Weird Residue in New Fram Ultra
by mphilleo. 02/16/19 01:40 AM
0w20 vs 0/5w30 (yes I know another viscosity thread)
by SnowDrifter. 02/15/19 11:42 PM
skid plate
by mobilaltima. 02/15/19 10:32 PM
The Last Gladiators (French)
by Marco620. 02/15/19 08:54 PM
Rural King 5W30 Citgo Superguard blend 5qt jug $9.91
by tenderloin. 02/15/19 08:34 PM
Meet Watson!
by spasm3. 02/15/19 08:16 PM
Tie Rod and Ball Jt. Recommendations/Advi
ce
by coopns. 02/15/19 08:11 PM
Uninstall Avast
by willbur. 02/15/19 06:58 PM
Need a new toliet
by JLawrence08648. 02/15/19 06:55 PM
Help Me Choose A Smartphone
by Warstud. 02/15/19 05:29 PM
Source for Torque Wrench Calibration?
by SubLGT. 02/15/19 05:09 PM
Transmission Scraping Noise
by bprat318. 02/15/19 04:59 PM
Ok to mix gear oil viscosities?
by zuluplus30. 02/15/19 04:11 PM
Tore Wheel Cylinder Boot on 2007 Tacoma
by john_pifer. 02/15/19 04:10 PM
Spotify to home theater
by Malo83. 02/15/19 03:19 PM
6.0 powerstroke for a forever truck
by FLORIDA. 02/15/19 02:55 PM
Atwoods PYB 5QT jug $7.99 after rebate !!
by GMguy84. 02/15/19 02:52 PM
Torque Wrench Accuracy
by Kjmack. 02/15/19 12:57 PM
3dfever, Mahmoud, Happycamper, jftcat, TexasForever
67246 Registered Users
35 registered members (berlyn, AmoryBlaine, Aero540T, Ag76, 1WildPig, anndel, 3 invisible), 603 guests, and 55 spiders.
Topics298,256
Posts4,988,183
Members67,246
Most Online2,474
Feb 10th, 2019
TT Camaro, Driven LS30; 1000 on oil, 2000 engine #4810917
07/11/18 02:30 AM
07/11/18 02:30 AM
MO
BlakeLSX Offline OP
BlakeLSX  Offline OP
MO
2010 Camaro with LSX 427/6 spd manual
Car actually runs on E85 most of the time and this sample was taken cold. I'm hoping the numbers, especially the iron, come down. I have about 600 more miles to go and I'll send in the 1000 mile sample (warm) mentioned in the comments. I also switched to Mobil 1 15W50 full synthetic. No real reason other than it was on sale and a little thicker oil than 5W30 is recommended by the turbo company.
The car makes 1000whp on low boost and I work it like a Dickensian orphan. Maybe I should start planning what parts to use in the rebuild...
Re: TT Camaro, Driven LS30; 1000 on oil, 2000 engine [Re: BlakeLSX] #4810921
07/11/18 03:40 AM
07/11/18 03:40 AM
Tri State Conservative
Zee09 Offline
Zee09  Offline
Wow iron is high!
"If I walked on water, they'd say I couldn't swim."
Re: TT Camaro, Driven LS30; 1000 on oil, 2000 engine [Re: BlakeLSX] #4810978
07/11/18 06:28 AM
07/11/18 06:28 AM
Ontario, Canada
OVERKILL Offline
OVERKILL  Offline
Ontario, Canada
It's generally of no value sampling the oil from an engine still breaking in. You'll want to do it after the oil has been drained/filled a few times to flush out that break-in material to get an idea of where your levels are and then watch subsequent samples to see if things are trending down like they are supposed to.
2019 RAM 1500 Sport
2016 Grand Cherokee SRT
Re: TT Camaro, Driven LS30; 1000 on oil, 2000 engine [Re: BlakeLSX] #4810986
07/11/18 06:37 AM
07/11/18 06:37 AM
Ocala, Florida
racin4ds Offline
racin4ds  Offline
Ocala, Florida
I agree, sampling on this new of an engine is a moot point. You aren't going to see anything valuable until it is broken in and all wear metals are flushed.
I'd certainly be using the thicker vis oils in this thing though! A 1000hp LS with Turbo is no place for a thin 5W30! I'm not a M1 fan at all so IMO there are much better oils out there for your application but either way do several more 1000-2000 OCI's and then sample and see if that iron has dropped, if not, its time to go see your builder!
Just say NO to thin oils and M1!
05 F350 Powerstroke
05 Hyundai Tucson
08 Legacy GT
Re: TT Camaro, Driven LS30; 1000 on oil, 2000 engine [Re: BlakeLSX] #4811013
07/11/18 07:26 AM
07/11/18 07:26 AM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
Well it is a new engine putting out lots of HP at wot. 5w-30 seems a bit thin to take the pounding. I could be wrong though.UOA on a new engine is a waste unless you suspect a coolant leak or something.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: TT Camaro, Driven LS30; 1000 on oil, 2000 engine [Re: BlakeLSX] #4811088
07/11/18 08:16 AM
07/11/18 08:16 AM
Michigan
A_Harman Offline
A_Harman  Offline
Michigan
What bearings does the engine have in it; bimetal Aluminum or trimetal leaded bronze?
The high copper and lead worry me more than the iron.
But like others have said here, a new engine will show a lot of wear metals.
How are you using the car? Drag race? Road courses? Street?
The KV100 has held up well in the Driven LS30. The M1 15w50 isn't a bad choice, but I would have only gone up to a 40-weight. Driven has a stout 40-weight, as do Redline and AMSoil.
1985 Z51 Corvette track car
2002 Camaro Z28 LS1/6-speed
2001 Dodge Ram 2500 diesel
1972 GMC 1500 shortbed project truck
Moderated by  ekpolk
