Nick1994
$100 site donor 2024
I'm thinking about installing a bigger transmission cooler on my Jeep, it has a factory one but it's the cutest thing you ever saw. It's a common upgrade, but I worry about airflow for the radiator. My Jeep runs pretty hot at low speeds, 230 degrees or so. I'm concerned that putting a big transmission cooler on it will reduce radiator air flow, and might make it run hotter.
Is this possible?
BTW, the entire cooling system has been replaced, not concerned with that.
Is this possible?
