SUNOCO GLOBAL FULL SYNTHETIC ATF
by Ursatdx. 02/22/19 06:46 PM
No more Meijer batteries!!
by bullwinkle. 02/22/19 06:24 PM
Valvoline premium blue tsc
by Dudemanmaximus. 02/22/19 05:38 PM
Echo won’t run on high speed
by artbuc. 02/22/19 05:36 PM
Roadside Assistance memberships
by paulri. 02/22/19 05:35 PM
Remembering Steve Irwin
by 2015_PSD. 02/22/19 05:27 PM
Transmission Cooler
by rcbob. 02/22/19 04:59 PM
Amazon: PP Euro 5W-40 $38 for pack of 6 quarts
by 1JZ_E46. 02/22/19 04:56 PM
89 Wrangler oil recommendations
by Chris142. 02/22/19 04:55 PM
New batteries failing on the shelf
by Chris142. 02/22/19 04:53 PM
Schaeffer’s 5w30 LT1
by s2krunner. 02/22/19 04:48 PM
Lexus LS430 P0756
by Kibitoshin. 02/22/19 04:41 PM
PUP is now SN + ??? Formulation change??
by Lazydan. 02/22/19 04:17 PM
Got a new wireless printer/MFC
by y_p_w. 02/22/19 02:48 PM
NM
by y_p_w. 02/22/19 02:47 PM
Names of brand names quality non-pro multi-meter
by JLawrence08648. 02/22/19 02:16 PM
Lady Luck
by CourierDriver. 02/22/19 02:06 PM
Ford MPG
by Zee09. 02/22/19 02:03 PM
jcthorne, duckthis1, Roughneck777, KDW, avantika31
67313 Registered Users
122 registered members (10WSmuckers, 928, Alisobob, AandPDan, AdditiveOCD, 11 invisible), 1,746 guests, and 55 spiders.
Topics284,678
Posts4,874,959
Members67,313
Most Online2,548
Feb 16th, 2019
Page 1 of 3 1 2 3
How often to change engine oil on low-use vehicle? #4811272
07/11/18 11:32 AM
07/11/18 11:32 AM
Southern California, USA
slickoil Offline OP
slickoil  Offline OP
I have a 2001 Jeep Cherokee Sport 4x4 that I only drive about 1K miles per year. I have a mechanic perform oil changes for me, and have them use conventional oil.
I've had some people tell me to change the engine oil and filter every 6 months (which is 500 miles), because that's what Jeep recommends.
I've had others tell me to change the engine oil and filter every 12 months (1000 miles), because that's "more reasonable" for a low-use vehicle.
I've had others tell me to change the engine oil and filter every 2 years (2000 miles), because cheap oil filters start to break down if used longer than that, but the oil and additives should last at least that long.
I've had others tell me to wait until I hit 5000 miles (about 5 years) before changing the engine oil because oil and oil additives don't degrade without use.
So I turn here, the internet's foremost oil forum to ask: How often should I change the engine oil and filter on a 2001 Jeep Cherokee that is only driven 1000 miles/year?
Re: How often to change engine oil on low-use vehicle? [Re: slickoil] #4811281
07/11/18 11:36 AM
07/11/18 11:36 AM
Florida
hatt Online content
hatt  Online Content
Florida
Every two years is what I'd do.
2013 F150 5.0, PUP 10W-30, Wix 57502
2010 Camry 2.5, GTX 5W-20, Fram Ultra XG9972
Re: How often to change engine oil on low-use vehicle? [Re: slickoil] #4811297
07/11/18 11:47 AM
07/11/18 11:47 AM
North Carolina
rooflessVW Offline
rooflessVW  Offline
North Carolina
My 911 mostly sits now unfortunately. I end up getting bored and changing it once or twice a year... Normally right before storing it.
If I didn't have a stash of cheap oil and filters to swap out willy-nilly I'd probably change it once a year.
"Zed's dead baby, Zed's dead."
Re: How often to change engine oil on low-use vehicle? [Re: slickoil] #4811312
07/11/18 11:59 AM
07/11/18 11:59 AM
PimTac Offline
PimTac  Offline
This 1000 miles per year, is it short trips?
One answer would be to drive that Jeep more often and on longer drives but you may have good reasons why its not driven so much.
I think every two years is acceptable.
Cannot see signatures any longer so it doesn’t matter.
Re: How often to change engine oil on low-use vehicle? [Re: slickoil] #4811348
07/11/18 12:30 PM
07/11/18 12:30 PM
1/2 hr N.E. of Detroit
Triple_Se7en Offline
Once a year, unless you live in Alaska. Even if you did, I doubt the cold would create an oil concern in 1K use.
