Originally Posted By: Kira
Isn't brake fluid commonly referred to as DOT 3 & 4?
Does this not imply that the DOT 3 spec is from the distant past and we should simply go to DOT 4?
NOTE: DOT 5 is different and you should know if your vehicle calls for it or not.
Also, do you use enough brake fluid to go through a gallon fast enough. The stuff absorbs moisture (as it is designed to) once the seal is broken.
Obviously if you use enough of the gallon fast enough you could just recycle what you don't use if the math works out.
I do not know the time frame for opened brake fluid even in a closed container.
DOT 3 absorbs moisture at a slower pace, but has a lower boiling point. Probably good enough for a car that never sees the track, but DOT 3 is an old spec, you are correct. DOT 3, 4 and 5.1 can all be mixed, but DOT 5 is silicone based and has specific applications. DOT 5 does not absorb water if I recall.
I'm not so sure about brake fluid absorbing moisture once the seal is cracked. If you store it inside away from fluctuating temps you should be OK for at least a year. Brake fluid is cheap, but there is no reason you should recycle 1/2 a bottle because you are worried about water getting to it. I think that theory came about to motivate people to not use questionable brake fluid as that is dangerous. Brake fluid that is only used by you, stored in an appropriate environment should be fine in anything but an ambulance, police car, or firetruck.
EDIT: No need for a giant jug, I can do all four corners on my car with a litre. I would rather a fresh bottle every time, than having a gallon jug that I thought I would use but now is a little too old to trust.
