WM Valvoline Full Syn Modern Eng Clearance
by Spartanfool. 03/22/19 04:22 PM
Need Moly basic training
by Bill_W. 03/22/19 04:03 PM
P0420 code goes away in warmer weather
by 2010Civic. 03/22/19 03:54 PM
Customer declined new belt
by Chris142. 03/22/19 03:13 PM
How to deep clean back of wheels?
by qdeezie. 03/22/19 02:51 PM
RK oil sale T4 15w40
by 1978elcamino. 03/22/19 01:57 PM
Hello and goodbye to my old job
by Motorking. 03/22/19 01:52 PM
Ichiro Suzuki retiring from baseball.
by PimTac. 03/22/19 12:40 PM
91 Caprice door wont fully latch...
by columnshift. 03/22/19 12:30 PM
Denso Platinum TT for 2004 Corolla?
by zorobabel. 03/22/19 11:16 AM
What should I run in the 09 rabbit trans
by ram_man. 03/22/19 10:32 AM
Chevy express van for towing
by Fitter30. 03/22/19 10:24 AM
Mobil 1 Filter Clearance - Wal Mart
by sdude2k2000. 03/22/19 10:01 AM
STP VI trans fluid
by acme. 03/22/19 09:37 AM
Increased oil capacity = lower pil temps ?
by SavagePatch. 03/22/19 09:15 AM
2007 Corolla - P0441 and P0455 codes
by Bama. 03/22/19 08:44 AM
Oldmoparguy1
by cjcride. 03/22/19 08:23 AM
Check engine light
by rtrdad. 03/22/19 08:21 AM
Super Tech 5W30 Synthetic With GDI Engine ?
by ChrisD46. 03/22/19 07:00 AM
Skendread, NGK, Thomas1, RE_Vision, JamesMc
67587 Registered Users
115 registered members (2015_PSD, AlanGonzales, Aichiguy, 2K2AcuraTL, 95oRANGEcRUSH, 13 invisible), 2,031 guests, and 52 spiders.
Topics286,244
Posts4,905,172
Members67,587
Most Online2,967
Mar 10th, 2019
Volvo GDI cleaning is this correct? #4810121
07/10/18 11:28 AM
07/10/18 11:28 AM
NM
tempnexus Offline OP
NM
If I follow these instructions then will it actually do anything to the GDI valves in terms of cleaning them? Or is it just a hogwash?
http://knowhow.napaonline.com/how-to-use-crc-gdi-intake-valve-cleaner/
Basically I want to keep my Volvo GDI fuel system clean w/o the need to walnut blast it. currently the car has 30k miles on it.
Re: Volvo GDI cleaning is this correct? [Re: tempnexus] #4810164
07/10/18 11:54 AM
07/10/18 11:54 AM
New England
Virtus_Probi Offline
New England
I had bad luck with this product in my FXT, probably partly due to the physical configuration of the car and partly due to my own ineptitude.
Some folks at subaruforester.org told me that getting to the throttle body would be a lot of work for my engine, so I tried to spray it past the MAF sensor through the open air box. The intake path took a sharp turn just past the MAF and I think some cleaner kicked back onto the sensor, which I had to clean after finding that my car was running poorly.
I also suspect that some cleaner pooled up somewhere in the intake path, as I had a very unpleasant experience after letting the car soak for an hour and heading out for the spirited, high speed drive. My driveway is long and steep up to the road and my car hesistated severely twice right after I turned out of it...both were accompanied by a nasty sound that I could best describe as similar to a handful of ball bearings being thrown into a coffee can. I feel like I was pretty lucky my car didn't appear to be damaged after that...
I ended up buying a special tool from Subaru that allows their own cleaners (they have two and they smell a lot different, one is petrochemically and the other is like strong bleach) to be introduced in atomized form through a vacuum line. The process of using these has its own quirks (they recommend to introduce 1/3 of a bottle at a time, but it's really hard to tell how much is left at any given point), but I like them a lot more than the CRC product.