2019 Hyundai SantaFe 2.4 factory fill / QS 5w20 conv. / Mahle OEM oil filter
04 Chev Colorado 3.5 QS / Valv syn 5w30 blend K&N filter
03 Chev Malibu 3.1 QS / Valv Syn 5w30 blend Fram EG filter
Re: How often to change engine oil on low-use vehicle? [Re: PimTac] #4811352
07/11/18 12:32 PM
07/11/18 12:32 PM
slickoil Offline OP
slickoil  Offline OP
It varies, but each trip is typically about 15-20 miles round trip (drive 7-10 miles to destination, Jeep sits for 1-3 hours, then drive 7-10 miles back).
Re: How often to change engine oil on low-use vehicle? [Re: slickoil] #4811355
07/11/18 12:34 PM
07/11/18 12:34 PM
NY
demarpaint Offline
demarpaint  Offline
NY
I stretch it to two years in my E-150, that's usually about 3,000-4,000 miles of short trips.
God Bless Our Troops
Re: How often to change engine oil on low-use vehicle? [Re: slickoil] #4811356
07/11/18 12:35 PM
07/11/18 12:35 PM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
I have been in a similiar situation for many years and I change the oil and filter every 2-3 years. I have had several analysis reports done and I was told I could even go longer but do not.
The "thinking" man's friend.
Re: How often to change engine oil on low-use vehicle? [Re: slickoil] #4811360
07/11/18 12:39 PM
07/11/18 12:39 PM
Saskatchewan, Canada
Johnny2Bad Offline
Johnny2Bad  Offline
There is no need to change oil any more often than yearly if the vehicle doesn't operate long enough to meet a mileage OCI.
You might get away with an even longer OCI but automakers and oil companies recommend against it as contaminants potentially can erode internal engine components. It must be said that many engines have sat for years and started up and lasted without any evident problems, so you can follow your personal nervousness and do what is recommended or try to save some money and effort.
'57 FL Straight 50 wt
'90 Miata 1.8L w/Rotrex Supercharger [Mobil1 0W-40]
'96 Ram 1500 [3.7L Mobil1 0W-20 / 1L 15W-50]
'01 PT Cruiser [Mobil1 0W-40]
Re: How often to change engine oil on low-use vehicle? [Re: demarpaint] #4811371
07/11/18 12:49 PM
07/11/18 12:49 PM
Tri State Conservative
Zee09 Offline
Zee09  Offline
I do the same in my tow truck but always use synthetic oil filters just in case.
"If I walked on water, they'd say I couldn't swim."
Re: How often to change engine oil on low-use vehicle? [Re: slickoil] #4811377
07/11/18 12:54 PM
07/11/18 12:54 PM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
I would think once every 2 years would be fine in that.
but I probably couldnt go that long and would just change it once yearly.
of course if you live in minnesota vs florida could have some effect.
10miles in a Minnesota winter wouldn't get rid of the moisture in the oil etc.
Maybe put a state on your location? USA is pretty vague.
Re: How often to change engine oil on low-use vehicle? [Re: slickoil] #4811385
07/11/18 12:59 PM
07/11/18 12:59 PM
Silicon Valley
PandaBear Offline
PandaBear  Offline
Silicon Valley
Depends on if you have time. If it is a really nice garage queen I would change it once a year then throw the like new oil into my daily driver, instead of wasting it.
"You keep asking questions PandaBear and you'll end up a vegetarian like my wife" - Camu Mahubah
Re: How often to change engine oil on low-use vehicle? [Re: slickoil] #4811414
07/11/18 01:26 PM
07/11/18 01:26 PM
US
JLTD Online shocked
JLTD  Online Shocked
US
My first thought was 2 years. But--
6 months definitely too early.
One year might be early in your place I'd spring for a UOA.
Is it a stick or auto?
I'm a thickie; assimilate
But 20s have their place
Using AMSOIL
Hers: 2008 Jeep Liberty 138k, SS 5w30/Amsoil
His: 2015 4Runner 45k, OE 5w30/Wix
Re: How often to change engine oil on low-use vehicle? [Re: slickoil] #4811415
07/11/18 01:26 PM
07/11/18 01:26 PM
VA
Gebo Online content
Gebo  Online Content
VA
Once a year with a high priced synthetic.
'98 LEX LS400 290K
'02 4Runner 230K
'05 Lex LS430 85K
'07 Lex GX470 65K
Amsoil in last two.
Schaeffer in the first two.
Re: How often to change engine oil on low-use vehicle? [Re: Gebo] #4811426
07/11/18 01:36 PM
07/11/18 01:36 PM
PimTac Offline
PimTac  Offline
Explain this.
Page 1 of 3 1 2 3
Moderated by  ekpolk
