Fram Pro Synthetic #9688 **NEW** CUT OPEN
by 53' Stude. 03/24/19 08:26 AM
Wagner OEX vs Akebono ProACT
by Patrick0525. 03/24/19 08:12 AM
Plasti Diping my OEM rims question
by dblshock. 03/24/19 07:53 AM
"The new" Mobil 1 Racing Oil ?
by lawnguy. 03/24/19 06:32 AM
Arlen Ness passes
by 02SE. 03/24/19 03:15 AM
Plants - they learn and remember
by Shannow. 03/24/19 03:02 AM
Rotella Gas Truck
by jpstiles02. 03/24/19 02:53 AM
The case for quitting Facebook
by StevieC. 03/23/19 11:21 PM
Mixing Toyota Spec'ed 0w20 & 5w20
by David2431. 03/23/19 09:59 PM
Run old DOS games on your Wii
by StevieC. 03/23/19 09:51 PM
Live in PA? Need a car? Want something UNIQUE?
by 14Accent. 03/23/19 09:33 PM
Painting plastic
by HangFire. 03/23/19 09:27 PM
Rav4 vs Forester
by fdcg27. 03/23/19 09:07 PM
cleanser stain on cylinder liners
by neo3. 03/23/19 09:06 PM
Electronics and DC Voltage Question
by maverickfhs. 03/23/19 08:39 PM
Oil Change Tips for the Newbie
by StevieC. 03/23/19 08:39 PM
DashCams
by Eddie. 03/23/19 08:07 PM
GSXRBullwinkie, Mark1970, FixItDad28, RandomJoe, Sciascia
67599 Registered Users
105 registered members (AandPDan, A1O, 4WD, 1foxracing, 2003f7, 53' Stude, 10 invisible), 1,826 guests, and 60 spiders.
Topics286,325
Posts4,906,430
Members67,599
Most Online2,967
Mar 10th, 2019
Page 1 of 3 1 2 3
Known downsides to LSPI-oriented formulations? #4812374
07/12/18 03:28 PM
07/12/18 03:28 PM
PA
d00df00d Offline OP
d00df00d  Offline OP
PA
In view of the fact that there's no free lunch: what are the potential downsides to chemistries aimed at reducing LSPI?
I know Ca has to be reduced, which means other detergent/dispersant additives need to be bumped up. Does this have potential implications for ash generation and/or acid fighting ability? I'd imagine any such problems can be and are being addressed in the total formulation. But if so, that still leaves the question of whether there's ever a case in which, say, an SN/GF-5 oil might be preferable to a comparable SN Plus oil -- kind of like how MB 229.51 is better than MB 229.5 on paper, but you don't want to use 229.51 for long drains in a gasoline engine where fuel might have too much sulfur.
Anyone know?
2008 BMW M3 Sedan 6MT
Re: Known downsides to LSPI-oriented formulations? [Re: d00df00d] #4812395
07/12/18 03:45 PM
07/12/18 03:45 PM
Plano, TX
dparm Offline
dparm  Offline
Plano, TX
Might be worth looking into the second-gen Dexos stuff, as LSPI became a priority for them in this new cert. I've heard that sometimes magnesium is increased.
The new Mobil 1 ESP Formula 0w40 actually has a rather mediocre starting TBN of 8.5 despite being dexos2. I've not seen a VOA of this oil yet.
Also, previous discussion we had about it:
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/4203943/Re:_LSPI_w/Direct_Injection
2017 Chevrolet Corvette Grand Sport
Re: Known downsides to LSPI-oriented formulations? [Re: dparm] #4812455
07/12/18 04:55 PM
07/12/18 04:55 PM
Oakville, Ontario
Patman Offline
Global Moderator
Patman  Offline
Global Moderator
Oakville, Ontario
In a case like that, I don't think TBN needs to be a big priority, considering that oil is geared for high performance GM engines and the oil life monitors in those cars won't really let them go much beyond 7-8k and in a lot of cases people will be hitting the one year mark before that mileage, so a much greater number of people using this new oil will probably be changing it well before it even hits 5k.
At the same time, it's possible that even with this new oil having a lower TBN to start, it could have better TBN retention than other oils. After 5000 miles it's possible that it'll only drop from 8.5 to 5, while in that same time frame it's also possible that an oil with a starting TBN of 10 might drop like a stone and end up around 4 after 5k of service.
2018 Corvette, 9k, M1 ESP Formula 5w30 & NAPA Gold
2006 Civic EX Coupe, 149k, PUP 5w20 & Fram Ultra
2010 BMW 328i X-Drive,113k, GC 0w40 & Fram Ultra
Re: Known downsides to LSPI-oriented formulations? [Re: d00df00d] #4812480
07/12/18 05:15 PM
07/12/18 05:15 PM
Fredericksburg, VA
JAG Offline
JAG  Offline
Fredericksburg, VA
You don’t want good TBN retention. You want the bases to neutralize as much of the acids as possible and as quickly as possible. By laws of nature, this reduces the amount of available base...TBN goes down. You do want enough TBN but not due it to “retaining” it; you want it due to it starting at a high value for your OCI. You want TAN to increase as little as possible.