2014 Forester XT, 95000 miles
Last Change;
M1 0W30 AFE d1G2
Tokyo Roki 15208AA170 filter
Re: Volvo GDI cleaning is this correct? [Re: tempnexus] #4810169
07/10/18 11:58 AM
07/10/18 11:58 AM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
As I usually ask,is there really a problem?
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Volvo GDI cleaning is this correct? [Re: CT8] #4810192
07/10/18 12:13 PM
07/10/18 12:13 PM
Shippensburg, PA
novadude Offline
novadude  Offline
Shippensburg, PA
I'm with you. If there are no noticeable performance issues, this is a solution looking for a problem. The downside if something goes wrong (see post above) likely outweighs any benefit.
Re: Volvo GDI cleaning is this correct? [Re: tempnexus] #4810221
07/10/18 12:29 PM
07/10/18 12:29 PM
Colorado Springs
Drew99GT Offline
Drew99GT  Offline
Colorado Springs
I'd find a vacuum line, like the PCV line, and spray in there. You can put duck tape over the line and poke a hole for the straw, then plug the other end of the line so there isn't a massive air leak and the car will run smother while you spray.
Re: Volvo GDI cleaning is this correct? [Re: novadude] #4810252
07/10/18 12:44 PM
07/10/18 12:44 PM
NM
NM
True but what about maintenance? Why put off maintenance until problem rears it's ugly head? Why is everyone soo into "is there a problem?" but then when the problem does occur everyone says: "Well then take it to the mechanic since a mechanic in a can won't fix it." Ok so based on that...it's do nothing until it breaks and then go to the mechanic. But what about maintenance of the system, take care of it and it will take care of you? For example, why do people with high cholesterol take statins if they didn't suffer from heart attack yet? I mean there is no problem, the heart attack didn't occur but yet we take statins to prevent further buildup?
The same goes for the car, why put off maintenance, cleaning the intake system until it's bad enough to loose compression or cause misfires? Why not maintain a clean intake system? Since once carbon starts then it will cause more carbon buildup (since now carbon has nucleation sites to deposit on).
Just my opinion, and hence I am asking for help in maintaining the system and not fixing the problem (there is no fix).
Re: Volvo GDI cleaning is this correct? [Re: Drew99GT] #4810253
07/10/18 12:45 PM
07/10/18 12:45 PM
NM
NM
Yeah but will it actually clean the valves or will it just create a smoke screen show whilst accomplishing nothing beyond fouling the O2 sensors?
Re: Volvo GDI cleaning is this correct? [Re: tempnexus] #4810261
07/10/18 12:53 PM
07/10/18 12:53 PM
Colorado Springs
Drew99GT Offline
Drew99GT  Offline
Colorado Springs
I mean, if anything will clean the valves via the induction method, it's gonna be CRC. It's got a high dose of PEA.
Re: Volvo GDI cleaning is this correct? [Re: tempnexus] #4810264
07/10/18 12:57 PM
07/10/18 12:57 PM
New England
New England
I believe that Trav mentioned O2 sensor issues as well as possible cat clogging as downsides to attempting to clean the intake valves with cleaners introduced through the airbox or a vacuum line...certainly made me think twice about doing it at every OCI as I was considering at one point.
Last Change;
M1 0W30 AFE d1G2
Re: Volvo GDI cleaning is this correct? [Re: tempnexus] #4810274
07/10/18 01:02 PM
07/10/18 01:02 PM
North Carolina
rooflessVW Online content
rooflessVW  Online Content
North Carolina
Sprays don't do anything. Only physical cleaning will remove the carbon buildup I've seen.
Wait until there's an issue before you create an issue by trying to solve one that doesn't exist.
"Zed's dead baby, Zed's dead."
Re: Volvo GDI cleaning is this correct? [Re: tempnexus] #4810280
07/10/18 01:08 PM
07/10/18 01:08 PM
Colorado Springs
Drew99GT Offline
Drew99GT  Offline
Colorado Springs
This is the only reliable before and after post with CRC I could find where someone actually did it with pics.
"So I got a chance to do the A, B test of the CRC GDI cleaner today in combination with an oil change.
