CVT Reliability and Durability
by raffy. 03/25/19 11:00 AM
comfortable seats
by redhat. 03/25/19 10:29 AM
walmart evinrude tcw-3 clearance score
by 1978elcamino. 03/25/19 10:15 AM
Mixing SN/d1G1 with SN+/d1G2?
by doyall. 03/25/19 10:14 AM
Best 2nd Phone Number App ?
by LoneRanger. 03/25/19 09:56 AM
Crud! Wix jacking up prices again! :(
by SubieRubyRoo. 03/25/19 09:53 AM
Interior "quick detailer"
by Redright9. 03/25/19 08:21 AM
Seafoam For Last 100 Miles Before Oil Change ?
by ChrisD46. 03/25/19 07:56 AM
WIX 57151XP factory filled with synthetic oil
by Donald. 03/25/19 06:58 AM
BMW Buying Guide: Every Model, Explained
by wemay. 03/25/19 05:43 AM
Double Din Android Auto Advice
by JeffKeryk. 03/24/19 11:25 PM
VW mk5 a/c intermittently works
by ram_man. 03/24/19 11:01 PM
DIY alignment done right?
by tookien. 03/24/19 10:03 PM
Cell phone privacy question
by loneryder. 03/24/19 10:00 PM
Ride quality between 45 and 35 sidewall
by bowlofturtle. 03/24/19 09:23 PM
FRAM TG 7317 - 12K miles opened
by crazy_raccoon. 03/24/19 09:01 PM
sonusfaber, Rollo, Drifted, Jcar516, gregjr7
67614 Registered Users
109 registered members (AdditiveOCD, ArrestMeRedZ, ARB1977, 2012AccentSE, 13 invisible), 2,167 guests, and 56 spiders.
Topics286,393
Posts4,907,459
Members67,614
Most Online2,967
Mar 10th, 2019
Stalling issue with Buick Regal 3800 engine #4811017
07/11/18 08:29 AM
07/11/18 08:29 AM
Michigan
ZZman Offline OP
ZZman  Offline OP
Michigan
I took a stab in the dark and changed the fuel filter as it has never been changed. After doing some reading I now think it is probably a Crank Position Sensor issue.
Any thoughts or tips?
2003 Mercury Grand Marquis. PP HM 5w-30 and Fram TG
2008 Sebring Hardtop convertible. PP HM 5w-30 and Fram Ultra
2006 Kawasaki Vulcan 900 LT. Motul 7100 10w-40 and K&N
Re: Stalling issue with Buick Regal 3800 engine [Re: ZZman] #4811034
07/11/18 08:40 AM
07/11/18 08:40 AM
'Stralia
Shannow Offline
Shannow  Offline
'Stralia
Blinker fluid is probably low in the passenger side front.
I'd change that next.
Re: Stalling issue with Buick Regal 3800 engine [Re: ZZman] #4811042
07/11/18 08:45 AM
07/11/18 08:45 AM
Alabama
ron350 Offline
ron350  Offline
Alabama
What year is this Regal?
How many times has it stopped running and how long does it take before it will restart?
ron350
Re: Stalling issue with Buick Regal 3800 engine [Re: ZZman] #4811063
07/11/18 08:59 AM
07/11/18 08:59 AM
NY
fcjeep Offline
fcjeep  Offline
NY
I had a 3800 in a 1989 LeSabre. When my crank pos sensor went out it cranked but did not start.
When my mass airflow sensor went it would start, drive a little, stall and restart again and stall again.
2006 Jeep GC 4.7L, Died @ 153059 mi frown
2008 Xterra 4.0L, 104500 mi
2016 Jeep GC 3.6L, 19100 mi
2017 Benz C300 14000 mi
Re: Stalling issue with Buick Regal 3800 engine [Re: ZZman] #4811064
07/11/18 09:01 AM
07/11/18 09:01 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Check the MAF sensor also on these, it can cause stalling, hard starting, grey smoke. Both sensors are very common failure points.
