0w20 vs 0/5w30 (yes I know another viscosity thread)
by SnowDrifter. 02/15/19 11:42 PM
skid plate
by mobilaltima. 02/15/19 10:32 PM
The Last Gladiators (French)
by Marco620. 02/15/19 08:54 PM
Rural King 5W30 Citgo Superguard blend 5qt jug $9.91
by tenderloin. 02/15/19 08:34 PM
Meet Watson!
by spasm3. 02/15/19 08:16 PM
Tie Rod and Ball Jt. Recommendations/Advi
ce
by coopns. 02/15/19 08:11 PM
Uninstall Avast
by willbur. 02/15/19 06:58 PM
Need a new toliet
by JLawrence08648. 02/15/19 06:55 PM
Help Me Choose A Smartphone
by Warstud. 02/15/19 05:29 PM
Source for Torque Wrench Calibration?
by SubLGT. 02/15/19 05:09 PM
Transmission Scraping Noise
by bprat318. 02/15/19 04:59 PM
Ok to mix gear oil viscosities?
by zuluplus30. 02/15/19 04:11 PM
Tore Wheel Cylinder Boot on 2007 Tacoma
by john_pifer. 02/15/19 04:10 PM
Spotify to home theater
by Malo83. 02/15/19 03:19 PM
6.0 powerstroke for a forever truck
by FLORIDA. 02/15/19 02:55 PM
Atwoods PYB 5QT jug $7.99 after rebate !!
by GMguy84. 02/15/19 02:52 PM
Torque Wrench Accuracy
by Kjmack. 02/15/19 12:57 PM
Thoughts on pennzoil 0w30 lx
by 750HMF. 02/15/19 12:26 PM
3dfever, Mahmoud, Happycamper, jftcat, TexasForever
67246 Registered Users
37 registered members (bfleeman, BrianF, Blkstanger, anndel, 1WildPig, Ag76, 2 invisible), 770 guests, and 56 spiders.
Topics298,255
Posts4,988,167
Members67,246
Most Online2,474
Feb 10th, 2019
Spark plug wire question #4813344
07/13/18 03:05 PM
07/13/18 03:05 PM
TX
s2krunner Offline OP
TX
I just replaced plugs on my 2011 Ford Ranger 4 cylider.
All other wire snap on, fit perfectly. But one cylinder wire wont go all the way in. Ive tried everything i could. I was thinking old plug was very rusted so maybe plug wont go all the way in? I tightened down more on plug very carefully and took them off/on and cleaned them. Nothing really helped.
Wire actually seat, i had to pull hard to take it out again. It just not goes all the way in...
Wire is Motorcraft. Plug also Motorcraft.
Thank you
2018 Chevy Camaro 6.2L V8
2017 Ford Explorer 3.5 V6
2011 Ford Ranger 4 banger
Re: Spark plug wire question [Re: s2krunner] #4813348
07/13/18 03:11 PM
07/13/18 03:11 PM
Silicon Valley
PandaBear Offline
PandaBear  Offline
Silicon Valley
Did the old one goes back in too?
"You keep asking questions PandaBear and you'll end up a vegetarian like my wife" - Camu Mahubah
Re: Spark plug wire question [Re: s2krunner] #4813349
07/13/18 03:12 PM
07/13/18 03:12 PM
USA
slacktide_bitog Offline
USA
Did you grease it? The wires usually come with some kind of grease you apply to the plugs and also the contacts on the coil. And wouldn't you be installing new plugs when you replace the wires?
NGK includes a packet of grease with their wires smile
Re: Spark plug wire question [Re: s2krunner] #4813352
07/13/18 03:21 PM
07/13/18 03:21 PM
TX
TX
Somehow original one did not go in all the way too. I should have look before take them off.
Yes, i did grease it.
Re: Spark plug wire question [Re: s2krunner] #4813354
07/13/18 03:22 PM
07/13/18 03:22 PM
TX
TX
All coil looked fine even old ones. Just rusted out side.
Re: Spark plug wire question [Re: s2krunner] #4813355
07/13/18 03:22 PM
07/13/18 03:22 PM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
Boot grease is your friend. Learned that the hard way on a Jeep V8 one Saturday plug change from Hades. grin2
Thick oil is better grin2
Re: Spark plug wire question [Re: s2krunner] #4813356
07/13/18 03:22 PM
07/13/18 03:22 PM
Illinois
wymi516 Offline
wymi516  Offline
Illinois
If the connector is locking on to the plug it sounds like the plug wire boot has slid up on the cable. Try pushing down just the boot over the plug.
2016 KIA Forte SX 1.6L T-GDI Daughter
2013 Chevy Impala LT 3.6L GDI Mine
2014 Chrysler 200S 3.6L PFI Wife
Re: Spark plug wire question [Re: s2krunner] #4813357
07/13/18 03:23 PM
07/13/18 03:23 PM
TX
TX
Re: Spark plug wire question [Re: s2krunner] #4813361
07/13/18 03:32 PM
07/13/18 03:32 PM
USA
oldhp Online content
oldhp  Online Content
USA
Put just a dab plug wire grease inside the boot and all of the top seal of spark plug boot. Then never use pressure washer to clean top of engine off. That's why the spark plugs rusted, trapped water. If you do "wash" engine....pull the all the wires and blow out with air until completely dry. My 2010 Ranger 4 cyl had some moisture on the plugs from the detail shop washing the engine bay.
2018 RAM 1500 3.6/8 speed.
2017 Jeep Sahara Unlimited 3.6
"U kan't fixe it......if'n it ain't broke."
Re: Spark plug wire question [Re: oldhp] #4813364
07/13/18 03:36 PM
07/13/18 03:36 PM
TX
TX
I bought this truck used. So not sure what happened to plugs. It was also gapped at 0.060.
Is yours go all the way in?
Re: Spark plug wire question [Re: andyd] #4813369
07/13/18 03:45 PM
07/13/18 03:45 PM
TX
TX
Haha yeah it sure helped one of other cylinder but not this one 😥
Re: Spark plug wire question [Re: s2krunner] #4813371
07/13/18 03:47 PM
07/13/18 03:47 PM
Arizona
Kawiguy454 Offline
Kawiguy454  Offline
Arizona
+1 washing the engine is a bad idea. Also the grease is not just grease for the boot but is dielectric to keep the high voltage from shorting across the boot. Apply dielectric grease liberally especially if you get your engine wet.
Re: Spark plug wire question [Re: s2krunner] #4814378
07/14/18 11:19 PM
07/14/18 11:19 PM
USA
USA
Yep. Wires pushed in, in one steady push. I swear I could feel the snap on the plug tops.
Re: Spark plug wire question [Re: oldhp] #4814924
07/15/18 03:39 PM
07/15/18 03:39 PM
TX
TX
I pushed them more other day. Back side of coil snapped in but half didnt lol. So half of it snapped in and half not. Definitely its not something i like how its done but well i can live with it. My finger been hurting for couple days haha
I will change them again at 150k later.
But its good tho, ive been put 100 miles so far and runs like new truck!
Re: Spark plug wire question [Re: s2krunner] #4815060
07/15/18 06:49 PM
07/15/18 06:49 PM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
My first toy car was a '63 Willys Overland do Brasil. Not 3 weeks later, I learned we had twins coming. The wires on the Willys were original and all dried out. I bought a bunch of boot grease and massaged it into the wires. It cured damp start troubles
Moderated by  ekpolk
