WM Valvoline Full Syn Modern Eng Clearance
by Spartanfool. 03/22/19 04:22 PM
Need Moly basic training
by Bill_W. 03/22/19 04:03 PM
P0420 code goes away in warmer weather
by 2010Civic. 03/22/19 03:54 PM
Customer declined new belt
by Chris142. 03/22/19 03:13 PM
How to deep clean back of wheels?
by qdeezie. 03/22/19 02:51 PM
RK oil sale T4 15w40
by 1978elcamino. 03/22/19 01:57 PM
Hello and goodbye to my old job
by Motorking. 03/22/19 01:52 PM
Ichiro Suzuki retiring from baseball.
by PimTac. 03/22/19 12:40 PM
91 Caprice door wont fully latch...
by columnshift. 03/22/19 12:30 PM
Denso Platinum TT for 2004 Corolla?
by zorobabel. 03/22/19 11:16 AM
What should I run in the 09 rabbit trans
by ram_man. 03/22/19 10:32 AM
Chevy express van for towing
by Fitter30. 03/22/19 10:24 AM
Mobil 1 Filter Clearance - Wal Mart
by sdude2k2000. 03/22/19 10:01 AM
STP VI trans fluid
by acme. 03/22/19 09:37 AM
Increased oil capacity = lower pil temps ?
by SavagePatch. 03/22/19 09:15 AM
2007 Corolla - P0441 and P0455 codes
by Bama. 03/22/19 08:44 AM
Oldmoparguy1
by cjcride. 03/22/19 08:23 AM
Check engine light
by rtrdad. 03/22/19 08:21 AM
Super Tech 5W30 Synthetic With GDI Engine ?
by ChrisD46. 03/22/19 07:00 AM
Skendread, NGK, Thomas1, RE_Vision, JamesMc
67587 Registered Users
106 registered members (2015_PSD, 2K2AcuraTL, 14Accent, 92saturnsl2, 53' Stude, 240_Ed, 11 invisible), 2,081 guests, and 50 spiders.
Topics286,244
Posts4,905,150
Members67,587
Most Online2,967
Mar 10th, 2019
Throttle Body #4811610
07/11/18 05:52 PM
07/11/18 05:52 PM
Athens, GA GO DAWGS
dawgn86 Offline OP
dawgn86  Offline OP
Athens, GA GO DAWGS
I have two Nissans with the VQ40 v6 engine; an 08 and 06 year model. I just cleaned the MAF sensor and wanted to clean the throttle body until I read up on it. Is there a way to avoid the idle air relearn procedure? I dont want to have to take it in to the Nissan dealer.
I also have a 2013 Toyota Tacoma with a 4cyl engine. Seems it doesnt have to do the pedal dance to relearn normal idle rpms.
2006 Nissan Pathfinder Mobil 1 Synthetic 5w-30
2008 Nissan Frontier Mobil 1 Synthetic 5w-30
2012 Jeep Cherokee Laredo Penzoil 5w-20 Synthetic
2013 Toyota Tacoma PreRunner 0w-20 Valvoline Synthetic
Re: Throttle Body [Re: dawgn86] #4811630
07/11/18 06:22 PM
07/11/18 06:22 PM
Hudson, NH
LeakySeals Offline
LeakySeals  Offline
Hudson, NH
I don't know why people write that online. Ive cleaned them, taken them off the car, disconnected the battery. 3 different Nissans new and old. Never did a relearning procedure. Just drove for 50 miles and all was good by the next day. Should go the same as your toyota.
06 Escalade 6.0L LQ9 AWD 165k M1 0w40
03 Maxima 3.5L POS 162k ST HM 10w30
05 Malibu Classic 108k Unk
Re: Throttle Body [Re: dawgn86] #4811632
07/11/18 06:24 PM
07/11/18 06:24 PM
Texas (south)
FermeLaPorte Offline
Texas (south)
The newer (2011- present) Nissan DO require that they get re-program if you touch the throttle body. Don't risk it. That is a part Nissans are really picky about. Guy above me doesn't know [censored] about it. Mine had to get cleaned from there. You are either better off taking it to a mechanic to just pay to get it reprogrammed or risk it. I would just spray it without touching it much.
Always Mobil 1
2014 1.6L Nissan Versa Sedan, 5 spd, 5k OCI.
2011 3.5L Chevrolet Impala, Automatic, 5k OCI.
Re: Throttle Body [Re: dawgn86] #4811930
07/12/18 03:51 AM
07/12/18 03:51 AM
Reunion Island
Superflan Offline
Superflan  Offline
Reunion Island
I’d spray with the throttle body on car, engine running, a second person doing revs up in cabin. But some would say you shouldn’t ever run without an air filter on.
