0w20 vs 0/5w30 (yes I know another viscosity thread)
by SnowDrifter. 02/15/19 11:42 PM
skid plate
by mobilaltima. 02/15/19 10:32 PM
The Last Gladiators (French)
by Marco620. 02/15/19 08:54 PM
Rural King 5W30 Citgo Superguard blend 5qt jug $9.91
by tenderloin. 02/15/19 08:34 PM
Meet Watson!
by spasm3. 02/15/19 08:16 PM
Tie Rod and Ball Jt. Recommendations/Advi
ce
by coopns. 02/15/19 08:11 PM
Uninstall Avast
by willbur. 02/15/19 06:58 PM
Need a new toliet
by JLawrence08648. 02/15/19 06:55 PM
Help Me Choose A Smartphone
by Warstud. 02/15/19 05:29 PM
Source for Torque Wrench Calibration?
by SubLGT. 02/15/19 05:09 PM
Transmission Scraping Noise
by bprat318. 02/15/19 04:59 PM
Ok to mix gear oil viscosities?
by zuluplus30. 02/15/19 04:11 PM
Tore Wheel Cylinder Boot on 2007 Tacoma
by john_pifer. 02/15/19 04:10 PM
Spotify to home theater
by Malo83. 02/15/19 03:19 PM
6.0 powerstroke for a forever truck
by FLORIDA. 02/15/19 02:55 PM
Atwoods PYB 5QT jug $7.99 after rebate !!
by GMguy84. 02/15/19 02:52 PM
Torque Wrench Accuracy
by Kjmack. 02/15/19 12:57 PM
Thoughts on pennzoil 0w30 lx
by 750HMF. 02/15/19 12:26 PM
3dfever, Mahmoud, Happycamper, jftcat, TexasForever
67246 Registered Users
35 registered members (bfleeman, anndel, 1WildPig, Ag76, bbhero, 3 invisible), 785 guests, and 57 spiders.
Topics298,255
Posts4,988,167
Members67,246
Most Online2,474
Feb 10th, 2019
1994 Civic LX 1.6L Brake Hose crush washers #4810781
07/10/18 08:58 PM
07/10/18 08:58 PM
CA
Gito Offline OP
Gito  Offline OP
CA
Need the crush washers for the rubber brake hoses that attach to the calipers. I need a total of 8 washers (2 per hose).
Honda dealer is selling them for $4 dollars each. Thats kind of pricey if you ask me. Part number is 46472-568-000.
Anyone know if I can get these washers some where else. AMZN also sells them for $4 dollars a piece.
Can I just reuse the washers?
Any advice is greatly appreciated
Re: 1994 Civic LX 1.6L Brake Hose crush washers [Re: Gito] #4810786
07/10/18 09:08 PM
07/10/18 09:08 PM
New York
NoNameJoe Offline
NoNameJoe  Offline
New York
You're talking about the two that crush between the banjo bolt, banjo fitting and caliper? Yes you can get them elsewhere. I hear you can re-use them but since I could get them easily I wouldn't personally do that.
The stock ones appear to be aluminum but every reman kit I get seems to come with copper. Last time I took the calipers off on my car, I used coppers. Never leaked, never had a problem.
The most important part would be getting the measurement right. If you don't already have the calipers off to measure the washers, here are the measurements I took last time. My Honda Civic uses the same washer part number as yours so these measurements should work with your car provided you have stock calipers.
* 10mm ID
* 15.25mm OD
* 1.25mm thickness
* 2.58mm diameter thickness
Note that while shopping for the washer you don't have to meet exactly these measurements, there's some margin as long as the sealing surface matches. The caliper also gives you significant room around the washer to accommodate different washer sizes.
For example having an extra .25mm thickness or .75mm increase in OD isn't going to matter. If we're talking millimeters it's so small it's virtually unnoticeable.
Here's what I bought last time I did the calipers. I went with these guys since they seemed like they focused only on brakes. The washers were excellent and have not given me any problems. They fit on the caliper exactly without hanging off or interfering with the prongs that stick out that guide the hose. I would buy from them again.
https://www.ebay.com/itm/COPPER-CRUSH-WASHERS-10mm-ID/330625585664
2015 Civic LX Coupe
Re: 1994 Civic LX 1.6L Brake Hose crush washers [Re: Gito] #4810787
07/10/18 09:10 PM
07/10/18 09:10 PM
Battle Creek, MI
SVTCobra Offline
SVTCobra  Offline
Battle Creek, MI
Think twice, speak once.
Re: 1994 Civic LX 1.6L Brake Hose crush washers [Re: Gito] #4810842
07/10/18 10:17 PM
07/10/18 10:17 PM
CA
Gito Offline OP
Gito  Offline OP
CA
Thanks NoNamejoe and SVTCobra, appreciate your homework.
Re: 1994 Civic LX 1.6L Brake Hose crush washers [Re: Gito] #4810894
07/11/18 12:55 AM
07/11/18 12:55 AM
Saskatchewan, Canada
Johnny2Bad Offline
Johnny2Bad  Offline
If you're searching, they're called "crush washers"
'57 FL Straight 50 wt
'90 Miata 1.8L w/Rotrex Supercharger [Mobil1 0W-40]
'96 Ram 1500 [3.7L Mobil1 0W-20 / 1L 15W-50]
'01 PT Cruiser [Mobil1 0W-40]
Re: 1994 Civic LX 1.6L Brake Hose crush washers [Re: Gito] #4810947
07/11/18 05:36 AM
07/11/18 05:36 AM
NC
BigD1 Offline
BigD1  Offline
NC
My local NAPA stores stock crush washers behind the counter for brakes, fuel lines, and etc. in all kinds of sizes. That's where they keep the high quality clamps too.
1992 Toyota Pickup--PYB 10W-30--Fram PH3614
Re: 1994 Civic LX 1.6L Brake Hose crush washers [Re: Gito] #4811061
07/11/18 07:58 AM
07/11/18 07:58 AM
New Jersey
JHZR2 Offline
JHZR2  Offline
New Jersey
Have you looked at any of the Honda parts discounters like Bernardi?
Shipping may be prohibitive, but it depends upon what else you might buy with it, I guess.
Re: 1994 Civic LX 1.6L Brake Hose crush washers [Re: Gito] #4811071
07/11/18 08:05 AM
07/11/18 08:05 AM
stl
MarkM66 Offline
MarkM66  Offline
stl
Any parts store will sell these. Just take an old one in, and match the size. They're a generic part other than size.
Moderated by  ekpolk
