comfortable seats
by redhat. 03/25/19 10:29 AM
walmart evinrude tcw-3 clearance score
by 1978elcamino. 03/25/19 10:15 AM
Mixing SN/d1G1 with SN+/d1G2?
by doyall. 03/25/19 10:14 AM
Best 2nd Phone Number App ?
by LoneRanger. 03/25/19 09:56 AM
Crud! Wix jacking up prices again! :(
by SubieRubyRoo. 03/25/19 09:53 AM
Interior "quick detailer"
by Redright9. 03/25/19 08:21 AM
Seafoam For Last 100 Miles Before Oil Change ?
by ChrisD46. 03/25/19 07:56 AM
WIX 57151XP factory filled with synthetic oil
by Donald. 03/25/19 06:58 AM
BMW Buying Guide: Every Model, Explained
by wemay. 03/25/19 05:43 AM
Double Din Android Auto Advice
by JeffKeryk. 03/24/19 11:25 PM
VW mk5 a/c intermittently works
by ram_man. 03/24/19 11:01 PM
DIY alignment done right?
by tookien. 03/24/19 10:03 PM
Cell phone privacy question
by loneryder. 03/24/19 10:00 PM
Ride quality between 45 and 35 sidewall
by bowlofturtle. 03/24/19 09:23 PM
FRAM TG 7317 - 12K miles opened
by crazy_raccoon. 03/24/19 09:01 PM
2014-2017 Toyota Corolla CVT Quiet Recall
by StevieC. 03/24/19 08:11 PM
sonusfaber, Rollo, Drifted, Jcar516, gregjr7
67614 Registered Users
91 registered members (1978elcamino, anndel, 53' Stude, 2015_PSD, AdditiveOCD, 7 invisible), 2,055 guests, and 57 spiders.
Topics286,392
Posts4,907,430
Members67,614
Most Online2,967
Mar 10th, 2019
Installing bathroom cabinets- finishing #4812112
07/12/18 10:27 AM
07/12/18 10:27 AM
FLORIDA
Walmill Offline OP
Walmill  Offline OP
FLORIDA
This is a question that stems partly from laziness, saving waste, and saving time.
I have some unfinished cabinets that I am going to install in the bathroom. Is it necessary, important, or even recommended to finish the back/sides/inside of cabinets? This is not for aesthetics but for potential protection. Can't seem to obtain an answer on google.
1994 f150, 4.9L, E4OD, RWD. 194XXX miles
2016 Hyundai elantra value edition 21000 miles
Re: Installing bathroom cabinets- finishing [Re: Walmill] #4812141
07/12/18 10:51 AM
07/12/18 10:51 AM
Chicago,IL,USA
pandus13 Offline
pandus13  Offline
Chicago,IL,USA
[off-topic]
Have your exhaust fan wired in parallel to a humidistat + on/off switch.
You control humidity, you have less expanse/mold/mildew problems...
[/off-topic]
16 Golf SportWagen
13 Mazda5
08 Yaris
04 Elantra
95 accent
95 mystique
97 concorde
Re: Installing bathroom cabinets- finishing [Re: Walmill] #4812164
07/12/18 11:06 AM
07/12/18 11:06 AM
California
Vuflanovsky Online content
Vuflanovsky  Online Content
California
You might have to clarify their location. My bathroom could have cabinets that are subject to steam/humidity or ones that are outside the toilet/shower area and separated by a door.
Re: Installing bathroom cabinets- finishing [Re: pandus13] #4812168
07/12/18 11:09 AM
07/12/18 11:09 AM
VW Fanboy Island
maxdustington Offline
VW Fanboy Island
Originally Posted By: pandus13
[off-topic]
[/off-topic]
They have fans now that are moisture sensing, and if you are going to install a switch make sure it has timer functions. Honestly, bathroom mold problems seem to be related to poor construction and lack of waterproofing in shower/tub areas. Cold basement three piece baths without windows compounds this.
It depends on the material. MDF is very sensitive to moisture, if it gets scratched it will swell in the area and look bad. Melamine seems to be relatively water resistant, not as bad as MDF.
