WM Valvoline Full Syn Modern Eng Clearance
by Spartanfool. 03/22/19 04:22 PM
Need Moly basic training
by Bill_W. 03/22/19 04:03 PM
P0420 code goes away in warmer weather
by 2010Civic. 03/22/19 03:54 PM
Customer declined new belt
by Chris142. 03/22/19 03:13 PM
How to deep clean back of wheels?
by qdeezie. 03/22/19 02:51 PM
RK oil sale T4 15w40
by 1978elcamino. 03/22/19 01:57 PM
Hello and goodbye to my old job
by Motorking. 03/22/19 01:52 PM
Ichiro Suzuki retiring from baseball.
by PimTac. 03/22/19 12:40 PM
91 Caprice door wont fully latch...
by columnshift. 03/22/19 12:30 PM
Denso Platinum TT for 2004 Corolla?
by zorobabel. 03/22/19 11:16 AM
What should I run in the 09 rabbit trans
by ram_man. 03/22/19 10:32 AM
Chevy express van for towing
by Fitter30. 03/22/19 10:24 AM
Mobil 1 Filter Clearance - Wal Mart
by sdude2k2000. 03/22/19 10:01 AM
STP VI trans fluid
by acme. 03/22/19 09:37 AM
Increased oil capacity = lower pil temps ?
by SavagePatch. 03/22/19 09:15 AM
2007 Corolla - P0441 and P0455 codes
by Bama. 03/22/19 08:44 AM
Oldmoparguy1
by cjcride. 03/22/19 08:23 AM
Check engine light
by rtrdad. 03/22/19 08:21 AM
Super Tech 5W30 Synthetic With GDI Engine ?
by ChrisD46. 03/22/19 07:00 AM
Skendread, NGK, Thomas1, RE_Vision, JamesMc
67587 Registered Users
97 registered members (53' Stude, 240_Ed, 2010Civic, 2015_PSD, 8 invisible), 2,221 guests, and 49 spiders.
Topics286,244
Posts4,905,134
Members67,587
Most Online2,967
Mar 10th, 2019
Chevy HHR intermittent power steering #4811849
07/11/18 10:18 PM
07/11/18 10:18 PM
St. Charles County, Missouri
csandste Offline OP
csandste  Offline OP
Just found out my daughter's HHR has off again, on again power steering. I've read everything from people replacing modules and motors and spending thousands to no avail, to someone who said he fixed everything with a different fuse with slightly longer contacts. There's some indication that GM has recall for same motor on 'Cobalt and 'Bu but nothing on HHR. Had two failures on my 05 Maxx but think I was fully reimbursed.
Lots of old posts to this problem, but a lot of comments are eight years old or older. Think car has about 160K on it and she purchased a year ago.
2017 Kia Soul Plus-- Super Tech Synthetic 5w30 59000 miles
Re: Chevy HHR intermittent power steering [Re: csandste] #4811867
07/11/18 11:06 PM
07/11/18 11:06 PM
Fort Worth, Texas
clinebarger Offline
clinebarger  Offline
Fort Worth, Texas
I would really like the history codes stored in the steering module. It sounds like "Motor Over-Amp/Overload protection"
*Make sure that she is not putting the steering in a bind (Against a curb/steering stop & whatnot)
*Check for binding steering components
*Check the battery connections, The steering motor draws a good amount of current
*A simple "drag test" will tell if main fuse is not making good contact, I make them out of old fuses.
2001 Chevy Camaro L92/4L80E
Re: Chevy HHR intermittent power steering [Re: csandste] #4811908
07/12/18 01:34 AM
07/12/18 01:34 AM
Balearic Islands , Spain
FordCapriDriver Offline
I don't know but i've read those things are moneypits.
1975 Ford Capri II Ghia 3000 V6, - Shell Helix HX3 20W-50 w/ 20% Rimula R4X 15W-40 HDEO.
1988 Ford Escort XR3i Cabrio, - Shell Rimula R4X 15W-40, w/ 30% Helix 3 20W-50.
Re: Chevy HHR intermittent power steering [Re: csandste] #4812090
07/12/18 09:48 AM
07/12/18 09:48 AM
MN
HeritageHighRoof Offline
MN
If by intermittent you mean stiff spots when turning and the wheel not returning to center on itís own, Itís probably the lower u-joint just above the rack on your steering shaft. I just had this issue and initially thought it was the motor. I got the GM replacement steering shaft ($150) since Iíve heard some bad reviews on the aftermarket ones. Was a pretty easy replacement with the LF wheel removed.
Re: Chevy HHR intermittent power steering [Re: HeritageHighRoof] #4812153
07/12/18 10:58 AM
07/12/18 10:58 AM
csandste Offline OP
csandste  Offline OP
By intermittent I mean-- power steering switches on and off electrically-- I have a grand daughter who will be getting her license this year and having steering effort suddenly increase by 1000% while she's making a turn doesn't sound safe to me. Had the same thing with my Maxx and steering the car with no power steering is more than disconcerting. Intermittent-- to me--means on and off.
With the Maxx, (from ten year old memory) the entire steering column, including the motor, had to be replaced. That was constant. Seems like I had later trouble with intermittent cut outs that did not require replacement of another column. Think I also was reimbursed for my original $900 outlay.