Peugeot Partner 1.9 D, 5W40 C3, 245000 Km, running on WVO
Wife's Mitsubishi Outlander PHEV, dealer’s overfilled, 16000 Km
Re: Throttle Body [Re: FermeLaPorte] #4812057
07/12/18 09:01 AM
07/12/18 09:01 AM
Ohio
hallstevenson Offline
Ohio
Considering he's done (3) different Nissan vehicles, I'm not sure how valid your opinion is....
Re: Throttle Body [Re: dawgn86] #4812068
07/12/18 09:11 AM
07/12/18 09:11 AM
Ohio
Ohio
I have an '08 VQ35HR and have cleaned the throttle bodies 1-1/2 times. I say a 1/2 time because the 2nd time I only removed the intake tube while the first time I removed it from the plenum (but left the electrical connection in place and battery connected). I also moved the butterfly valve ! Both times !
Even if you need or want to do the idle relearn, it's not difficult and does not require a trip to the dealer.
Re: Throttle Body [Re: Superflan] #4812078
07/12/18 09:33 AM
07/12/18 09:33 AM
California
Dave1027 Offline
Dave1027  Offline
California
Sure you can do it with the TB on the car but No need to have the engine running. You simply gain access to the TB (remove intake components). Then block the butterfly open and spray carb cleaner into the TB. Then use a toothbrush and rags to scrub and dry the inside.
But TB cleaning is over done and is not really that important. Not really that much can go wrong with a TB. The air filter cleans almost all of the dirt.
Is mechanics throttle body recommendation legit?
Re: Throttle Body [Re: Dave1027] #4812081
07/12/18 09:36 AM
07/12/18 09:36 AM
Reunion Island
Superflan Offline
Superflan  Offline
Reunion Island
The thing is that engine running so electronic throttle body works.
Re: Throttle Body [Re: Dave1027] #4812195
07/12/18 11:34 AM
07/12/18 11:34 AM
Ohio
Ohio
It may vary by design but on Nissan's VQ engines the PCV system feeds back into the intake and it WILL get a build-up on the face of the butterfly valve as well as create a 'ring' inside the throttle body bore where the valve sits when 'closed'. On VQ engines, this can and does cause idle fluctuations - unsteady idle or when you stop and it drops down to 650-700 idle RPM, it will flutter and drop down to 400-500. Cleaning it, at least for me, SOLVED that.
Re: Throttle Body [Re: hallstevenson] #4812477
07/12/18 05:13 PM
07/12/18 05:13 PM
California
Dave1027 Offline
Dave1027  Offline
California
So Nissan is routing crankcase blowby/oil vapors through the throttle body? That's a screwy design. In that case yeah I agree. Something like that you'd have to clean all the time. Normally PCV is routed directly to the intake manifold bypassing the TB.
Re: Throttle Body [Re: Dave1027] #4812600
07/12/18 07:46 PM
07/12/18 07:46 PM
Ohio
Ohio
Googling "oil buildup throttle body" gets results the refer to Jeeps, Miatas, Toyota pickups, Chevy Tahoe, etc, etc. One person's comment was
Quote:
It’s most likely from blow-by gasses combined with engine oil. It comes from the PCV system. The PCV system sucks air out of the crankcase and feeds it into the intake, usually at or near the throttle body.
There was no reference to the vehicle or engine design in that case.
Re: Throttle Body [Re: dawgn86] #4812625
07/12/18 08:02 PM
07/12/18 08:02 PM
USA
mk378 Online content
mk378  Online Content
USA
Almost every car will get a buildup of black stuff throughout the intake manifold, including the inside of the throttle plate and the downstream sides of the throttle body. It is is oil and unburned gas that carbonizes to a gooey sticky mess. If it is severe it can cause the plate to stick, resulting in driveability problems at idle and just off idle.
Re: Throttle Body [Re: dawgn86] #4813116
07/13/18 11:30 AM
07/13/18 11:30 AM
Ontario
Microscopeman Offline
Ontario
2012 Altima, 2.5S, 110K miles (180K KM). Just cleaned mine to cure a bad idle, stumble on acceleration and error P101 that wasn't fixed with a new MAF sensor.
Undid the TB, but left the connections on and made sure not to move the butterfly. Backside of the butterfly was a mess with a ton of black deposits. Sprayed it all off with TB cleaner. Runs like new, no error codes, no hesitation, not idle issues!
Re: Throttle Body [Re: dawgn86] #4813392
07/13/18 05:29 PM
07/13/18 05:29 PM
Cumming GA
chunt Online content
chunt  Online Content
Cumming GA
If the battery is disconnected prior to starting the throttle body cleaning, there should be no need for the relearn procedure.
18 Pathfinder SL (mine) 0W20
18 Rogue SV (granddaughter's) 0W20
03 Camry LE (daughter's) 5W30
10 Camry SE (granddaughter's) 5W30
