NM
by y_p_w. 02/22/19 02:47 PM
Lady Luck
by CourierDriver. 02/22/19 02:06 PM
112 registered members (1WildPig, 2003f7, 53' Stude, Aero540T, 2015_PSD, 14 invisible),
1,860
guests, and 48
spiders. |
Key:
Admin,
Global Mod,
Mod
Topics284,669
Posts4,874,845
Members67,313
Most Online2,548 Feb 16th, 2019
STP XL Filters - heads up!
#4811336
07/11/18 12:20 PM
07/11/18 12:20 PM
Posts: 5,505 North Carolina
rooflessVW
OP
OP
North Carolina
Both STP XL filters for the LS engines (3506 and 3675) have bypass valves.
They're not supposed to!
Heading back now to make a swap. Hopefully they help me out.
"Zed's dead baby, Zed's dead."
Re: STP XL Filters - heads up!
[Re: rooflessVW]
#4811341
07/11/18 12:24 PM
07/11/18 12:24 PM
Posts: 1,731 San Rafael, CA
dogememe
San Rafael, CA
can I ask you something? I am not confirming or denying the presence of bypass valves in those two filters (since I never shop at Autozone where I believe those are sold) but how is having a bypass valve detrimental in whatever application? Thank you!
2010 Ford Escape 2.5 ~94K Miles: Royal Purple 5W-30 2008 Ford Crown Vic P71 4.6 ~167K Miles: AMSOIL SS 0W-30 1995 Chevy Silverado 5.7 ~277K Miles: Delo 10W-30
[Re: rooflessVW]
#4811383
07/11/18 12:57 PM
07/11/18 12:57 PM
rooflessVW
OP
OP
North Carolina
Having the bypass valve is not a non-issue if your car is specifically modified to not have a filter bypass. In any case - the LS has an internal bypass, so why spend the money to put one in the can where it's not needed?
[Re: ZeeOSix]
#4811421
07/11/18 01:32 PM
07/11/18 01:32 PM
rooflessVW
OP
OP
North Carolina
Probably wouldn't hurt to have a "double bypass" as long as the filter's bypass valve was set higher than the built-in block bypass valve. It was just something I'd never seen before. Never seen a filter for this app with a bypass, Fram HP20 excluded.
[Re: doolah02]
#4811449
07/11/18 02:09 PM
07/11/18 02:09 PM
rooflessVW
OP
OP
North Carolina
I believe Mobil 1 filters have the bypass valve in that location, that would be great for startup noise in my Sport Trac. M1-107A and M1-206A are without bypass valves, as they should be.
[Re: rooflessVW]
#4811806
07/11/18 08:20 PM
07/11/18 08:20 PM
Posts: 5,049 MTL, CANADA
Rolla07
MTL, CANADA
Maybe its done to work on other makes that require the bypass that also use this filter. Id guess having one when not needed is better than not having one when needed?
2007 Corolla Red Pearl 155k miles PP 0w20 & ST 4967
[Re: Rolla07]
#4812916
07/13/18 05:53 AM
07/13/18 05:53 AM
Posts: 12,909 The Old North State
Sayjac
The Old North State
Maybe its done to work on other makes that require the bypass that also use this filter. Id guess having one when not needed is better than not having one when needed? Seeing as the STP XL consolidates applications, I'd say that's a reasonable assumption. And yes, having one where not spec'd infinitely better than not having one where it is.
[Re: rooflessVW]
#4812919
07/13/18 05:57 AM
07/13/18 05:57 AM
rooflessVW
OP
OP
North Carolina
Interesting to me that it's only the one line of filters that "consolidate," and they're made in China...
Edit: I mean consumer lines of filters. I know lube shop filter lines consolidate.
[Re: rooflessVW]
#4813053
07/13/18 09:08 AM
07/13/18 09:08 AM
Posts: 118 Kentucky
JeePing
Kentucky
................... Holly [censored] ... people who read this. please, do not listen to the nonsense above. Every engine, with pressurized lubricating system, driven by positive displacement pump has a pressure relief. Or what uninformed poster calls a "bypass". The reason for filter to have pressure relief valve internal and independent is to keep oil flowing to the engine even if filter is completely clogged. If filter does not have a relief, oil will simply dump into the sump with out circulating through the engine.
If it an't broke, take it a part and see why not.
[Re: JeePing]
#4813091
07/13/18 10:10 AM
07/13/18 10:10 AM
Posts: 8,635 Cincinnati, OH, USA
bullwinkle
Cincinnati, OH, USA
................... Holly [censored] ... people who read this. please, do not listen to the nonsense above. Every engine, with pressurized lubricating system, driven by positive displacement pump has a pressure relief. Or what uninformed poster calls a "bypass". The reason for filter to have pressure relief valve internal and independent is to keep oil flowing to the engine even if filter is completely clogged. If filter does not have a relief, oil will simply dump into the sump with out circulating through the engine. Actually, there are usually TWO pressure relief valves-one on the oil pump (which dumps the oil back into the sump), and one either in the filter or in the block that allows oil to bypass a blocked filter OR during extreme cold/thick oil events. Some SB Chevy oil filters have a filter bypass, other ones don't-and I have never heard of any issues caused by having the extra one in the filter!
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
