Older PENNZOIL ATF on sale vs newer not on sale
Kuala Lumpur ,Malaysia
So I head over to ace hardware and found a good deal on old stock of copyright 2007 Pennzoil ATF DEX II and III compatible.
My car is as toyota from 89, and it specifies ATF for the power steering.
I have a feeling the mechanic used Poswer Steering fluid instead of ATF, so I was thinking of buying this ATF on sale.
or should i use this newer formulation not on sale ?
Mercon v seems to be the higher spec when it comes to these dex/merc fluids. The older bottle lists it so I would go with that one, especially if it's cheaper. But really your car won't know the difference between the two.
