Best coolant at low conc
Australia
Most coolants seem designed to be used at 50/50 these days. How effective are they (any?) at lower concentration? For a road/track car rather than use an inhibitor only, I'd prefer to run a glycol coolant at lower conc, maybe 25%. Any recommendations?
Just make a lower concentration and test the freeze point. Coolants have anti corrosion additives, to protect metals and seals, water pump and head gasket, and they are using less capacity and higher volume through engines these days.
Your track lets you use glycol in any concentration?
Originally Posted By: Rand
for normal use the minimum concentration is usually 30:70 coolant:water
I thought normal use was 50/50 in the US. Colder climates can use up to 70/30 = AF/W
The concentration of anti corrosion additives is what I'm concerned with. Lower concentration usually means a shorter life, too low and there maybe a lack of protection at any life.
Yes, for what I do it has never been an issue.
I wouldn't dream of tracking it, but I run 2:1 Water:prestone(green) in the summer in the MG.
I rarely go more than 6 months without at least a partial drain of coolant for one reason or another, and 66% water keeps the temperature gauge from creeping up quite as fast when I'm sitting in traffic.
I do generally drain and go to 50% Prestone some time in the fall.
Granted that's not representative of modern applications-it has a 5 bladed metal fan bolted to the water pump pulley that tends to not move a huge amount of air when stationary. In fact, even though it seems counter intuitive, I run the idle at around 1K in the summer as-there again in traffic-the water pump doesn't move enough water and the fan doesn't move enough air at ~800 rpms to keep the temperature down.
