Originally Posted By: Hootbro
Originally Posted By: johnnyz73
PEAK Global can be used in place of the Purple Mopar Coolant... It is compatible with Spec MS 12106 as seen in the picture attached below :
https://i.imgur.com/nSflo6I.jpg
Devil is in the details. The asterisk denotes that a complete flush and refill with the Peak coolant is required and the top off is only if topping off a system with the Peak coolant already in there.
This stuff is not mix compatible with MS12106 coolant. It is only full flush replacement compatible for the vehicle engine if maintained going forward with the Peak.
If you read the text on the label, the asterisk refers to the "lifetime protection guarantee" conditions. Otherwise, it states that it is suitable for complete replacement or top offs, implying that it IS compatible with the MOPAR coolant. It also states that it
mixes with any color coolant and will not void the vehicle warranty.
Having said that, unless it was an emergency, I would not top off my coolant with a different brand/type of coolant. I can never understand being penny-wise and pound-foolish with very expensive equipment. A beater, maybe o.k..
