Test drove a Tesla Model 3
by y_p_w. 03/22/19 05:54 PM
Did i make a mistake? Hilux 3.0 d4dhello
by Anton93. 03/22/19 05:52 PM
WM Valvoline Full Syn Modern Eng Clearance
by Spartanfool. 03/22/19 04:22 PM
Need Moly basic training
by Bill_W. 03/22/19 04:03 PM
P0420 code goes away in warmer weather
by 2010Civic. 03/22/19 03:54 PM
Customer declined new belt
by Chris142. 03/22/19 03:13 PM
How to deep clean back of wheels?
by qdeezie. 03/22/19 02:51 PM
RK oil sale T4 15w40
by 1978elcamino. 03/22/19 01:57 PM
Hello and goodbye to my old job
by Motorking. 03/22/19 01:52 PM
Ichiro Suzuki retiring from baseball.
by PimTac. 03/22/19 12:40 PM
91 Caprice door wont fully latch...
by columnshift. 03/22/19 12:30 PM
Denso Platinum TT for 2004 Corolla?
by zorobabel. 03/22/19 11:16 AM
What should I run in the 09 rabbit trans
by ram_man. 03/22/19 10:32 AM
Chevy express van for towing
by Fitter30. 03/22/19 10:24 AM
Mobil 1 Filter Clearance - Wal Mart
by sdude2k2000. 03/22/19 10:01 AM
STP VI trans fluid
by acme. 03/22/19 09:37 AM
Increased oil capacity = lower pil temps ?
by SavagePatch. 03/22/19 09:15 AM
2007 Corolla - P0441 and P0455 codes
by Bama. 03/22/19 08:44 AM
Oldmoparguy1
by cjcride. 03/22/19 08:23 AM
Skendread, NGK, Thomas1, RE_Vision, JamesMc
67587 Registered Users
98 registered members (anndel, 2015_PSD, AlanGonzales, 2010Civic, 12 invisible), 2,086 guests, and 52 spiders.
Topics286,246
Posts4,905,180
Members67,587
Most Online2,967
Mar 10th, 2019
2008 Volvo C30 2.4i (5244S4) oil consumption #4813219
07/13/18 02:01 PM
07/13/18 02:01 PM
Quebec, Canada
mlab Offline OP
mlab  Offline OP
Quebec, Canada
Hi,
Bought an older C30, with now 230 000 km (144 000 miles). Very clean car with still super responsive suspension, steering, brakes and engine. Only problem is a little too much oil consumption which happens when I fool around with it more often. Babied it when I brought it home after purchase, for hundreds of km, and oil level stayed the same.
Manual recommends :
5W-30 / 5W-40 or synthetic : 0W-30 / 0W-40
ILSAC specification GF-3, API SL, or ACEA A1/B1.
I did my first oil change on it and it's currently running dyno 5W-30. This is the oil that it drinks too much of, when pushed harder.
This all happened since the end of April so, summer in Quebec, Canada...a relatively hot one.
From a brief overview, I found these options I need to look into :
1. PCV
2. Ring cocking : Kreen, Valvoline HDEO
3. High mileage oil
4. Additives
5. Thicker grade (40 instead of 30)
If anybody has other solutions to propose, or any specific knowledge about this engine (2.4i, 5244S4, shared by the S40, V50, C70), please let me know.
In the mean time, I'll keep searching the forums.
Thanks!
Re: 2008 Volvo C30 2.4i (5244S4) oil consumption [Re: mlab] #4813264
07/13/18 02:53 PM
07/13/18 02:53 PM
PA
123Saab Offline
123Saab  Offline
PA
Your best bet is to check the PCV valve for proper functioning and then take it from there.