A coat of primer on all exterior sides is probably enough. I would do a decent job painting the inside because you are going to be looking at it all the time.
03 Jetta AWP/09A 205k kms
Edge 0W40 + Mann 719/30
Re: Installing bathroom cabinets- finishing [Re: Walmill] #4812193
07/12/18 11:31 AM
07/12/18 11:31 AM
FLORIDA
Walmill Offline OP
Walmill  Offline OP
FLORIDA
-Good idea on the exhaust fan.
-Cabinets are in the bathroom with a shower nearby. Three cabinets, two sinks. Approx 3 feet from shower. One cabinet against exterior wall.
-Florida, tend to get rather humid.
-Cabinets are solid wood, don't know what wood just off the top of my head. Backing cover about 1/8 inch engineered kind of product, name escapes me right now. Counter to be solid stone.
-1990ish house, not as weather/energy efficient as a modern house, but not a sieve either. Have had occasionaly mildew here and there, but no widespread problems.
Re: Installing bathroom cabinets- finishing [Re: Walmill] #4812201
07/12/18 11:40 AM
07/12/18 11:40 AM
Chicago,IL,USA
pandus13 Offline
pandus13  Offline
Chicago,IL,USA
Wallmill/OP,
General finishes makes some gel stain. it can be used as wipe-on regular stain or just plain painted as an oil paint(self level), then some poly/varnish on top.
Also , put some vinyl sheet on the bottom of the cabinets, rolled around on 3 sides (left, right and back) to protect from the spills or liquid accumulation.
I think homedepot/lowes has some cabinet protectors for this.
Also for the exhaust fan, make sure it has enough CFM/flow for the bathroom's area. Panasonic fans have good name in the industry.
Re: MaxDustington: pretty good knowledge for a young guy. Keep it going, be a PRO, and you will retire on your own terms. Hat off!
16 Golf SportWagen
13 Mazda5
08 Yaris
04 Elantra
95 accent
95 mystique
97 concorde
Re: Installing bathroom cabinets- finishing [Re: Walmill] #4812264
07/12/18 01:14 PM
07/12/18 01:14 PM
NM, USA
pkunk Offline
pkunk  Offline
NM, USA
Wood, of any kind, once finished on one side should be finished on the other side as well as any exposed edges. This is to prevent moisture from entering and causing the panel to warp.
In the case of a cabinet, it also makes it easier to clean.
8200 ft elevation in the Sangre de Cristos
2008 Mini Cooper Clubman (toad)
2000 Mercedes ML320
1994 Dodge 2500 Cummins
1999 Ford F53 V10 Coachman Motorhome 34ft
Re: Installing bathroom cabinets- finishing [Re: Walmill] #4812294
07/12/18 01:42 PM
07/12/18 01:42 PM
wi
dave123 Offline
dave123  Offline
wi
Wood finishing for 25+ years and supply OEM cabint and custom builders in bathroom answer is yes yes yes including bottoms and tops of entrance door if also doin Conversion Varnish is recommended for this app.
Re: Installing bathroom cabinets- finishing [Re: Walmill] #4812342
07/12/18 02:56 PM
07/12/18 02:56 PM
The land of USA-made Subies!
SubieRubyRoo Offline
What about on wood that has dried for 20+ years? My friend gave me some black walnut planks that were done with the bark intact (that live-edge stuff) and it dried in barn for over 20 years. I ran it through the planer a couple times to flatten it out, and my wife wants me to turn it into a shelf. Do I still need to worry about warping after the long drying times and planing afterwards, and what should I use to leave the most natural finish? Do I need to worry about sealing the bark edge?
Re: Installing bathroom cabinets- finishing [Re: SubieRubyRoo] #4812418
07/12/18 04:00 PM
07/12/18 04:00 PM
wi
dave123 Offline
dave123  Offline
wi
if it was my own because of the unique nature of the woodI have materials not available to general diy guy but I would give a recommendation or look into Tung oil for this job for the diy person.
