What pressure washer should I buy?
by wallyuwl. 03/25/19 11:27 AM
Natural Gas from Ohio Valley
by SubLGT. 03/25/19 11:18 AM
CVT Reliability and Durability
by raffy. 03/25/19 11:00 AM
comfortable seats
by redhat. 03/25/19 10:29 AM
walmart evinrude tcw-3 clearance score
by 1978elcamino. 03/25/19 10:15 AM
Mixing SN/d1G1 with SN+/d1G2?
by doyall. 03/25/19 10:14 AM
Best 2nd Phone Number App ?
by LoneRanger. 03/25/19 09:56 AM
Crud! Wix jacking up prices again! :(
by SubieRubyRoo. 03/25/19 09:53 AM
Interior "quick detailer"
by Redright9. 03/25/19 08:21 AM
Seafoam For Last 100 Miles Before Oil Change ?
by ChrisD46. 03/25/19 07:56 AM
WIX 57151XP factory filled with synthetic oil
by Donald. 03/25/19 06:58 AM
BMW Buying Guide: Every Model, Explained
by wemay. 03/25/19 05:43 AM
Double Din Android Auto Advice
by JeffKeryk. 03/24/19 11:25 PM
VW mk5 a/c intermittently works
by ram_man. 03/24/19 11:01 PM
DIY alignment done right?
by tookien. 03/24/19 10:03 PM
Cell phone privacy question
by loneryder. 03/24/19 10:00 PM
sonusfaber, Rollo, Drifted, Jcar516, gregjr7
67614 Registered Users
119 registered members (4WD, alteredtuning990, Aero540T, avi1777, 97f150, 15 invisible), 2,173 guests, and 61 spiders.
Topics286,395
Posts4,907,511
Members67,614
Most Online2,967
Mar 10th, 2019
2010 Fusion Hybrid, 18,875 miles AMSOIL SS 0w-20 #4810515
07/10/18 04:51 PM
07/10/18 04:51 PM
North Carolina
Rat407 Offline OP
Rat407  Offline OP
North Carolina
Again my friends daughter has gone past what I instructed her to come in for an oil change and so here is the sample. This is the third one with AMSOIL Signature Series 0w-20 and Ea15k51 filter. I cut the filter open and it looks just fine. No make up oil and it was down about half a qt.
2002 Silverado 5.3 0w-20 AMSOIL®
Re: 2010 Fusion Hybrid, 18,875 miles AMSOIL SS 0w-20 [Re: Rat407] #4810536
07/10/18 05:17 PM
07/10/18 05:17 PM
The land of USA-made Subies!
SubieRubyRoo Offline
Was all that 18k on battery? smile That looks pretty good!
Re: 2010 Fusion Hybrid, 18,875 miles AMSOIL SS 0w-20 [Re: Rat407] #4810578
07/10/18 06:05 PM
07/10/18 06:05 PM
Washington, USA
Onug Offline
Onug  Offline
Washington, USA
I have more wear metals (all of them) in my samples after 4,500 miles (M1 or Schaeffers), so your sample looks like a great fit. You putting a quality oil in the motor for someone not too interested in maintenance. Good on you!
2016 F-150 3.5L Ecoboost
Current Oil: Castrol Magnatec 5W-30 and Fram Ultra filter
Re: 2010 Fusion Hybrid, 18,875 miles AMSOIL SS 0w-20 [Re: Rat407] #4810587
07/10/18 06:22 PM
07/10/18 06:22 PM
Fredericksburg, VA
JAG Offline
JAG  Offline
Fredericksburg, VA
As long as the engine is staying clean inside, that OCI seems fine according to everything in the UOA. She is using a top notch oil. The oxidation looks high because the test detects C-O bonds in the ester portion of the base oil mixture. In VOAs I’ve seen, it starts off in the 40s or 50s, so 61 is reasonable for the OCI.
Re: 2010 Fusion Hybrid, 18,875 miles AMSOIL SS 0w-20 [Re: Rat407] #4810624
07/10/18 07:06 PM
07/10/18 07:06 PM
TX
parshisa Offline
parshisa  Offline
TX
Does anyone else noticing increase in the viscosity? What could cause that?
Re: 2010 Fusion Hybrid, 18,875 miles AMSOIL SS 0w-20 [Re: Rat407] #4810629
07/10/18 07:11 PM
07/10/18 07:11 PM
PimTac Offline
PimTac  Offline
Can you tell us what percentage of those miles is with the engine running and not solely on battery?
Cannot see signatures any longer so it doesn’t matter.
Re: 2010 Fusion Hybrid, 18,875 miles AMSOIL SS 0w-20 [Re: PimTac] #4810648
07/10/18 07:35 PM
07/10/18 07:35 PM
Houston, TX
2015_PSD Offline
2015_PSD  Offline
Houston, TX
With a TBN of 2.58, I would bet it was far more engine than battery or countless short trips over that 18K OCI.
