VP Racing Oil
Very low TBN, has a lot of zinc, would definitely not be a long drain oil. I've been running Delvac 1300 15W40 in older flat tappet SBC engines with good success, haven't wiped a cam lobe with it yet!
Thank you. I like that high zinc. That's why I've been running the turbo diesel oil. And I use their fuel. But the price of their oil is expensive.
Royal Purple HPS is a quality high-zinc oil that is semi-readily available and about $8/qt.
Seems pretty overpriced, much like their fuels.
I've been happy with Valvoline VR-1 oil in my race engines for 20+ years.
I have used VR-1 in the past and liked it. Also used Redline. I wonder how the VP oil compares to Redline.
I would have to say Redline is a better oil. I know vp makes good fuels, I use vp small engine fuel for my yard equipment, I use redline gear lubes. I don't believe they blend oil, not a RP fan.
