0w20 vs 0/5w30 (yes I know another viscosity thread)
by SnowDrifter. 02/15/19 11:42 PM
skid plate
by mobilaltima. 02/15/19 10:32 PM
The Last Gladiators (French)
by Marco620. 02/15/19 08:54 PM
Rural King 5W30 Citgo Superguard blend 5qt jug $9.91
by tenderloin. 02/15/19 08:34 PM
Meet Watson!
by spasm3. 02/15/19 08:16 PM
Tie Rod and Ball Jt. Recommendations/Advi
ce
by coopns. 02/15/19 08:11 PM
Uninstall Avast
by willbur. 02/15/19 06:58 PM
Need a new toliet
by JLawrence08648. 02/15/19 06:55 PM
Help Me Choose A Smartphone
by Warstud. 02/15/19 05:29 PM
Source for Torque Wrench Calibration?
by SubLGT. 02/15/19 05:09 PM
Transmission Scraping Noise
by bprat318. 02/15/19 04:59 PM
Ok to mix gear oil viscosities?
by zuluplus30. 02/15/19 04:11 PM
Tore Wheel Cylinder Boot on 2007 Tacoma
by john_pifer. 02/15/19 04:10 PM
Spotify to home theater
by Malo83. 02/15/19 03:19 PM
6.0 powerstroke for a forever truck
by FLORIDA. 02/15/19 02:55 PM
Atwoods PYB 5QT jug $7.99 after rebate !!
by GMguy84. 02/15/19 02:52 PM
Torque Wrench Accuracy
by Kjmack. 02/15/19 12:57 PM
Thoughts on pennzoil 0w30 lx
by 750HMF. 02/15/19 12:26 PM
3dfever, Mahmoud, Happycamper, jftcat, TexasForever
67246 Registered Users
35 registered members (bfleeman, anndel, 1WildPig, Ag76, bbhero, 3 invisible), 785 guests, and 57 spiders.
Topics298,255
Posts4,988,167
Members67,246
Most Online2,474
Feb 10th, 2019
5w20 vs 5w30? #4812616
07/12/18 06:57 PM
07/12/18 06:57 PM
Southern VA
klt1986 Offline OP
klt1986  Offline OP
Southern VA
Would a 5w20 and 5w30, such as Mobil 1, Pennzoil Platinum, Valvoline Synthetic or Castrol Edge, have the same cold startup viscosity? I understand once the oil is at operating temperature, one should act as a 30 weight and the other as a 2o weight. However, wouldn't they both flow the same at startup??
Wife: 08 Honda CR-V 4WD, M1 5W-20
Me: 11 Toyota Tundra DC 4WD 5.7L, PP 5W-30
Me Work: 06 Ford Explorer 4WD 4.0L, Pennzoil 5W-30
Son: 14 Toyota Corolla S, M1 AFE 0W-20
Re: 5w20 vs 5w30? [Re: klt1986] #4812633
07/12/18 07:16 PM
07/12/18 07:16 PM
Western S.C.
CR94 Offline
CR94  Offline
Western S.C.
About.
Doesn't 5W-30 effectively consist of 5W-20 with a dash of extra VI improver thrown in?
2011 Toyota Prius now at 96K
Re: 5w20 vs 5w30? [Re: klt1986] #4812662
07/12/18 07:34 PM
07/12/18 07:34 PM
Pennsylvania
Astro_Guy Offline
Astro_Guy  Offline
Pennsylvania
They would if you were in Fairbanks Alaska in January. The 5w30 should be a little thicker in Virginia.
Re: 5w20 vs 5w30? [Re: klt1986] #4812679
07/12/18 07:42 PM
07/12/18 07:42 PM
PA
d00df00d Offline
d00df00d  Offline
PA
In sub-freezing temps, they'll be comparably pumpable.
On startup at more moderate temps, most 5W-20s will be thinner than most 5W-30s.
2008 BMW M3
Re: 5w20 vs 5w30? [Re: klt1986] #4812720
07/12/18 08:09 PM
07/12/18 08:09 PM
Virginia
bbhero Online sick
bbhero  Online Sick
Virginia
Yep. The same. The last couple of winter's with low temps down to as low as -7F in the area... No difference amongst those oils at start up. If it pumps.... It pumps. Which those oil would. If those oils fall back into the sump... It falls back into it. Which those iils would have easily at -5 to -7F. The CCS and MRV with all these oils make them all great for the coldest temps seen in this area. I would not be concerned at all smile
Nissan Altima 3.5 Coupe
Mobil Super 5w30 Wix 57356
"Treat your family like your friends and treat your friends like your family."
Re: 5w20 vs 5w30? [Re: klt1986] #4812749
07/12/18 08:46 PM
07/12/18 08:46 PM
South Florida
bubbatime Offline
bubbatime  Offline
South Florida
Not the same, but close. Every oil will have its own viscosity, at each temp, measured in centistokes.
So when you say startup, what temp are you talking about? Because in Alaska, the cold start winter viscosity is going to be drastically different than the cold start viscosity in Phoenix in the summer.
One paper I read showed when oil is freezing solid, right below its pour point, it has about 100,000 centistokes. This is about -45 degrees C. At operating temp, 100 degrees C, a synthetic 5W20 has about 9 centistokes.
So a synthetic 5W20 has between 9 centistokes at operating temp, and 100,000 centistokes when the oil is frozen solid and almost pours.
The 5W30 vs 5W20 labeling is a layman's labeling system, to dumb down what the oil does for the average consumer. Most folks wouldn't understand what viscosity oil to buy if it was labeled by centistokes.
17 Chrysler Pacifica Edge Syn 5W30
13 Yamaha XT250 Valv MC 10W40
10 Acura TSX 2.4 SuperTech Syn 5W20
06 GMC Sierra SuperTech 10W30
Moderated by  ekpolk
