WM Valvoline Full Syn Modern Eng Clearance
by Spartanfool. 03/22/19 04:22 PM
Need Moly basic training
by Bill_W. 03/22/19 04:03 PM
P0420 code goes away in warmer weather
by 2010Civic. 03/22/19 03:54 PM
Customer declined new belt
by Chris142. 03/22/19 03:13 PM
How to deep clean back of wheels?
by qdeezie. 03/22/19 02:51 PM
RK oil sale T4 15w40
by 1978elcamino. 03/22/19 01:57 PM
Hello and goodbye to my old job
by Motorking. 03/22/19 01:52 PM
Ichiro Suzuki retiring from baseball.
by PimTac. 03/22/19 12:40 PM
91 Caprice door wont fully latch...
by columnshift. 03/22/19 12:30 PM
Denso Platinum TT for 2004 Corolla?
by zorobabel. 03/22/19 11:16 AM
What should I run in the 09 rabbit trans
by ram_man. 03/22/19 10:32 AM
Chevy express van for towing
by Fitter30. 03/22/19 10:24 AM
Mobil 1 Filter Clearance - Wal Mart
by sdude2k2000. 03/22/19 10:01 AM
STP VI trans fluid
by acme. 03/22/19 09:37 AM
Increased oil capacity = lower pil temps ?
by SavagePatch. 03/22/19 09:15 AM
2007 Corolla - P0441 and P0455 codes
by Bama. 03/22/19 08:44 AM
Oldmoparguy1
by cjcride. 03/22/19 08:23 AM
Check engine light
by rtrdad. 03/22/19 08:21 AM
Super Tech 5W30 Synthetic With GDI Engine ?
by ChrisD46. 03/22/19 07:00 AM
Skendread, NGK, Thomas1, RE_Vision, JamesMc
67587 Registered Users
97 registered members (53' Stude, 240_Ed, 2010Civic, 2015_PSD, 8 invisible), 2,221 guests, and 49 spiders.
Topics286,244
Posts4,905,134
Members67,587
Most Online2,967
Mar 10th, 2019
Page 1 of 3 1 2 3
Low comp engine, trying thicker oil... #4810743
07/10/18 09:23 PM
07/10/18 09:23 PM
utah,usa
kawie_guy Offline OP
utah,usa
Got the bad news today.....my 300,000 mile truck has two cylinders that are way under minimum spec compression. This is like hearing a family member has cancer. I've had this truck for 16 years. So before I start looking for a new engine, I thought maybe I'd try some thicker oils in a hail Mary attempt. The manual calls for 10w30. So should I go 10w40, or go for the gusto and buy some xw50?
Re: Low comp engine, trying thicker oil... [Re: kawie_guy] #4810752
07/10/18 09:29 PM
07/10/18 09:29 PM
US
JLTD Offline
JLTD  Offline
US
Why not just do a ring job and head gasket if needed? Oil probably will not help with compression....is it burning any oil?
But to answer your question it will be helpful to know the make and engine. A 40 is what I would try first if shooting in the blind.
I use the overseas owner's manual to choose my oil.
Using AMSOIL™
Hers: 2008 Jeep Liberty 143k, SS 5w30/Amsoil
His: 2015 4Runner 51k, OE 5w30/Wix
Re: Low comp engine, trying thicker oil... [Re: kawie_guy] #4810759
07/10/18 09:35 PM
07/10/18 09:35 PM
PimTac Offline
PimTac  Offline
I don’t think thicker oil will help. As mentioned already, why not rebuild the existing engine? Make and model of vehicle will be helpful.
Cannot see signatures any longer so it doesn’t matter.
Re: Low comp engine, trying thicker oil... [Re: kawie_guy] #4810769
07/10/18 09:47 PM
07/10/18 09:47 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
RESTORE!!!
Re: Low comp engine, trying thicker oil... [Re: Linctex] #4810785
07/10/18 10:07 PM
07/10/18 10:07 PM
PimTac Offline
PimTac  Offline
Originally Posted By: Linctex
RESTORE!!!
He might need the 4 cylinder formula since we don’t know the engine make and size.
