Weird Residue in New Fram Ultra
by mphilleo. 02/16/19 01:40 AM
0w20 vs 0/5w30 (yes I know another viscosity thread)
by SnowDrifter. 02/15/19 11:42 PM
skid plate
by mobilaltima. 02/15/19 10:32 PM
The Last Gladiators (French)
by Marco620. 02/15/19 08:54 PM
Rural King 5W30 Citgo Superguard blend 5qt jug $9.91
by tenderloin. 02/15/19 08:34 PM
Meet Watson!
by spasm3. 02/15/19 08:16 PM
Tie Rod and Ball Jt. Recommendations/Advi
ce
by coopns. 02/15/19 08:11 PM
Uninstall Avast
by willbur. 02/15/19 06:58 PM
Need a new toliet
by JLawrence08648. 02/15/19 06:55 PM
Help Me Choose A Smartphone
by Warstud. 02/15/19 05:29 PM
Source for Torque Wrench Calibration?
by SubLGT. 02/15/19 05:09 PM
Transmission Scraping Noise
by bprat318. 02/15/19 04:59 PM
Ok to mix gear oil viscosities?
by zuluplus30. 02/15/19 04:11 PM
Tore Wheel Cylinder Boot on 2007 Tacoma
by john_pifer. 02/15/19 04:10 PM
Spotify to home theater
by Malo83. 02/15/19 03:19 PM
6.0 powerstroke for a forever truck
by FLORIDA. 02/15/19 02:55 PM
Atwoods PYB 5QT jug $7.99 after rebate !!
by GMguy84. 02/15/19 02:52 PM
Torque Wrench Accuracy
by Kjmack. 02/15/19 12:57 PM
3dfever, Mahmoud, Happycamper, jftcat, TexasForever
67246 Registered Users
39 registered members (1WildPig, anndel, 2015_PSD, 750HMF, Bjornviken, Aero540T, 2 invisible), 597 guests, and 58 spiders.
Topics298,256
Posts4,988,183
Members67,246
Most Online2,474
Feb 10th, 2019
SAE HS806 Vs ISO 4548-12 #4810427
07/10/18 02:30 PM
07/10/18 02:30 PM
Ca.
UncleDave Offline OP
Ca.
Can anyone tell me the differences between these two tests?
Mercury Marine rate their filters using the SAE HS806 standard.
They only say "97%" and give no micron rating - sounds like frontier gibberish, but the test itself may specify the particle size and fill in the missing data.
Thanks!
Uncle Dave
Uncle Dave
Cat 3126/2 MB3500/Titan/RX400H/17 Ridgeline
700HP V10/ 725HP BBC/ Raptor 700/ KFX450/ YZ250/Onan 8K/ Cat3011C
Re: SAE HS806 Vs ISO 4548-12 [Re: UncleDave] #4811012
07/11/18 07:25 AM
07/11/18 07:25 AM
Ca.
Ca.
......anything?
UD
Uncle Dave
Re: SAE HS806 Vs ISO 4548-12 [Re: UncleDave] #4811326
07/11/18 12:11 PM
07/11/18 12:11 PM
Tennessee
goodtimes Offline
goodtimes  Offline
Tennessee
It looks like this test is similar to the US-car36 which tests many other parameters besides multi pass efficiency. Couldn't find the actual test. Mercury may be referring to single pass efficiency according to said test.
http://www.ifts-usa.com/file/Standards%20for%20Engine%20Lube%20Oil%20Filter%20Tests.pdf
https://www.sae.org/images/books/toc_pdfs/HS8062009.pdf
Re: SAE HS806 Vs ISO 4548-12 [Re: UncleDave] #4811405
07/11/18 01:21 PM
07/11/18 01:21 PM
Ca.
Ca.
I hadn't found either of these datasets - good info thank you sir!
Look like I may have to buy the test to really know.
I suspect Merc is winging the numbers on the side of the box.
UD
Uncle Dave
Re: SAE HS806 Vs ISO 4548-12 [Re: UncleDave] #4811417
07/11/18 01:27 PM
07/11/18 01:27 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
As we all know, specifying an efficiency percentage without a corresponding micron size is useless info, and an advertising scheme geared towards people not fully knowlegable about filtration.
Re: SAE HS806 Vs ISO 4548-12 [Re: UncleDave] #4811429
07/11/18 01:41 PM
07/11/18 01:41 PM
Ca.
Ca.
The only way it wouldn't be the gibberish it appears to be at the moment - is if that particular SAE test specified the particle size as part of the test parameter.
.....then "97%" would mean something.
UD
Uncle Dave
Re: SAE HS806 Vs ISO 4548-12 [Re: UncleDave] #4811431
07/11/18 01:47 PM
07/11/18 01:47 PM
Ca.
Ca.
.....the article in question
Worst potting and seam Ive ever seen.
UD
Uncle Dave
Re: SAE HS806 Vs ISO 4548-12 [Re: UncleDave] #4811448
07/11/18 02:07 PM
07/11/18 02:07 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
It looks like mess backed full synthetic media. If it's 97% at 20 microns then it's pretty good.
Did you try contacting Mercury to see if they have more efficiently info?
Re: SAE HS806 Vs ISO 4548-12 [Re: ZeeOSix] #4811576
07/11/18 04:18 PM
07/11/18 04:18 PM
Ca.
Ca.
Haven't bothered the mercury rep with stuff like that - I may float it out to some of the boating forums to see if a rep can pick it up but I don't want to call my Merc rep for something like this yet.
Im just not running it till I know and I have plenty of good option Mainly the new HP4 at these HP's/pressures, and sump intervals.
When the guys ask about it - Ill just point out what I can see- which isnt great.
The can is nice and thick - probably the thickest Ive seen in a while.
UD
Uncle Dave
Moderated by  ekpolk
