First time ever didnt do my own oil change
by dbias. 02/22/19 07:12 PM
Toyota 3.4L 5VZ-FE Crank Sprocket
by The Critic. 02/22/19 07:08 PM
Weird Noise After Shutdown - 2018 Giulia
by RamFan. 02/22/19 07:01 PM
2019 Honda Passport
by mailman74. 02/22/19 06:56 PM
Who is censoring me? public wifi
by Vern_in_IL. 02/22/19 06:53 PM
Serpentine Belt Tool
by Gebo. 02/22/19 06:49 PM
SUNOCO GLOBAL FULL SYNTHETIC ATF
by Ursatdx. 02/22/19 06:46 PM
No more Meijer batteries!!
by bullwinkle. 02/22/19 06:24 PM
Valvoline premium blue tsc
by Dudemanmaximus. 02/22/19 05:38 PM
Echo won’t run on high speed
by artbuc. 02/22/19 05:36 PM
Roadside Assistance memberships
by paulri. 02/22/19 05:35 PM
Remembering Steve Irwin
by 2015_PSD. 02/22/19 05:27 PM
Transmission Cooler
by rcbob. 02/22/19 04:59 PM
Amazon: PP Euro 5W-40 $38 for pack of 6 quarts
by 1JZ_E46. 02/22/19 04:56 PM
89 Wrangler oil recommendations
by Chris142. 02/22/19 04:55 PM
New batteries failing on the shelf
by Chris142. 02/22/19 04:53 PM
Schaeffer’s 5w30 LT1
by s2krunner. 02/22/19 04:48 PM
Lexus LS430 P0756
by Kibitoshin. 02/22/19 04:41 PM
PUP is now SN + ??? Formulation change??
by Lazydan. 02/22/19 04:17 PM
Got a new wireless printer/MFC
by y_p_w. 02/22/19 02:48 PM
HwyFlierKev, McGruder, SirDave, DieselJoel, jcthorne
67317 Registered Users
102 registered members (AdditiveOCD, 69Torino, 2015_PSD, AandPDan, 13 invisible), 1,631 guests, and 57 spiders.
Topics284,685
Posts4,875,007
Members67,317
Most Online2,548
Feb 16th, 2019
Ford FL-500S Vs Baldwin B7449 #4810120
07/10/18 10:27 AM
07/10/18 10:27 AM
SK, Canada
cdlamb Offline OP
cdlamb  Offline OP
SK, Canada
sorry, I have tried the search, & cant seem to find the information I am looking for. I recently purchased a new 2018 F150 3.5 Ecoboost. I completed the first oil change early at 3900 kilometers, or around 2400 miles for you Americans. I though oil was pretty black in appearance for a new engine, & had a gassy fuel dilution odor. I sent a sample to Fluid Life in Edmonton for Analysis.
Once I get results back I will share them.
I replaced oil with a store Brand, (Canadian Tire Formula 1) Shell Manufactured Synthetic Oil, & a Baldwin Filter.
I am having trouble finding the specs for a Ford filter, efficiency rating, & concerned about the differences in bypass settings. I have heard from other sources that some feel that adding an aftermarket oil separator catch can is beneficial to preventing the intake valves from carbon buildup, & might install a Team RXP, dual valve RX catch can, or UPR 5030-221-1 separator in the future. Would be monitoring oil through analysis to log if there is any benefit, or all gimmick.
The following is all I have found for Fords filter specs, I have attached a Baldwin summary as well
Motorcraft FL-500S OIL FILTER SPECS
Part Number: 57502
Principal Application: Mazda Tribute, Ford Escape and Mercury Mariner (2009) w/ 3.0L engine - Ford Taurus, Edge, Mercury Sable w/ V6 3.5L mfg after 1/16/2009
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 4.09
Outer Diameter Top: 2.942
Outer Diameter Bottom: Closed
Thread Size: 22X1.5 MM
By-Pass Valve Setting-PSI: 8
Anti-Drain Back Valve: Yes
Max Flow Rate: 10-12 GPM
Beta Ratio
Burst Pressure
Normal Micron Rating
Gasket Dim's: 2.753" OD x ID 2.397" ID x 0.25" Thick
The original oil filter from factory was a FoMoCo AA5E 6714 DA, what is the significance of the ***E/ ***Z as compared with the AA5Z-6714-A
Re: Ford FL-500S Vs Baldwin B7449 [Re: cdlamb] #4810358
07/10/18 01:24 PM
07/10/18 01:24 PM
Illinois
tig1 Offline
tig1  Offline
Illinois
Where does the bottle of oil fit in here with the filters?