A: Take manifold off, take before photos of valves (potatoes 1 & 2)
Install manifold, spray CRC GDI cleaner according to instructions
B: Take manifold off again, take after photos of valves (potatoes 3 & 4)
Unfortunately, photos came out terrible.
However, I will say that the simple spray on cleaners actually did take a substantial amount of the goop off- but not nearly close to what a proper walnut blast would do.
The mechanism seems to be heat and some kind of strong detergent. After application the intake manifold and associated parts of the engine bay were quite hot. It took over an hour to even partially cool and for me to stop burning my hands in the "after" tear down. I didn't happen to have any of my long Q-tips to swab the valves, but all the nasty stubborn oily deposits in the manifold and throttle body simply wiped away.
Mechanism for delivery: inserting the straw into the boost tube post intercooler, pre throttle body.
Car: stock as stock gets MS3 engine, including EGR no CC.
The verdict: if it's cheap and available, sure, throw a can the car for a regular maintenance. HOWEVER, not a replacement for a yearly walnut cleaning. Or an additional helper to cut down on soaking for walnut blasting."
http://www.mazdaspeedforums.org/forum/f1...399/index3.html
So maybe if you do it enough times, it will actually start making a difference, but the hard baked on deposits will only come off via manually scrubbing with the intake manifold off or walnut blasting.
Re: Volvo GDI cleaning is this correct? [Re: Drew99GT] #4810322
07/10/18 01:53 PM
07/10/18 01:53 PM
NM
NM
Thanks that was very informative!
Well at least it's good to know that it does do something, not much but at least something.
Re: Volvo GDI cleaning is this correct? [Re: tempnexus] #4811140
07/11/18 10:05 AM
07/11/18 10:05 AM
Shippensburg, PA
novadude Offline
novadude  Offline
Shippensburg, PA
If the manufacturer does not believe that this procedure is part of "maintenance", why would you worry about doing it? I'm not suggesting you skip all NECESSARY maintenance, but trying to solve a problem that isn't really a problem (minor deposits on valves) doesn't seem like a great idea, given all the potential issues that the "maintenance" can potentially cause. How can you be sure that these deposits are going to cause a drivability, performance, or other issue? Just cause it doesn't look pretty doesn't mean it will impact the way the engine runs in any way the butt dyno will feel.
Just my opinion, but I think that for MOST engines, the subject of GDI valve deposits are much ado about nothing. There are engine designs where this can be a known problem.
Re: Volvo GDI cleaning is this correct? [Re: novadude] #4811607
07/11/18 05:50 PM
07/11/18 05:50 PM
NM
NM
I would agree with you on all points except the one regarding manufacturer not recommending things. A manufacturer cares only long enough until the warranty lasts after that they would rather have you back in the dealership buying a new car instead of driving one for hundreds of thousands of miles (planned obsolescence). They don't care nor want you to drive you car for 100k+ miles, hence many of the manufacturers have sealed transmissions with "lifetime fluid" and by "lifetime" they mean lifetime of the warranty and not your definition of a "lifetime" of the car. So I am just saying that just because it's not in the maintenance schedule doesn't mean it's not necessary.
Re: Volvo GDI cleaning is this correct? [Re: tempnexus] #4812039
07/12/18 08:45 AM
07/12/18 08:45 AM
San Diego
FlyPenFly Offline
FlyPenFly  Offline
San Diego
IMO after seeing how thick and heavy valve intake deposits are, there's no way that a solution that stays for less than a second will have any impact. Even with overnight soaking in brake cleaner, it barely makes a dent on these deposits. Fortunately, some of the newer GDI engines use a hybrid port and direct injection system to combat this problem.
Unfortunately, just periodic 60k (or whatever) intervals of walnut blasting is the only real solution when the engine design is pervasive to this. Catch cans don't do anything, well maintained PCV valves don't do much either, and I highly doubt any brief exposure to a mild cleaner that's combustion safe will do anything at all.
Perhaps using low volatility oils in short intervals would help according to that study on the Hyundai engine. But even then, the data is a bit confusing because high ester oils can actually create more deposits too.
2014 Mercedes GLK350 3.5L DFI
2014 Mercedes E350 Coupe 3.5L DFI
2010 Audi A4 2.0T
