31 AM
Utah, USA
28oz Offline
28oz  Offline
Utah, USA
Maybe try an HDEO? Have a family member's 2001 Altima that consumes a bit of 5W-30, HM or not. She'll have to top it off several times during an OCI. She just recently took a road trip to Oregon and I put Rotella 10W-30 in it since I already had it on hand and she would be doing a lot of freeway in high temperatures. She didn't have to add any oil the entire trip. The level on the dipstick was still above the midway mark when she got back to Utah. Perhaps worth a try in your application?
1990 Nissan 300zx VG30DE - PP Euro 0W-40
2004 Nissan Quest VQ35DE - PP Euro 0W-40
2003 Ford Excursion 7.3 PSD - Rotella T6 5W-40
2005 Ford Taurus 3.0 Vulcan - Havoline HM 5W-20
Re: Suggestions on HM Oil to treat consumption [Re: Bullwinkle007] #4816277
07/17/18 10:56 AM
07/17/18 10:56 AM
Oakville,Ontario
Volvoeric Offline
Volvoeric  Offline
Oakville,Ontario
Yes. The B series vtec engines burn oil no matter the oil viscosity.... but i still love them.
Re: Suggestions on HM Oil to treat consumption [Re: shurguywutt] #4816359
07/17/18 12:45 PM
07/17/18 12:45 PM
California
nthach Offline
nthach  Offline
California
In a Prius, I'm using PPHM on this current OCI after a few cycles of MMO and Schaeffer's Neutra 131 with M1HM and Castrol Edge HM. I got the consumption down to 1qt/2000+miles. I'm interested in trying the Valvoline Cummins Restore stuff. 4-cylinder FWD Toyotas do have a knack about sludged up rings, especially the 1NZ/1ZZ/2AZ engines.
The latest PDS for SuperTech Synthetic HM shows it has one of the lowest NOACK values for a GIII oil, you'll need to switch to a PAO/ester-based oil like Red Line or Amsoil Signature Series if you want any lower.
Re: Suggestions on HM Oil to treat consumption [Re: shurguywutt] #4816489
07/17/18 03:02 PM
07/17/18 03:02 PM
San Diego
FlyPenFly Offline
FlyPenFly  Offline
San Diego
AT-205 + Synthetic has helped with consumption issues more than synthetic HM oil has for me. Both are good at sealing minor leaks, but in consumption, I haven't noticed a difference with HM oil.
2014 Mercedes GLK350 3.5L DFI
2014 Mercedes E350 Coupe 3.5L DFI
2010 Audi A4 2.0T
Re: Suggestions on HM Oil to treat consumption [Re: JAG] #4816591
07/17/18 04:45 PM
07/17/18 04:45 PM
Connecticut
cheesepuffs Offline
cheesepuffs  Offline
Connecticut
Originally Posted By: JAG
Originally Posted By: cheesepuffs
In the Honda, Iím not sure if the Pilot was affected by this but other J series Hondas certainly were - the variable cylinder management causes oil consumption and hereís why.
When the second cylinder bank ďshuts offĒ, those cylinders cool down. This makes the piston rings contract, causing blow-by, and that is exacerbated by the fact that the heating and cooling of those combustion chambers and rings cause carbon buildup. The rings get stuck with carbon deposits, making it so that they canít seal to the cylinder wall as well, also causing blow-by.
I have this issue with my car and a real like tribologist (oil scientist) that I know outside of this forum recommended I run a high PAO oil to free up the stuck rings. I have read on this forum that PAO has zero cleaning abilities as told by armchair quarterbacks, but this is what this oil professional told me, so Iím trying it via Mobil 1 EP 0W-20 which has around 60% PAO content going off of its Safety Data Sheet. Itís too soon to tell if it worked. Previous to this change I ran Platinum HM which seemed to help but did not stop the oil loss, although for some reason consumption went up initially before dropping again with the Pennzoil. I would high reccomend running full synthetic oils in these engines to help prevent further deposits at least. And now with all the HM varieties of full synthetics you can get those seal swellers with them if so inclined.
Can you say whether that tribologist is a member here?
I said PAO is a lousy cleaner of engine deposits. Check the literature if you donít believe it.
They are not a member of this forum.
2008 Honda Accord Coupe V6
Page 2 of 2 1 2