I don’t like Mg detergents because of the following paper: http://www.oil-lab.com/downloads/TBN-1.pdf
Re: Known downsides to LSPI-oriented formulations? [Re: d00df00d] #4812489
07/12/18 05:36 PM
07/12/18 05:36 PM
Western S.C.
CR94 Offline
CR94  Offline
Western S.C.
The biggest downside might be increased cost, for customers who didn't need to worry about LSPI in the first place.
2011 Toyota Prius now at 97K
Re: Known downsides to LSPI-oriented formulations? [Re: d00df00d] #4812496
07/12/18 05:52 PM
07/12/18 05:52 PM
NJ
buster Offline
buster  Offline
NJ
Higher corrosive bearing wear. Ideally, if GDI didn't come out, I believe the formulators would have preferred to stick with the with Ca. The new engines and emissions systems certainly pose challeges to formulators.
Re: Known downsides to LSPI-oriented formulations? [Re: buster] #4812528
07/12/18 06:29 PM
07/12/18 06:29 PM
PA
d00df00d Offline OP
d00df00d  Offline OP
PA
Yikes!
Are you saying this tends to be an effect of the additives that make up for the loss of Ca, or that it's a net effect of the overall formulation of the finished lube?
Re: Known downsides to LSPI-oriented formulations? [Re: d00df00d] #4812566
07/12/18 07:03 PM
07/12/18 07:03 PM
WA
OilUzer Offline
OilUzer  Offline
WA
Along the same line, I asked a question a while back regarding d1g2 oils ... My question/concern was if these oils (having more or less of some chemicals to combat lspi in DI engines) may not necessarily be the best choice for pfi engines ...
The reason I asked the question was because we have one DI car and all our other cars are all PFI.
The consensus (not many people chimed in) was "to use it (d1g2) with confidence" for pfi cars ...
Obviously I don't have the knowledge or any scientific data to go against the above recommendation, However my gut feeling says there is always a trade off and I have a hard time with "one size fits all" theory ... I am sure top guns will jump on my "gut feeling" vs. scientific data ... but what can I say, I am a little suspicious. lol
Re: Known downsides to LSPI-oriented formulations? [Re: d00df00d] #4812596
07/12/18 07:37 PM
07/12/18 07:37 PM
NJ
buster Offline
buster  Offline
NJ
Yikes!
I doubt it. There are probably ways around it. It’s what gives chemists and formulators job security. smile. Think about it though, almost all the SN+/dexos 2 oils are using some mg.
Re: Known downsides to LSPI-oriented formulations? [Re: CR94] #4812658
07/12/18 08:32 PM
07/12/18 08:32 PM
Plano, TX
dparm Offline
dparm  Offline
Plano, TX
Why would consumers not need to worry about LSPI? Are you saying that it's not something the average person needs to think about, or that it's not even happening?
Re: Known downsides to LSPI-oriented formulations? [Re: d00df00d] #4812673
07/12/18 08:39 PM
07/12/18 08:39 PM
WA
OilUzer Offline
OilUzer  Offline
WA
Isn't lspi a concern only for DI (Turbo? DI) engines?
If I don't have a DI, why should I accept the shortcomings (if any)?
Re: Known downsides to LSPI-oriented formulations? [Re: OilUzer] #4812682
07/12/18 08:43 PM
07/12/18 08:43 PM
PimTac Offline
PimTac  Offline
Are there shortcomings? That is conjecture on your part.
Cannot see signatures any longer so it doesn’t matter.
Re: Known downsides to LSPI-oriented formulations? [Re: dparm] #4812709
07/12/18 09:01 PM
07/12/18 09:01 PM
Western S.C.
CR94 Offline
CR94  Offline
Western S.C.
No, I'm saying LSPI is something consumers who won't be using the oil in engines vulnerable to LSPI don't need to worry about. They'll have to help pay for the changes, though.
Re: Known downsides to LSPI-oriented formulations? [Re: OilUzer] #4812711
07/12/18 09:02 PM
07/12/18 09:02 PM
PA
d00df00d Offline OP
d00df00d  Offline OP
PA
"Use it with confidence" just means it'll be fine. Which it's supposed to be, and likely will be. API didn't relax any of SN's requirements for SN Plus, so any SN Plus product will meet specs for API SN applications.
That's a different ballgame from what's best. If finding that is your goal, you're not looking for something that just meets the standards; you're looking for something that exceeds them by as much as your budget will allow.
I have to imagine it's easier to exceed SN specs if you don't have to worry about LSPI. If that turns out to be true, then it might be more likely that the "best" oil for a PFI application is more likely to be SN than SN Plus.
Unfortunately, that kind of vague suspicion is about as far as you can go, because no formulator is going to publish more than a tidbit or two about the margin by which their products beat any given standard. It's good enough for my purposes, which is why I asked this question -- but no way on earth is it a good way to find the "best" oil for any given application.
Re: Known downsides to LSPI-oriented formulations? [Re: PimTac] #4812812
07/12/18 11:43 PM
07/12/18 11:43 PM
Canada
nap Offline
nap  Offline
Canada
Are you suggesting that one should not ask a question for which he doesn’t already have the answer? That is [censored] on your part.
Page 1 of 3 1 2 3
