5.0L Lamborghini Gallardo oil comsumption Help!
Perhaps run Castrol "TWS" 10w-60? It's the product BMW used to help alleviate their oil consumption issues and it is generally an excellent oil.
Spot on. I would try 10w60 Castrol first, followed by an enthusiastic track day exercise.
Originally Posted By: FordCapriDriver
I would also try Castrol 10W-60.
Although 1qt. every 600 miles ( 1000km ) isn't outrageous to be honest!
That's actually not too far off what a lot of hard driven Ford 5.0 engines were consuming back in the 80s, I seem to remember that Ford wouldn't even warranty an engine unless it was burning more than a quart every 500 miles. (I had two different 87 Mustang GTs though and neither burned oil that bad, but it was a known issue back then)
Those motor had problems and Ford was just being like all the other Big Three - Condescending Dolts.
My "Mutha Ladie" Rogue makes more power than a mid eighties carbureted 5.0 and its 1/2 the displacement.
I know Ive owned a few of those junk box cheap "Stangs.. IIRC the First fox body 5.0 was the best one of the decade with the 390 metrics wheels and the shimmed Slapper bars and the SOLID T10**. Not much power though STOCK.
**Unlike the exploding T5 featherweight junk pile)
Over here in Europe Ford engines had a good reputation for using very little oil, my '88 Escort has had nothing at all done to it ever and it has 105k miles and burns no oil whatsoever.
I was going to say "over here in Europe" Ford engines not all have a good reputation
It depends from country to country it seems! The recent Ecoboost have a certain tendency to drink oil, but that could also be related to bad maintenance, same with some diesels.
If its not leaking then your oil is going past either rings, stem seals or PCV. Pull and shake the PCV, do or don't perform leak down based on noise when you shake the PCV.
Originally Posted By: EricWalls
I'll try an answer some questions here:
I Paid $85,000 USD. for the car. It's a Heck of a lot a car for the money I think. My only regret is it not being a true 6-speed. Its the E-gear paddle shift.
My daily driver is an 2002 E46 M3, so I'm familiar with the Castrol TWS 10W-60. But I believe it maybe relabeled as Castrol Edge "SuperCar" oil now. " The Castrol 10w-60 SuperCar is available at my local Autozone.
If my car did have stuck rings, or even any type of oil getting past the rings in the combustion camber, would a compression test show me that? or even a Leak down test (which ive never done before)
The Gallardo is very Much an Audi/VW product, not sure about the actual engine block, or transmission but the electronics, interior buttons and switches all have Audi part #'s for the most part.
Yes that's me in the video, I had been awake all day waiting for the car to arrive, it was late & freezing outside, I was overwhelmed with everything an didn't know what to really say to the camera, but I'm still glad to have it on video. I was so much in awe that I didn't take one picture on delivery day.
Lastly I know everyone has there "favorite" oil brands but as far as oil weight I'm torn between 10w-60 (large #'s spread will shear down?) or a Less aggressive 15w-50 oil that maybe more shear stable, as my car will only be driven in the warm summer months, an put into storage during the cold ohio winter's ,...……….how thick can the oil viscosity be for cold startup protection during the Ohio summers, 10w, 15w, 20w. I don't know
Mobil-1 15w-50 at short OCI's, maybe even 1k-2k. You likely have some stuck/coked rings. And 5w-40 for your engine is inadequate during summer driving. Mid (and rear) engine vehicles tend to have higher engine bay temperatures than front and front-mid engine vehicles. M1 15w-50 is readily available in 5qt jugs.
My 1999 911 3.4 H6 (in a significantly lower state of tune than your lambo, mind you) comes recommended from Porsche for 0w-40 oil. Which ends up being fully inadequate even for street driving here in Central FL from March through November (with oil pressure regularly dipping below recommended levels and consumption of 1 quart every 1500 miles). So, I've seen great success running robust dual-rated SN/CJ 5w-40 diesel oils like Rotella T6 (actually both 0w-40 and 5w-40), Mobil Delvac 5w-40, and Chevron Delo Syn 5w-40(with HTHS's of 3.8-4.1, up from M1's starting HTHS of 3.5, which quickly moves toward the 2.9 of a 5w-30 oil....YIKES). Engines run smoother and burn/consume zero oil now even with spirited driving bracketed by radiator crushing stop-and-go traffic. I have run M1 15w-50 in mine and, while great when fully warm, warm up time was rather extended over even 5w-40 and the engine was pretty sluggish until fully warm (which often took more than 20 minutes of actual driving) whereas the 5w-40 is fully warm with optimal oil pressure after only 10-12.
Any std gasoline-only-rated 40 weight will likely not be heavy enough for you; 5w-40 dual rated oils as noted above should be your absolute baseline, with a min HTHS of 3.6 and above. I think M1 15w-50 is a cost-effective stop-gap experiment on your way to something possibly as heavy as Castrol 10w-60. I would try 15w-50 first.
