WM Valvoline Full Syn Modern Eng Clearance
by Spartanfool. 03/22/19 04:22 PM
Need Moly basic training
by Bill_W. 03/22/19 04:03 PM
P0420 code goes away in warmer weather
by 2010Civic. 03/22/19 03:54 PM
Customer declined new belt
by Chris142. 03/22/19 03:13 PM
How to deep clean back of wheels?
by qdeezie. 03/22/19 02:51 PM
RK oil sale T4 15w40
by 1978elcamino. 03/22/19 01:57 PM
Hello and goodbye to my old job
by Motorking. 03/22/19 01:52 PM
Ichiro Suzuki retiring from baseball.
by PimTac. 03/22/19 12:40 PM
91 Caprice door wont fully latch...
by columnshift. 03/22/19 12:30 PM
Denso Platinum TT for 2004 Corolla?
by zorobabel. 03/22/19 11:16 AM
What should I run in the 09 rabbit trans
by ram_man. 03/22/19 10:32 AM
Chevy express van for towing
by Fitter30. 03/22/19 10:24 AM
Mobil 1 Filter Clearance - Wal Mart
by sdude2k2000. 03/22/19 10:01 AM
STP VI trans fluid
by acme. 03/22/19 09:37 AM
Increased oil capacity = lower pil temps ?
by SavagePatch. 03/22/19 09:15 AM
2007 Corolla - P0441 and P0455 codes
by Bama. 03/22/19 08:44 AM
Oldmoparguy1
by cjcride. 03/22/19 08:23 AM
Check engine light
by rtrdad. 03/22/19 08:21 AM
Super Tech 5W30 Synthetic With GDI Engine ?
by ChrisD46. 03/22/19 07:00 AM
Skendread, NGK, Thomas1, RE_Vision, JamesMc
67587 Registered Users
101 registered members (14Accent, 92saturnsl2, 53' Stude, 240_Ed, 2010Civic, 9 invisible), 2,181 guests, and 49 spiders.
Topics286,244
Posts4,905,149
Members67,587
Most Online2,967
Mar 10th, 2019
16 Silverado 5.3L, A/C Delco 0W-20, 7745 Miles #4812468
07/12/18 05:02 PM
07/12/18 05:02 PM
MD, USA
Why Offline OP
Why  Offline OP
MD, USA
Decided to take advantage of a free dealer oil change, and as you can see from my results, am regretting it. This OCI did occur through an abnormally cold winter and spring and it did do a lot of idling. Miles were probably 50/50 city/highway. Filter was new Fram Ultra. OLM was at 1% remaining. The two previous samples were with PUP 5W-20.
Dumped the oil and refilled with M1 EP 0W-20 that I scored for $14/jug. Curious to see if the iron drops back down next sample.
Re: 16 Silverado 5.3L, A/C Delco 0W-20, 7745 Miles [Re: Why] #4812484
07/12/18 05:28 PM
07/12/18 05:28 PM
US
JLTD Offline
JLTD  Offline
US
Bit of an increase in wear metals for the dealer oil....doubt they even knew what it was. Hope the M1 brings it down for you, how long was this run on the calendar?
I use the overseas owner's manual to choose my oil.
Using AMSOIL
Hers: 2008 Jeep Liberty 143k, SS 5w30/Amsoil
His: 2015 4Runner 51k, OE 5w30/Wix
Re: 16 Silverado 5.3L, A/C Delco 0W-20, 7745 Miles [Re: JLTD] #4812487
07/12/18 05:36 PM
07/12/18 05:36 PM
MD, USA
Why Offline OP
Why  Offline OP
MD, USA
A tad over 10 months.
Re: 16 Silverado 5.3L, A/C Delco 0W-20, 7745 Miles [Re: Why] #4812544
07/12/18 06:49 PM
07/12/18 06:49 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
This help...
Re: 16 Silverado 5.3L, A/C Delco 0W-20, 7745 Miles [Re: Trav] #4812558
07/12/18 06:56 PM
07/12/18 06:56 PM
MD, USA
Why Offline OP
Why  Offline OP
MD, USA
Originally Posted By: Trav
This help...
