Hazet 600LG/8 Wrench set - $160
by drtyler - 02/25/20 01:34 PM
Cartridge Filter Question
by Tundra73 - 02/25/20 01:21 PM
Buying another car of the same generation
by brages - 02/25/20 01:02 PM
Buying Tires on Amazon
by jcartwright99 - 02/25/20 12:52 PM
plated cylinder liners and sulphur
by alex_at - 02/25/20 12:31 PM
Have we reached the ceiling in improvents to PCMO?
by Speak2Mountain - 02/25/20 11:59 AM
International travel for pleasure
by Pew - 02/25/20 11:42 AM
maxi scooter - should i change the oil now?
by alex_at - 02/25/20 11:05 AM
Toyota NA vs Toyota Global...
by mv6845 - 02/25/20 10:11 AM
How to determine Group II, III or IV
by Drew7a - 02/25/20 09:41 AM
Pulling axle question
by supton - 02/25/20 07:50 AM
Sams Club gas
by dbvettez061 - 02/25/20 07:44 AM
2019 Ram Battery Issue
by NYEngineer - 02/25/20 06:00 AM
belt squeaking suddenly
by dogememe - 02/24/20 11:45 PM
Is Mobil 1 advanced synthetic a full synthetic?
by apollo18 - 02/24/20 11:08 PM
what stocks to buy?
by daves66nova - 02/24/20 08:55 PM
I thought Windows 7 would be insecure now?
by atikovi - 02/24/20 08:48 PM
When to replace struts
by ram_man - 02/24/20 08:40 PM
BJD2020, ToyTaco2002, EarlT500, Newbie111, Boris_Be
70800 Registered Users
102 registered members (aquariuscsm, 01VFR, ABerns, alex_at, AlaskaMike, bbhero, 6 invisible), 2,483 guests, and 19 spiders.
Topics301,912
Posts5,205,224
Members70,800
Mazda Long Life Hypoid Gear Oil SG1 #4811155 07/11/18 09:23 AM
1
10ecfarmer Offline OP
1
Whats the specs for this gear oil, and whats a good a after market equivalent?
Re: Mazda Long Life Hypoid Gear Oil SG1 [Re: 10ecfarmer] #4811183 07/11/18 09:52 AM
R
Rand Offline
R
for what application?
is this for a mazda mx-5 manual transmission?
Re: Mazda Long Life Hypoid Gear Oil SG1 [Re: Rand] #4811217 07/11/18 10:33 AM
R
Rand Offline
R
apparently my edit failed.
at least for the application I listed api gl-4 75w90 gear oil is somewhat similar except perhaps thicker.
Re: Mazda Long Life Hypoid Gear Oil SG1 [Re: 10ecfarmer] #4811228 07/11/18 10:44 AM
slug_bug Offline
I asked Red Line if they made an equivalent a couple of months ago. Their response was "at this point we donít offer a cross for the SG1 differential gear oil." Not that this helps you, but, it leads me to believe there is something unique about the oil.
2017 RX350 (36k)
2016 Miata 2.0l (24k)
2013 Fusion 2.5l(99k)
2013 Focus(73K)
Re: Mazda Long Life Hypoid Gear Oil SG1 [Re: 10ecfarmer] #4811260 07/11/18 11:17 AM
1
1
Per Mazda:
Mazda Long Life Hypoid Gear Oil SG1 for the differential..
Mazda Original Long life Gear Oil IS for the manual transmission with this footnote "can use API Service GL-4 75W-90"
but there is No Footnote for the Differential..
Re: Mazda Long Life Hypoid Gear Oil SG1 [Re: Rand] #4811264 07/11/18 11:21 AM
1
1
Rand, its for the Differential.
Re: Mazda Long Life Hypoid Gear Oil SG1 [Re: 10ecfarmer] #4818865 07/20/18 02:12 PM
R
RamFan Offline
R
I'd like to know specs too. In 2016, Mazda changed the recommendation for the transfer case and rear differential on the CX-5 from an 80w90 GL-5 to Mazda Long Life Hypoid Gear Oil SG1. Was there a technical reasoning or is this a way to increase dealership visits?
18 Giulia Ti Sport Q4
  • 2.0T I4 - 24k - PP Euro LX 0w30 - PureOne - 10k/1yr
16.5 CX-5 Touring AWD
  • 2.5L I4 - 68k - Castrol Edge EP 0w20 - Denso - 7.5k/1yr
Re: Mazda Long Life Hypoid Gear Oil SG1 [Re: 10ecfarmer] #4819550 07/21/18 09:25 AM
B
Bullwinkle007 Offline
B
I just looked on redline website, I don't see anything either. Watched a quick video, redline MTL is used in Mazda transmissions,
Re: Mazda Long Life Hypoid Gear Oil SG1 [Re: 10ecfarmer] #4819580 07/21/18 10:07 AM
1
1
Some of the aftermarket Miata suppliers list Redline for the NA,NB,NC,ND differential, So??????? My ND was low from the factory, I drained & filled w/ Mobil 1 75W90 GL5. I don't track or autocross, so I feel this is more than adequate.
Re: Mazda Long Life Hypoid Gear Oil SG1 [Re: 10ecfarmer] #5341658 02/05/20 09:17 AM
A
avi1777 Offline
A
bump,
im approaching 30 k miles and want to change the rear dif fluid,no sg1 to be found so what do i buy?the dealership says 80W90 but they also say not to change it ever only if the diff was in water so dont know if to trust them on the 80w90 oil.
a 16 2.5 4*4 cx5.
tnx a lot.
Re: Mazda Long Life Hypoid Gear Oil SG1 [Re: avi1777] #5341670 02/05/20 09:33 AM
Z
zeng Offline
Z
Originally Posted by avi1777
bump,
a 16 2.5 4*4 cx5.
tnx a lot.
You should trust them on the 80W90, but it has to be a GL5, not GL4 .
Re: Mazda Long Life Hypoid Gear Oil SG1 [Re: 10ecfarmer] #5341674 02/05/20 09:39 AM
A
avi1777 Offline
A
i can only get a mineral 80w90 or a 75w90 full syn,can i use the 75w?
tnk u for your quick reply.
Re: Mazda Long Life Hypoid Gear Oil SG1 [Re: 10ecfarmer] #5341692 02/05/20 10:03 AM
Z
zeng Offline
Z
A mineral 80W90 typically has a KV40 of 145 - 160 cSt;whilst
a synthetic 75W90 typically has a KV40 of 95 - 105 cSt; and
a 75W typically has a KV40 of 35 - 45 cSt .
Now the factory SG1 has KV40 of what value ? IDK. I would speculate it to be around 100 - 120 for fuel economy with modern hardware manufacturing technology .
You can use 75W, but your higher ambient temperature may promote whining noise (as a very very mild form of wear and tear) and made worse with relative hard driving .
I personally prefer a monograde SAE 90 GL5, which your dealer did not recommend .
Re: Mazda Long Life Hypoid Gear Oil SG1 [Re: 10ecfarmer] #5341694 02/05/20 10:05 AM
A
avi1777 Offline
A
as long as its a GL5 of course
Re: Mazda Long Life Hypoid Gear Oil SG1 [Re: 10ecfarmer] #5341697 02/05/20 10:08 AM
A
avi1777 Offline
A
they use the motorcraft 80w90 apparently.
