Questions on upgrading to higher-output alternator
by ltslimjim. 02/22/19 07:42 PM
First time ever didnt do my own oil change
by dbias. 02/22/19 07:12 PM
Toyota 3.4L 5VZ-FE Crank Sprocket
by The Critic. 02/22/19 07:08 PM
Weird Noise After Shutdown - 2018 Giulia
by RamFan. 02/22/19 07:01 PM
2019 Honda Passport
by mailman74. 02/22/19 06:56 PM
Who is censoring me? public wifi
by Vern_in_IL. 02/22/19 06:53 PM
Serpentine Belt Tool
by Gebo. 02/22/19 06:49 PM
SUNOCO Global Full Synthetic ATF
by Ursatdx. 02/22/19 06:46 PM
No more Meijer batteries!!
by bullwinkle. 02/22/19 06:24 PM
Valvoline premium blue tsc
by Dudemanmaximus. 02/22/19 05:38 PM
Echo won’t run on high speed
by artbuc. 02/22/19 05:36 PM
Roadside Assistance memberships
by paulri. 02/22/19 05:35 PM
Remembering Steve Irwin
by 2015_PSD. 02/22/19 05:27 PM
Transmission Cooler
by rcbob. 02/22/19 04:59 PM
Amazon: PP Euro 5W-40 $38 for pack of 6 quarts
by 1JZ_E46. 02/22/19 04:56 PM
89 Wrangler oil recommendations
by Chris142. 02/22/19 04:55 PM
New batteries failing on the shelf
by Chris142. 02/22/19 04:53 PM
Schaeffer’s 5w30 LT1
by s2krunner. 02/22/19 04:48 PM
Lexus LS430 P0756
by Kibitoshin. 02/22/19 04:41 PM
PUP is now SN + ??? Formulation change??
by Lazydan. 02/22/19 04:17 PM
HwyFlierKev, McGruder, SirDave, DieselJoel, jcthorne
67317 Registered Users
106 registered members (69GTX, 69Torino, 53' Stude, 2009Edge, 2015_PSD, 12 invisible), 1,660 guests, and 53 spiders.
Topics284,686
Posts4,875,018
Members67,317
Most Online2,548
Feb 16th, 2019
Freezer light bulb stuck solid ? #4812030
07/12/18 07:35 AM
07/12/18 07:35 AM
Joplin
Cressida Online content OP
Cressida  Online Content OP
Joplin
The light bulb in the freezer section of my old refrigerator has gone out and cannot be turned at all. I've tried using a leather glove so I've got the grip but any more force will surely break it off. Before I make things worse, anyone have any tricks to get the bulb to turn out?
Don't really want to shut the unit down if I can avoid it and don't know if PB Blaster would even help or is appropriate because of all the plastic.
Re: Freezer light bulb stuck solid ? [Re: Cressida] #4812048
07/12/18 07:53 AM
07/12/18 07:53 AM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
Use the glove & unscrew it . Might try to move it slightly back and forth to try to loosen it up .
But , if it breaks , it breaks .
Then unplug the appliance and use needle nose pliers to remove the lamp base from the socket .
Wyr
God bless
Re: Freezer light bulb stuck solid ? [Re: Cressida] #4812051
07/12/18 07:55 AM
07/12/18 07:55 AM
OH
SatinSilver Offline
SatinSilver  Offline
OH
Maybe use a hairdryer on the socket for five minutes to warm the area a little bit. High heat and fan speed. Then have a go at it. Turn the thermostat to the warmest setting while you're working on it.
Re: Freezer light bulb stuck solid ? [Re: Cressida] #4812052
07/12/18 07:56 AM
07/12/18 07:56 AM
Illinois
SHOZ Offline
SHOZ  Offline
Illinois
I use to change a lot of HID bulbs and they would get stuck. Usually a shot of lube into the bulb/socket threads would free it up quickly.
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
Re: Freezer light bulb stuck solid ? [Re: Cressida] #4812145
07/12/18 09:53 AM
07/12/18 09:53 AM
New England
gathermewool Offline
New England
Can it be twisted clockwise, in the tightening direction?
'14 Forester XT FA20DIT (Cobb Stage 1)
Edge 0W-40 + FU filter (64,774 miles)
'15 Legacy FB25 (OEM Stage, uh, neg. 7?)
Edge 0W-20 + FU filter (40,803 miles)
Re: Freezer light bulb stuck solid ? [Re: Cressida] #4812175
07/12/18 10:13 AM
07/12/18 10:13 AM
1/2 hr N.E. of Detroit
Triple_Se7en Offline
Use electrical spray lube.
CRC- 2-26 Spray Lubricant
Put a rag underneath the light when spraying, to avoid over-spray.
2019 Hyundai SantaFe 2.4 factory fill / QS 5w20 conv. / Mahle OEM oil filter
04 Chev Colorado 3.5 QS / Valv syn 5w30 blend K&N filter
03 Chev Malibu 3.1 QS / Valv Syn 5w30 blend Fram EG filter
Re: Freezer light bulb stuck solid ? [Re: Cressida] #4812226
07/12/18 11:23 AM
07/12/18 11:23 AM
PA
123Saab Offline
123Saab  Offline
PA
Any chance it's a bayonet mount? Push in and turn 1/4 anti-clockwise.
Anything can happen
The tallest towers be overturned
Those in high places be daunted
Those overlooked regarded
- Seamus Heaney
Re: Freezer light bulb stuck solid ? [Re: Cressida] #4812240
07/12/18 11:39 AM
07/12/18 11:39 AM
Georgia
MParr Offline
MParr  Offline
Georgia
When you get it out, put a light coat of Vaseline on the base of the new bulb.
2013 KIA Optima EX 2.4L. Now: Unknown &OE filter
2017 Ford Escape SE 2.0T Now: NAPA Synthetic 5W30 & NAPA Gold 1348
Moderated by  ekpolk
