0w20 vs 0/5w30 (yes I know another viscosity thread)
by SnowDrifter. 02/15/19 11:42 PM
skid plate
by mobilaltima. 02/15/19 10:32 PM
The Last Gladiators (French)
by Marco620. 02/15/19 08:54 PM
Rural King 5W30 Citgo Superguard blend 5qt jug $9.91
by tenderloin. 02/15/19 08:34 PM
Meet Watson!
by spasm3. 02/15/19 08:16 PM
Tie Rod and Ball Jt. Recommendations/Advi
ce
by coopns. 02/15/19 08:11 PM
Uninstall Avast
by willbur. 02/15/19 06:58 PM
Need a new toliet
by JLawrence08648. 02/15/19 06:55 PM
Help Me Choose A Smartphone
by Warstud. 02/15/19 05:29 PM
Source for Torque Wrench Calibration?
by SubLGT. 02/15/19 05:09 PM
Transmission Scraping Noise
by bprat318. 02/15/19 04:59 PM
Ok to mix gear oil viscosities?
by zuluplus30. 02/15/19 04:11 PM
Tore Wheel Cylinder Boot on 2007 Tacoma
by john_pifer. 02/15/19 04:10 PM
Spotify to home theater
by Malo83. 02/15/19 03:19 PM
6.0 powerstroke for a forever truck
by FLORIDA. 02/15/19 02:55 PM
Atwoods PYB 5QT jug $7.99 after rebate !!
by GMguy84. 02/15/19 02:52 PM
Torque Wrench Accuracy
by Kjmack. 02/15/19 12:57 PM
Thoughts on pennzoil 0w30 lx
by 750HMF. 02/15/19 12:26 PM
3dfever, Mahmoud, Happycamper, jftcat, TexasForever
67246 Registered Users
42 registered members (1WildPig, 750HMF, Bjornviken, Aero540T, 3dfever, 2strokeNorthstar, 3 invisible), 628 guests, and 61 spiders.
Topics298,255
Posts4,988,178
Members67,246
Most Online2,474
Feb 10th, 2019
Do poly bushings need to be torqued loaded? #4812339
07/12/18 01:52 PM
07/12/18 01:52 PM
Anaheim, CA
zorobabel Offline OP
Anaheim, CA
I've been trying to figure out how to torque lower control arm bushings with the suspension loaded (clearance issues), but do polyurethane bushings even need to be torqued with the suspension loaded?
1997 Maxima 195k, Castrol GTX Synblend 5W-30, FL400S
2004 Corolla 196k, VWB 5w20 + SSS 10w40, MGL4967
Re: Do poly bushings need to be torqued loaded? [Re: zorobabel] #4812378
07/12/18 02:31 PM
07/12/18 02:31 PM
Occupied Virginia
Bottom_Feeder Offline
Occupied Virginia
It shouldn't need to since the lubed urethane bushing rides on the inner sleeve instead of the sleeve being bonded to the rubber bushing.
That said, what do the instructions say?
Re: Do poly bushings need to be torqued loaded? [Re: Bottom_Feeder] #4812400
07/12/18 02:48 PM
07/12/18 02:48 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
^ This.
Re: Do poly bushings need to be torqued loaded? [Re: zorobabel] #4812514
07/12/18 05:10 PM
07/12/18 05:10 PM
Anaheim, CA
Anaheim, CA
Thanks, it is what made sense to me, but figured I'd ask. Now I have to search for the instructions.
Re: Do poly bushings need to be torqued loaded? [Re: zorobabel] #4812520
07/12/18 05:17 PM
07/12/18 05:17 PM
Santa Barbara, CA
bdcardinal Offline
bdcardinal  Offline
Santa Barbara, CA
Normally yes they do. Spherical rod ends do not.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: Do poly bushings need to be torqued loaded? [Re: bdcardinal] #4812539
07/12/18 05:43 PM
07/12/18 05:43 PM
Trav Offline
Trav  Offline
?. If they are just a static bushing in with a sleeve through the middle why would they need to be torqued in any position, there is no bonding to the shell hence not stress on the material.
Re: Do poly bushings need to be torqued loaded? [Re: zorobabel] #4813068
07/13/18 09:47 AM
07/13/18 09:47 AM
Anaheim, CA
Anaheim, CA
These are the instructions, and this is what it looks like:
Re: Do poly bushings need to be torqued loaded? [Re: zorobabel] #4813298
07/13/18 02:17 PM
07/13/18 02:17 PM
Trav Offline
Trav  Offline
Torquing that with the weight of the car on it, off it, upside down, right side up or on its back isn't going to make a lick of difference. No bonded to metal material = no stress or tearing that simple.
Re: Do poly bushings need to be torqued loaded? [Re: zorobabel] #4821265
07/23/18 10:58 AM
07/23/18 10:58 AM
Anaheim, CA
Anaheim, CA
I've changed the bushings this Saturday, I torqued the pivot arm off the car. Surprisingly this one (driver side) was easy to pivot after torqueing, I remember having to loosen the nut to move it (under the car though) when installing the passenger side.
Thanks for the replies!
Moderated by  ekpolk