Anything can happen
The tallest towers be overturned
Those in high places be daunted
Those overlooked regarded
- Seamus Heaney
Re: 2008 Volvo C30 2.4i (5244S4) oil consumption [Re: mlab] #4813376
07/13/18 04:56 PM
07/13/18 04:56 PM
Virginia Beach
Astro14 Offline
Astro14  Offline
Virginia Beach
Itís more than just a valve in the PCV system. Volvoís donít have a PCV Valve. All the pipes and passages need to be replaced or cleaned.
Nothing else will help your oil consumption- you need a PCV overhaul.
Ignore it, and it will get worse, until you blow an engine seal. That gets expensive.
Check out IPD for a complete parts kit for your model/year.
32 Packard 15W40
02 Volvo V70 T5 0W40 M1
02 Volvo V70 XC 0W40 Edge
05 MB S600 0W40 M1
Re: 2008 Volvo C30 2.4i (5244S4) oil consumption [Re: Astro14] #4813388
07/13/18 05:22 PM
07/13/18 05:22 PM
PA
123Saab Offline
123Saab  Offline
PA
Did not know that, looked it up and yeah it's a whole breather system. Interesting and not overly expensive.
Anything can happen
- Seamus Heaney
Re: 2008 Volvo C30 2.4i (5244S4) oil consumption [Re: mlab] #4813504
07/13/18 08:41 PM
07/13/18 08:41 PM
Connecticut
Sam_Julier Offline
Sam_Julier  Offline
Connecticut
I have owned many V70 I5 engines though none right now. After you replace the PVC system switch to a Full Syn 0w30 or 0W40. I ran Petro-Canada Duron 0W30 for years. Easy to get in your area. Never had an issue with the PVC system. These engines do poorly on conventional oil.
Sam
2013 Toyota Avalon Hybrid TGMO 0W20, 68k
1993 Volvo 245 T5 10W30, 153k
1993 Volvo 244 PP 10W30, 166k
Re: 2008 Volvo C30 2.4i (5244S4) oil consumption [Re: mlab] #4814350
07/14/18 11:04 PM
07/14/18 11:04 PM
Quebec, Canada
mlab Offline OP
mlab  Offline OP
Quebec, Canada
Thanks for the replies. I did stumble upon posts on Volvo Forums saying the PCV is a problem with these cars and affects fuel economy. Didn't yet associate it with oil consumption. Astro, how exactly does it blow engine seals? Sam, did anything else go bad on conventional oil?
Thanks
Re: 2008 Volvo C30 2.4i (5244S4) oil consumption [Re: mlab] #4814466
07/15/18 07:01 AM
07/15/18 07:01 AM
Brittany / Canada
Popsy Offline
Popsy  Offline
Brittany / Canada
In Europe they are designed for A5/B5 oil, but are run by most people on A3/B4 oil, because it's generally cheaper and easier to get there. I haven't heard any people having problem with the PCV system in these engines, so maybe it is also related to the use of conventional oil ?
I know in Quebec oil can be expensive, good synthetic sometimes hard to get at a good price, etc...last winter I put Rotella T6 0W40 in my Quebec car (not a Volvo though), bought on special at Walmart, cause it was the cheapest 0W I found when I was in the market for oil. That and a Fram ultra (not Walmart, Rockauto), and the car run much smoother than with the 5W30 conventional it had before. It was my first oil buying experience in Canada, and I was quite surprised by the "difficulty" to find a real synthetic that doesn't cost an arm and a leg wink
96 Barchetta, 300V 5W40 | Forfour 95, SHU 0W40
Mazda 6 2.3, M1 AFE 0W20 | Colt Ralliart, 300V 0W40
Re: 2008 Volvo C30 2.4i (5244S4) oil consumption [Re: mlab] #4814550
07/15/18 09:06 AM
07/15/18 09:06 AM
Connecticut
Sam_Julier Offline
Sam_Julier  Offline
Connecticut
Conventional oil doesn't meet the specs and it fouls the PVC system faster. If you run any 0W30 or OW40 you'll be fine. Astro14 has posted excellent UOA running 0W40.
Sam