Yes, thanks!
Re: 16 Silverado 5.3L, A/C Delco 0W-20, 7745 Miles [Re: Why] #4812567
07/12/18 07:05 PM
07/12/18 07:05 PM
Wet side WA
JohnnyJohnson Online content
JohnnyJohnson  Online Content
Wet side WA
All Chevy engines seem to have such bad iron numbers I can't believe it!
2004 Corolla 130005
Out: EDGE EP 5W-30 Bosch 3311 7156 Miles
In: Havoline Pro DS 10w-30 Purolator PureOne 3-14-19 129693
2006 Duramax 74725
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: 16 Silverado 5.3L, A/C Delco 0W-20, 7745 Miles [Re: Why] #4812588
07/12/18 07:27 PM
07/12/18 07:27 PM
The land of USA-made Subies!
SubieRubyRoo Offline
If you really want to clean it up quick, run this OCI for 3k or less, then follow it up with another OCI of 3k or less. This will flush out any copper or iron that is currently sticking to the block and in nooks and crannies. It worked on my Odyssey, the first UOA when I got it was 31ppm Fe, I ran PP for 3k, then drained and refilled with PP 5w20 again, and ran it 6500 miles. My iron dropped to single digits and has remained there for 30k.
Re: 16 Silverado 5.3L, A/C Delco 0W-20, 7745 Miles [Re: Why] #4812604
07/12/18 07:51 PM
07/12/18 07:51 PM
North Carolina
Rat407 Offline
Rat407  Offline
North Carolina
The fact that they are saying a trace of fuel to me is telling me that there is a lot more than a trace and that is one of the major factors in this sample not looking so good. It is my understanding that Blackstone's test for fuel isn't very accurate and is an older method.
2002 Silverado 5.3 0w-20 AMSOIL
Re: 16 Silverado 5.3L, A/C Delco 0W-20, 7745 Miles [Re: Why] #4812621
07/12/18 07:59 PM
07/12/18 07:59 PM
MD, USA
Why Offline OP
Why  Offline OP
MD, USA
Just remembered...it wasnt a fram ultra this run, it was also an ac delco filter. Still, the insolubles didnt change so I suppose it did the trick.
Re: 16 Silverado 5.3L, A/C Delco 0W-20, 7745 Miles [Re: Why] #4812691
07/12/18 08:50 PM
07/12/18 08:50 PM
Indiana
Phishin Offline
Phishin  Offline
Indiana
Copper and iron seem way too high
This engine should be way past break in.
Where is the manganese coming from??
2018 Chevy Silverado 3500HD 6.0L Gas: RLI 10w30
2010 Accord-LX K24: MaxLife 5w30 + Torco MPZ
2014 CR-V LX K24: M1 0w30
Re: 16 Silverado 5.3L, A/C Delco 0W-20, 7745 Miles [Re: Why] #4812884
07/13/18 05:14 AM
07/13/18 05:14 AM
Sunny Florida
SteveSRT8 Offline
SteveSRT8  Offline
Sunny Florida
We who actually own and use GM V8's every day will tell you that the OA numbers are not concerning.
While the iron is "high" it is easily accounted for and the copper may stick around for a long time. Yet the engine will likely easily outlast the rest of the truck.
"In a democracy, dissent is an act of faith."
J. William Fulbright
Best ET-12.79 @ 111 mph
4340 pounds, Street tires
Just like we go to Publix
Re: 16 Silverado 5.3L, A/C Delco 0W-20, 7745 Miles [Re: JohnnyJohnson] #4812927
07/13/18 07:14 AM
07/13/18 07:14 AM
NJ
buster Offline
buster  Offline
NJ
That's generally what we see on here. The oil often has little to do with wear metals. A good engine and good oil, you can go longer. Some engines just naturally wear more or show more wear. Some oils can reduce wear a bit, but IMO it's never significant enough that you'd really notice a difference in the long run.
