Did i make a mistake? Hilux 3.0 d4dhello
by Anton93. 03/22/19 05:52 PM
WM Valvoline Full Syn Modern Eng Clearance
by Spartanfool. 03/22/19 04:22 PM
Need Moly basic training
by Bill_W. 03/22/19 04:03 PM
P0420 code goes away in warmer weather
by 2010Civic. 03/22/19 03:54 PM
Customer declined new belt
by Chris142. 03/22/19 03:13 PM
How to deep clean back of wheels?
by qdeezie. 03/22/19 02:51 PM
RK oil sale T4 15w40
by 1978elcamino. 03/22/19 01:57 PM
Hello and goodbye to my old job
by Motorking. 03/22/19 01:52 PM
Ichiro Suzuki retiring from baseball.
by PimTac. 03/22/19 12:40 PM
91 Caprice door wont fully latch...
by columnshift. 03/22/19 12:30 PM
Denso Platinum TT for 2004 Corolla?
by zorobabel. 03/22/19 11:16 AM
What should I run in the 09 rabbit trans
by ram_man. 03/22/19 10:32 AM
Chevy express van for towing
by Fitter30. 03/22/19 10:24 AM
Mobil 1 Filter Clearance - Wal Mart
by sdude2k2000. 03/22/19 10:01 AM
STP VI trans fluid
by acme. 03/22/19 09:37 AM
Increased oil capacity = lower pil temps ?
by SavagePatch. 03/22/19 09:15 AM
2007 Corolla - P0441 and P0455 codes
by Bama. 03/22/19 08:44 AM
Oldmoparguy1
by cjcride. 03/22/19 08:23 AM
Check engine light
by rtrdad. 03/22/19 08:21 AM
Skendread, NGK, Thomas1, RE_Vision, JamesMc
67587 Registered Users
113 registered members (Anton93, 2010Civic, 2015_PSD, AlanGonzales, Aichiguy, 12 invisible), 2,043 guests, and 52 spiders.
Topics286,245
Posts4,905,177
Members67,587
Most Online2,967
Mar 10th, 2019
2 stroke oil for Yamaha PWC #4811652
07/11/18 06:47 PM
07/11/18 06:47 PM
Canada
seanf Offline OP
seanf  Offline OP
Canada
I've got a 97 Yamaha Waverunner GP760 2 stroke with about 140 hours on it. Is there any specific oil I should be running besides a TCW3 rated oil? I ran some Mystic JT4 TCW3 syn blend and currently have run a gallon of Phillips 66 Synjex TCW3 thru it.
I need to buy more oil but I'm uncertain if there are any specific brands I should look at? Keep in mind I'm in Canada and I'm basically stuck with whatever Canadian Tire sells or my work place which is a Phillips 66 dealer so I can get injex, injex pro and synjex. Amsoils out of the question IMO since they say to mix at 100:1 and I've got the factory oil injection which mixes 50:1 so I'd be throwing my money out the window @ $18.99L CAD for the amsoil. I always warm the ski up and baby it a bit before going riding but I ride it hard and it sees lots of WOT time and hole shots.
Thanks
Re: 2 stroke oil for Yamaha PWC [Re: seanf] #4811674
07/11/18 07:14 PM
07/11/18 07:14 PM
texas
danez_yoda Offline
danez_yoda  Offline
texas
Any quality tcw3 oil should be fine.
Re: 2 stroke oil for Yamaha PWC [Re: seanf] #4811742
07/11/18 08:32 PM
07/11/18 08:32 PM
Richmond, VA
Barkleymut Offline
Barkleymut  Offline
Richmond, VA
i used to own that same year and model. If walmarts there carry the pennzoil 2stroke oil, I would use it. Cheap and did fine in mine.
09 Vue(95K) 2.4 4spd AT -PU 5w30 / 09 Flex(52K)3.5L PU / Moms car 04 Pilot(105K) 5w20 PP + Puro
Re: 2 stroke oil for Yamaha PWC [Re: seanf] #4811753
07/11/18 08:45 PM
07/11/18 08:45 PM
Port Orange, Florida
Panzerman Offline
Panzerman  Offline
I never owned a jet ski or water powercraft but I bought some Quicksilver PWC oil on clearance because it is TC rated. I am thinking TCW3 would not be the right oil for a high performance watercraft.
They even warn about using a TCW3 on the bottle in power water craft. Might want to research it.
I have found TCW3 oil leaves a hard carbon in air cooled two strokes. Again I never owned a PWC, just reading the bottle and why I bought it. TC rated.
2006 Dodge Ram 2500 Hemi 4x4
2016 Dodge Challenger Scat Pack
Re: 2 stroke oil for Yamaha PWC [Re: seanf] #4811764
07/11/18 08:56 PM
07/11/18 08:56 PM
South Florida
bubbatime Offline
bubbatime  Offline
South Florida
A good synthetic oil should keep everything cleaner, which isnt a bad thing.
