Plasti Diping my OEM rims question
by dblshock. 03/24/19 07:53 AM
"The new" Mobil 1 Racing Oil ?
by lawnguy. 03/24/19 06:32 AM
Arlen Ness passes
by 02SE. 03/24/19 03:15 AM
Plants - they learn and remember
by Shannow. 03/24/19 03:02 AM
Rotella Gas Truck
by jpstiles02. 03/24/19 02:53 AM
The case for quitting Facebook
by StevieC. 03/23/19 11:21 PM
Mixing Toyota Spec'ed 0w20 & 5w20
by David2431. 03/23/19 09:59 PM
Run old DOS games on your Wii
by StevieC. 03/23/19 09:51 PM
Live in PA? Need a car? Want something UNIQUE?
by 14Accent. 03/23/19 09:33 PM
Painting plastic
by HangFire. 03/23/19 09:27 PM
Rav4 vs Forester
by fdcg27. 03/23/19 09:07 PM
cleanser stain on cylinder liners
by neo3. 03/23/19 09:06 PM
Electronics and DC Voltage Question
by maverickfhs. 03/23/19 08:39 PM
Oil Change Tips for the Newbie
by StevieC. 03/23/19 08:39 PM
DashCams
by Eddie. 03/23/19 08:07 PM
Rough idle... Only in drive
by nicholas. 03/23/19 07:02 PM
Using synthetic blend or full synthetic oil
by FixItDad28. 03/23/19 07:01 PM
GSXRBullwinkie, Mark1970, FixItDad28, RandomJoe, Sciascia
67599 Registered Users
65 registered members (2009Edge, A1O, aloe2018, AdditiveOCD, ARB1977, aircooled, 10 invisible), 1,409 guests, and 55 spiders.
Topics286,321
Posts4,906,384
Members67,599
Most Online2,967
Mar 10th, 2019
Sea foam and GDI #4810239
07/10/18 12:38 PM
07/10/18 12:38 PM
ga
dabo72 Offline OP
dabo72  Offline OP
ga
Is sea foam safe to run in fuel tank once in a while in a vehicle that is GDI? Thanks
Re: Sea foam and GDI [Re: dabo72] #4810247
07/10/18 12:43 PM
07/10/18 12:43 PM
California
nthach Offline
nthach  Offline
California
You can run it, but it won't have any effect to clean up the valves. You need to either introduce a cleaning agent past the throttle body via a centrally-located vacuum point or take off the intake manifold and media blast the valves with ground walnut shells.
Re: Sea foam and GDI [Re: nthach] #4810279
07/10/18 01:08 PM
07/10/18 01:08 PM
ga
dabo72 Offline OP
dabo72  Offline OP
ga
Yes. I understand about the valves not being cleaned but will it help with anything else. I have a catch can installed to help the carbon issue.
Re: Sea foam and GDI [Re: dabo72] #4810300
07/10/18 01:29 PM
07/10/18 01:29 PM
Lyndhurst NJ
Audios Offline
Audios  Offline
Lyndhurst NJ
No I doubt it will do much else, maybe maybe some catalyst cleaning after combustion? Might clean up whatever gunk is inside combustion chamber, but I doubt much else. I wonder if running it in crankcase will do anything from the fumes attacking the carbon through pcv?
2002 VW Golf TDI-Mobil 1 5/40 TDT
2007 Mercedes GL320 CDI- M1 0/30 ESP
2005 BMW M3 BMW Twin Power 10/60
2003 BMW M5-Fuchs 5/40
1998 BMW M3/4/5 Fuchs 5/40
Re: Sea foam and GDI [Re: dabo72] #4810410
07/10/18 03:21 PM
07/10/18 03:21 PM
Kendall, FL
wemay Offline
wemay  Offline
Kendall, FL
It will keep injectors clean and in turn maintain the spray pattern consistent with factory spec. This too is important to GDI platforms.
https://www.magnetimarelli.com/business_areas/powertrain/competences/definition-of-injector-target-(spray-targeting)-in-gdi-engines
https://www.sae.org/publications/technical-papers/content/2014-01-1439/
18 KIA Sportage 2.4 AWD
M1HM 10W30, OEM
ST Syn 5W30, OEM (next)
13 Hyundai Santa Fe Sport 2.0T
PPeL 5W30, OEM
M1HM 10W30, OEM (next)
Re: Sea foam and GDI [Re: dabo72] #4810678
07/10/18 08:01 PM
07/10/18 08:01 PM
San Diego
FlyPenFly Offline
FlyPenFly  Offline
San Diego
I believe the injectors in GDI engines stay clean due to the incredible high pressures they operate in.
2014 Mercedes GLK350 3.5L DFI
2014 Mercedes E350 Coupe 3.5L DFI
2010 Audi A4 2.0T
Re: Sea foam and GDI [Re: dabo72] #4811793
07/11/18 09:13 PM
07/11/18 09:13 PM
South Eastern, CT
AMC Offline
AMC  Offline
South Eastern, CT
For GDI cleaning, get the aerosol seafoam and spray it directly into the intake by sticking the straw past the butterfly valve.
That should at least help the backs of the valves a little bit. I am guessing you would have to do this procedure pretty often, say every 10,000 miles or so, in order to keep them clean. Seafoam is pretty weak sauce by today's standards.
18 Honda CR-V - Mobil-1 AFE 0w-20
17 Ram 1500 SLT - Napa Synthetic 5w-20
14 Yamaha Super Tenere - Mobil Delvac 15w-40