Edit: fcjeep had the same thought at the same time.
Re: Stalling issue with Buick Regal 3800 engine [Re: ZZman] #4811080
07/11/18 09:10 AM
07/11/18 09:10 AM
Oklahoma
Schmoe Offline
Schmoe  Offline
Oklahoma
My old 1990 Cutlass had a similar problem, crank sensor. PITA to replace.
01 Supercrew Lariat 4X4
06 Accord EX-L V6
14 CRV EX-L (RIP) 2018 CRV EX-L
Re: Stalling issue with Buick Regal 3800 engine [Re: Schmoe] #4811116
07/11/18 09:35 AM
07/11/18 09:35 AM
Trav Offline
Trav  Offline
It takes a big friggin impact gun to get the crank bolt off if its never been off before. I hit it with the 1" IR right off the bat and it rockets it off in seconds.
Re: Stalling issue with Buick Regal 3800 engine [Re: ZZman] #4811132
07/11/18 10:00 AM
07/11/18 10:00 AM
In the Garage...
ls1mike Offline
ls1mike  Offline
In the Garage...
What year is it?
Mike
00 Trans Am WS6 5.7 LS1
02 Silverado 2500HD 6.0
14 Caprice PPV 6.0
15 Malibu LTZ Turbo
12 Passport TT
Re: Stalling issue with Buick Regal 3800 engine [Re: ZZman] #4811166
07/11/18 10:33 AM
07/11/18 10:33 AM
Michigan
ZZman Offline OP
ZZman  Offline OP
Michigan
2002
It stalls occasionally and usually starts right back up
Re: Stalling issue with Buick Regal 3800 engine [Re: ZZman] #4811262
07/11/18 12:19 PM
07/11/18 12:19 PM
Wisconsin
Rmay635703 Offline
Rmay635703  Offline
Wisconsin
Mine did that an idled like cra it was a leaky cracked plastic intake.
Re: Stalling issue with Buick Regal 3800 engine [Re: ZZman] #4811296
07/11/18 12:46 PM
07/11/18 12:46 PM
Alabama
ron350 Offline
ron350  Offline
Alabama
If it is a crankshaft position sensor you will only have so many stops before the sensor dies for good and leaves you stranded.
The next time it dies watch the tach and see if it works while you are trying to crank the car. With most bad CPS the tach will read lower than normal while cranking.
ron350
Re: Stalling issue with Buick Regal 3800 engine [Re: ZZman] #4811366
07/11/18 01:44 PM
07/11/18 01:44 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
Could be any number of things but if throwing the parts cannon at it a crank sensor would be my 1st choice.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Stalling issue with Buick Regal 3800 engine [Re: ZZman] #4811424
07/11/18 02:35 PM
07/11/18 02:35 PM
Ohio
beast3300 Offline
beast3300  Offline
Ohio
Does it stall when you hit the turn signal?
'03 Regal GS L67: PPUP 5w30/FU3980
'99 Grand Prix L36: R.I.P.
'07 LaCrosse L26: QS HM 5w30/TG3387A
ASE L1 MT
Re: Stalling issue with Buick Regal 3800 engine [Re: ZZman] #4811574
07/11/18 05:16 PM
07/11/18 05:16 PM
Milwaukee, WI.
beechcraftted Offline
Milwaukee, WI.
I had a 3.8 (Grand Prix) that had a bad fuel pressure regulator. Easy to check, if you have fuel on the vacuum side it is bad. This vehicle would stall on long coasting conditions and long red lights. Always started right back up.
'66 Chevelle 496 big block
'69 Corvette 427 4 speed
'70 Rebel "Machine" 390 4 speed
'04 Suburban
'10 Impala
'15 Honda F6B
'92 Suzuki Katana 1100
Re: Stalling issue with Buick Regal 3800 engine [Re: ZZman] #4811640
07/11/18 06:33 PM
07/11/18 06:33 PM
Michigan
ZZman Offline OP
ZZman  Offline OP
Michigan
Sure would help if it threw a code!