Re: Low comp engine, trying thicker oil... [Re: kawie_guy] #4810794
07/10/18 10:23 PM
07/10/18 10:23 PM
US
bunnspecial Online content
bunnspecial  Online Content
US
As suggested, the oil weight really doesn't have any affect on compression.
A compression certainly has a lot of value as an engine "snap shot" but I'd suggest doing a leak-down. This generally will allow you to pinoint where exactly you're losing compression and can show you how to proceed.
The whole engine is probably tired and could use a rehab after 300K miles, but you might get lucky and find a leaky exhaust valve or something like that. If that's the case, you can pull the head, lap or replace the valve(I'd probably just replace all of them as they're cheap) then slap it back together with a new head gasket.
Of course, how easy that is depends on what it is. Pulling a head on a small block Chevy or really most any OHV engine is a whole lot easier than on most any OHC engine.
2010 Lincoln MKZ-Mobil 1 5W-30
1970 MG MGB Roadster-Valvoline VR-1 20W-50
Re: Low comp engine, trying thicker oil... [Re: PimTac] #4810801
07/10/18 10:28 PM
07/10/18 10:28 PM
utah,usa
utah,usa
Sorry, forgot to mention that it's a Ram 5.2 liter (318) magnum v8. OHV pushrod.
Ran like a champ until two weeks ago, then started idling rough and misfiring. Completely replaced all ignition components, still ran rough at low rpm. Did the comp test and found two bad cylinders. Number 5 and number 7 specifically.
Re: Low comp engine, trying thicker oil... [Re: kawie_guy] #4810802
07/10/18 10:28 PM
07/10/18 10:28 PM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
Your rings are probably crudded up. You can try various things or do a ring job.
2015 Ford F250 w/Powerstroke
Re: Low comp engine, trying thicker oil... [Re: JLTD] #4810810
07/10/18 10:37 PM
07/10/18 10:37 PM
utah,usa
utah,usa
It's hard to say because it leaks a little. When I pull a trailer, it gets a little low on the dipstick quicker. But I never have to add more than a quart in 5000 miles. Always have used Valvoline Full Syn and oci of 3000 miles until last year when I went to 5000 based on uoa tbn. The truck's been babied.
Re: Low comp engine, trying thicker oil... [Re: kawie_guy] #4810815
07/10/18 10:41 PM
07/10/18 10:41 PM
PimTac Offline
PimTac  Offline
How about a leak down test? The fact this happened suddenly makes me wonder.
Or, just take the head off and see exactly what’s up.
Re: Low comp engine, trying thicker oil... [Re: PimTac] #4810822
07/10/18 10:51 PM
07/10/18 10:51 PM
utah,usa
utah,usa
Yeah, me too. That's why I went through all the electrical stuff first. Thought something quick like that would be plugs, wires, sensors, cap and rotor, etc. The crankshaft position sensor did turn out to be bad, and replacing it did make it run better at speed, but it still runs rough at idle up to about 1800 rpm. I'm guessing thats because it's basically running on six uneven cylinders instead of 8.
Re: Low comp engine, trying thicker oil... [Re: Linctex] #4810825
07/10/18 10:53 PM
07/10/18 10:53 PM
utah,usa
utah,usa
RESTORE!!!
Does that stuff really work? I always thought it was snake oil.
Re: Low comp engine, trying thicker oil... [Re: Linctex] #4810827
07/10/18 10:59 PM
07/10/18 10:59 PM
Dallas,Tx USA
aquariuscsm Offline
aquariuscsm  Offline
Dallas,Tx USA
RESTORE!!!
Restore AND 20W50!! laugh
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Pennzoil Platinum HM 10W30
Re: Low comp engine, trying thicker oil... [Re: kawie_guy] #4810828
07/10/18 11:01 PM
07/10/18 11:01 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
Often a sudden drop in compression between 2 cylinders is a head gasket is leaking compression between the cylinders.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Low comp engine, trying thicker oil... [Re: Chris142] #4810841
07/10/18 11:16 PM
07/10/18 11:16 PM
PimTac Offline
PimTac  Offline
This was something I thought about as well.
Page 1 of 3 1 2 3
