We bought a house 2 years ago, came with a matching washer and dryer set made by Samsung with pedestals.
The washer started leaking recently, I did the basic stuff as seen on forums and youtube, checking clogs, etc. It turns out, the tub is cracked around the front rim from about 10 o'clock clockwise all the way down to 6 o'clock. It doesn't look too difficult to replace, just a lot of fasteners. The part itself will cost about $170. I believe it to be some kind of Nylon, I originally thought it was a small crack and I might be able to fix it with some kind of adhesive, but it seems too extensive.
Bottom of crack
New, uncracked front half of tub
My options:
Buy a new Samsung washer that can reuse the pedestal.
Buy a different washer that might be able to reuse the pedestal, go without a pedestal, or buy a new pedestal (never been a huge Samsung fan) (side note, why are pedestals so expensive?!).
Fix the current washer, and hope that the washer lasts long enough to make it worth it (who knows how soon something else may break).
We don't need the pedestals, but it's nice not needing to bend down as far to move the laundry. If we do buy a new washer, I'd consider getting something better quality, that may not have all the fancy features of the Samsung, like a Speed Queen, although I hear that very recently, the SQ machines aren't being built as sturdily. We would likely stick with a front loader though, my wife is short and has trouble getting into the bottom of a top loader.
What would you guys do? Thanks for any thoughts or any washer suggestions!
Bottom of crack
My options:
