Hello bitog!
As I am approaching 60 000 kms, I decided to change both differentials' oil.
I read a post on subaruforester.org and it looks pretty simple, so I bought amsoil svg 75w-90 for both differentials. A while ago it was the best gear oil from what I read online, is it still a good oil?
Also, in the manual it says that the front differential shoud use something called extra mt as it is in the same window as the manual transmission. It says GL5 could be used but could affect drivability...
Is the Amsoil svg 75w-90 a good oil for the front diff?