2018 Mercedes Benz AMG GLC43 3.0L Bi-Turbo [Castrol Edge 0W-40 & Pur filter]
2018 Mercedes Benz C300 2.0L Turbo [Pennzoil Platinum 0W-40 & Mann filter]
Re: 2010 Fusion Hybrid, 18,875 miles AMSOIL SS 0w-20 [Re: Rat407] #4810679
07/10/18 08:01 PM
07/10/18 08:01 PM
Tennessee
Best F100 Offline
Best F100  Offline
Tennessee
Great UOA! How many miles are on this car?
These 2010 -2012 Fusion Hybrids with the 2.5L engines are bulletproof. In the Toyota and Honda durability category, in my opinion. I have the same 2010 Fusion Hybrid, now with 180,000 miles on it.
Just for a frame of reference (or comparison), in 2016, I had a UOA done at 140,000 miles. The oil change interval was 10,200 miles using Mobil 1 0W20EP. Iron level was only 7. TBN was 4 something. The final [email protected] viscosity was 8.42.
My youngest son, the so called destroyer of all things mechanical, is now driving this car full time. He will do his best to neglect and abuse this car. So instead of the anticipated 400,000 miles, I expect it to only make it to 300,000 miles, before it explodes, and I hear him say, "I forgot".
Re: 2010 Fusion Hybrid, 18,875 miles AMSOIL SS 0w-20 [Re: parshisa] #4810694
07/10/18 08:14 PM
07/10/18 08:14 PM
Fredericksburg, VA
JAG Offline
JAG  Offline
Fredericksburg, VA
I noticed it. Amsoil says the virgin viscosity is 8.5 cSt. Oils thicken from the chain reactions caused by oxidation, nitration, and sulfation. Put simply, high molecular weight products form, increasing the viscosity. One danger caused by this is that they tend to be poorly soluble or insoluble in the oil and tend to attach themselves to surfaces. They don’t necessarily do so and it depends partly on the ability of the oil to keep these large molecules solubized and/or encapsulated by detergents and dispersants and/or blocked from adhering to surfaces by detergents at the surfaces. Esters help with solubizing the large molecules. Non-polar Group II-IV are not good at this, especially those with the higher Group numbers. Acidity also increases, which can but does not necessarily cause corrosionn of soft metals used in bearings. This UOA does not show an indication of acids dissolving soft metals.
Re: 2010 Fusion Hybrid, 18,875 miles AMSOIL SS 0w-20 [Re: JAG] #4810713
07/10/18 08:45 PM
07/10/18 08:45 PM
TX
parshisa Offline
parshisa  Offline
TX
In other words in this particular case thickening is not harmul is it? Although thickening is still a first step to sludging, correct?
Re: 2010 Fusion Hybrid, 18,875 miles AMSOIL SS 0w-20 [Re: Rat407] #4810753
07/10/18 09:32 PM
07/10/18 09:32 PM
Fredericksburg, VA
JAG Offline
JAG  Offline
Fredericksburg, VA
The only way to know for sure if deposits are forming is visual inspection. It also helps to put a finger on the internal surfaces and see if the finger somewhat sticks to the surface or leaves a lasting fingerprint (been there, done that). Some oils can lay deposits when their properties in a UOA look decent, while better oils can look like heck in the UOA but not yet lay deposits. Run long enough, even the best oils will give up the ghost and lay deposits.
Thickening is Stage 3, according to some researchers.
http://www.mdpi.com/2075-4442/3/1/54/htm
Quote:
Oxidation is the primary mechanism by which oil degradation occurs in an engine. The process of oxidation occurs in three stages. The first stage corresponds to the depletion of antioxidant and antiwear additives, followed by oxidative degradation of the base oil [2,3]. During this stage, the formation of polar organic compounds in oil (such as ketones, alcohols, carboxylic acids and esters) is more pronounced. The final stage corresponds to an increase in viscosity of the oil owing to polymerization. The recombination of long chain radicals, Aldol and Claisen condensation reactions of carbonyl, carboxylic acid and alcohols that are formed via oxidative degradation in the second stage are the main reactions leading to higher molecular weight molecules [21]. Besides oxidation, during combustion, with the engine running at full load or with improper air/fuel ratios, other reactions that lead to the formation of nitrogen oxides and organic nitrates may occur. Similarly, the presence of sulfur may lead to the formation of SOx, organic sulfones and sulfoxides via oxidation, and sulfurous acid esters when SOx reacts with organic compounds present in oil.
Re: 2010 Fusion Hybrid, 18,875 miles AMSOIL SS 0w-20 [Re: PimTac] #4810907
07/11/18 02:41 AM
07/11/18 02:41 AM
North Carolina
Rat407 Offline OP
Rat407  Offline OP
North Carolina
I can't say, she does a lot of in city driving as well as highway from Greenville NC to home which is 70 miles. Of that 70 miles 40 is back country roads.
Re: 2010 Fusion Hybrid, 18,875 miles AMSOIL SS 0w-20 [Re: Rat407] #4811322
07/11/18 01:07 PM
07/11/18 01:07 PM
NJ
buster Offline
buster  Offline
NJ
Great oil and great engine. It often takes both to go the distance.
