Originally Posted By: Astro_Guy
My Ariens snow blower with 254 cc motor is the outlier in this conversation. It stands to reason that a snow blower won't see much use above 32 degrees F, let alone 40 F at the extreme. The manual calls for 5w30. What are your thoughts on running a good quality 0w20 synthetic in a snow blower? With three cars in the driveway spec'd for 0w20, there will always be some on hand.
0W20 will be fine in a snow blower. Now, I will tell you why.
Air cooled small engines TYPICALLY run about 140 degrees hotter than the ambient temp, give or take (generality). So a mower engine ran on a 85 degree day, will run at ABOUT 225 degrees. A mower engine ran at 20 degrees will run at ABOUT 160 degrees. As you are probably aware, 160 degree oil is much thicker than 225 degree oil viscosity wise. So your 160 degree 0W20 oil will be thicker than a 5W30 or 5W40 oil is at 225 degrees.
Basically, snow blower engines never really get all that hot. Yes they get hot, but they dont get summer time in Arizona hot. They have cooling fans blowing cold air on the engine, which rapidly cools it. A 20 weight is more than enough when you take the temperature viscosity curve into equation.