17 Chrysler Pacifica Edge Syn 5W30
13 Yamaha XT250 Valv MC 10W40
10 Acura TSX 2.4 SuperTech Syn 5W20
06 GMC Sierra SuperTech 10W30
Re: 2 stroke oil for Yamaha PWC [Re: seanf] #4811803
07/11/18 09:17 PM
07/11/18 09:17 PM
Middlesex County CT
simple_gifts Offline
Middlesex County CT
In my local Walmart Pennzoil XLF for older 'seasoned' engines is $4/gal cheaper than the regular Pennzoil 2 stroke. Just an FYI for the OP'r
2004 Prius; 110K; ASL
2007 Yaris 86K 0w-40 Castrol
2006 B2300;132K;ALM
Was driving an ox cart; Now on the USS Enterprise
Re: 2 stroke oil for Yamaha PWC [Re: seanf] #4811914
07/12/18 02:03 AM
07/12/18 02:03 AM
Southwestern Alberta
Warlord Offline
Warlord  Offline
You can get Mystic Sea and Snow at any Canadian Tire. Iíd use that. Especially if you find it on sale.
07 GMC Canyon - 204km
01 Saturn SL2 - 240km
Re: 2 stroke oil for Yamaha PWC [Re: Warlord] #4811970
07/12/18 06:23 AM
07/12/18 06:23 AM
Canada
seanf Offline OP
seanf  Offline OP
Canada
So I found an owner's manual, since I don't have power valves I'm spec'd to use tcw3 oil. I'm not sure if running a TC rated oil like sea and snow will hurt anything or not. I have run the mystik jt4 outboard tcw3 oil tho. It's $28 cad for 4L.
Re: 2 stroke oil for Yamaha PWC [Re: seanf] #4812065
07/12/18 09:09 AM
07/12/18 09:09 AM
Midwest, Illinois
beanoil Offline
beanoil  Offline
Midwest, Illinois
The P66 Injex you ran is a great oil.
Shell Nautilus would be my second choice.
beanoil: Tough under heat, real dirty afterwards.
Re: 2 stroke oil for Yamaha PWC [Re: seanf] #4812200
07/12/18 11:39 AM
07/12/18 11:39 AM
Warlord Offline
Warlord  Offline
Regarding sea and snow I apologize for being careless. I had never actually looked into it I just assumed that it would be tcw3 as itís marketed for snowmobiles and PWCs. How bizarre itís meant for air cooled sleds and watercraft. I imagine those are fairly rare nowadays.
No powervalves at least means a super expensive synthetic isnít really necessary. If you have a bass pro nearby you can get pennzoil there. Otherwise have you considered shell advance snowmobile? Itís tcw3 and I used a few litres of it in outboards with no complaints. Not sure it would be any better than the mystic outboard though.
Iím curious to know what you go with cause Iím thinking of picking up a pwc to do some bombing around when itís too hot to fish.
Re: 2 stroke oil for Yamaha PWC [Re: seanf] #4813259
07/13/18 02:49 PM
07/13/18 02:49 PM
Warlord Offline
Warlord  Offline
FYI if you are still looking my local Walmart has 4 liter jugs of Castrol super snowmobile which is tcw3 rated for 11 bucks. 2.75 a liter! Iíd buy it all if I didnít already have 100 liters of random 2 stroke oil in the garage.
Re: 2 stroke oil for Yamaha PWC [Re: Panzerman] #4816275
07/17/18 10:55 AM
07/17/18 10:55 AM
Canada
seanf Offline OP
seanf  Offline OP
Canada
So I decided to stick with the Synjex. $45cad a gallon after tax. I'd rather pay a bit more and run a very good oil and hopefully not blow it up. Last jetski I bought I had to rebuild the engine 2 months after I got it.
In regards to TC vs tcw3 my googling tells me that seadoos with rotary valves and power valved pwc are probably going to require the TC rated oil where as my 760 and 640cc Artic cat tigershark are standard 2 strokes and need tcw3 oil. Someone correct me if I'm wrong but the literature I have for these tell me tcw3 or the manufacturer branded oils.
Re: 2 stroke oil for Yamaha PWC [Re: seanf] #4821483
07/23/18 03:52 PM
07/23/18 03:52 PM
Southern Middle Tennesee
Arctic388 Offline
Arctic388  Offline
that engine is spec'd for TCW3 so anything you run will be fine. it does not have power valves or rave valves. I ran the pennzoil Syn in mine until i switched to AMSOIL Interceptor but that was because i also had a Seadoo with rave valves and it was what i ran in it so i ran it in both for simplicity.
make sure the carbs are adjusted correctly and clean and that thing will last a long time no matter what 2 stroke oil is used.
2015 Sierra Z71
1999 Malibu
1996 Tahoe 4x4
2015 Seadoo GTI SE 155 Limited
2017 Seadoo GTI SE 130
1998 Yamaha XL760
1996 Seadoo GTX
2005 Yamaha Grizzly 660
https://www.youtube.com/user/Arctic388/videos
Re: 2 stroke oil for Yamaha PWC [Re: seanf] #4844351
08/19/18 08:57 AM
08/19/18 08:57 AM
Canada
seanf Offline OP
seanf  Offline OP
Canada
So update.
I've run about a gallon and a half of the Phillips Synjex thru my machine this season so far. Still over 140 psi comp in each cyl @ 150hrs, plugs look a bit oily but not too bad, the PTO plug is a bit darker, maybe I should tweak the high speed jet on the rear carb but I'll probably just leave it as I GPS 50mph on the water. From what I can see in the hull this things all original with no bolts having tool marks so I'm confident this is the original engine, carbs work great.
Re: 2 stroke oil for Yamaha PWC [Re: seanf] #4849605
08/24/18 10:53 AM
08/24/18 10:53 AM
Midwest, Illinois
beanoil Offline
beanoil  Offline
Midwest, Illinois
Synjex is good stuff.
It was the starting point for one of the best 2T oils ever, XamaX.
