Installed this a couple weekends ago. Power steering is a Wix 51269 Hydraulic filter, Coolant is a Fleetguard WF2107 non-chemical coolant filter. The Coolant filter is the Wix base, and I modified this existing bracket on the front of the engine to hold it.
The PS is a 3/4-16 remote head, I think its a Derale, but its a pretty generic part. I drilled and tapped the frame for the bolts. I just inserted it into the existing return line from the steering rack.
I still have a trans filter to install. For that I am using a 6um Donaldson filter & head. I have to finish making the bracket to hang it. Between finding motivation and being busy with other stuff I havent had time to do it. Im hoping this weekend. Look clear so far.