2007 Ford Fusion 237,000 miles
M1 0-20 EP
2017 Ford Fusion 64K
M1 0-20 EP
M1 ATF and Valvoline LV
M1 10-30 in all OPE
MC filters
Re: Ford FL-500S Vs Baldwin B7449 [Re: cdlamb] #4810581
07/10/18 05:08 PM
07/10/18 05:08 PM
Sask, Canada
BrianF Offline
BrianF  Offline
Sask, Canada
Baldwin is really good for specs when emailed. I have dealt with them on a few matters with Racor, Baldwin and Hastings. They always gave quick detailed responses.
As for the oil, where did you score that? Most CT stores I have been in are now carrying the Citgo made MM oils.
2006 Trailblazer LT. QSUD with Fram Ultra.
2017 Ram 3500 SLT Megacab. Duron SHP 10w30 with Hastings LF608.
1993 GMC 1500. QSAD with Fram PH5
Re: Ford FL-500S Vs Baldwin B7449 [Re: cdlamb] #4810608
07/10/18 05:51 PM
07/10/18 05:51 PM
MT
jongies3 Offline
jongies3  Offline
MT
I didn't know Baldwins were that efficient, nice to know! I'd use it personally over the MC for that reason alone. Plus the media won't tear either.
2004 Toyota Tacoma 3.4 V6: Mobil 1 AFE 0W-30, FRAM TG-3600 filter
1969 Mustang Mach 1 5.8 V8: PYB 10W-30 Napa Gold 1515 filter
2013 Honda 400EX ATV: Mobil 1 Racing 4t 10W-40 OEM filter
Re: Ford FL-500S Vs Baldwin B7449 [Re: cdlamb] #4810618
07/10/18 06:00 PM
07/10/18 06:00 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
What the efficiency numbers mean.
BX=2 means 50% efficiency. So the chart says it's 50% @ 12 microns
BX=75 means 98.7% efficiency. So the chart says it's 98.7% @ 25 microns.
Re: Ford FL-500S Vs Baldwin B7449 [Re: tig1] #4810874
07/11/18 12:06 AM
07/11/18 12:06 AM
SK, Canada
cdlamb Offline OP
cdlamb  Offline OP
SK, Canada
This is the oil I used with the oil change. I was using Canadian Tire Synthetic for quite a while with the Baldwin filter in my 07 5.4 It had 383000 kilometers on original motor & transmission when it was stolen from me 2 months ago. Tow truck driver said it was still driving good when he pulled it off the spruce tree!
Re: Ford FL-500S Vs Baldwin B7449 [Re: ZeeOSix] #4810876
07/11/18 12:10 AM
07/11/18 12:10 AM
SK, Canada
cdlamb Offline OP
cdlamb  Offline OP
SK, Canada
Do you know the specs on the FL-500S ?
Re: Ford FL-500S Vs Baldwin B7449 [Re: cdlamb] #4810928
07/11/18 04:22 AM
07/11/18 04:22 AM
Planet Earth
2015_PSD Online content
2015_PSD  Online Content
Planet Earth
Of course, the FoMoCo filter is not an FL-500s; these are typically Champion made "one size fits many" filters that Ford uses on many models to reduce costs "out of the gate".
2018 Mercedes Benz AMG GLC43 3.0L Bi-Turbo
2018 Mercedes Benz C300 2.0L Turbo
2015 Ford F-250 Platinum 4WD 6.7L PSD
Re: Ford FL-500S Vs Baldwin B7449 [Re: cdlamb] #4811236
07/11/18 10:54 AM
07/11/18 10:54 AM
SK, Canada
cdlamb Offline OP
cdlamb  Offline OP
SK, Canada
I contacted Baldwin and received a spec sheet on PDF. Unfortunately I can not figure out how to convert to a file under 6 MB to share. My spec sheet shows the media grade has changed from L26-75M to L26-88 I also don't show an average efficiency, but the old one was 89.4. I think this is better
Part # Brand: B7449/ BALDWIN
Thread: M22 x 1.5
Gasket Features: G449-B AD, HBP (20PSI)
Outside Diameter: 2.92
Length: 4.10
Media Grade: L26-88
Area sq. in.: 164.5
Capacity, grams: 11.5
Est micron rating: 9.8
BX=2: 9.8 (captures 50% of 9.8 micron particles)
BX=75: 27 (captures 98.7% of 27 micron particles)
Burst psi: 200
Collapse psi: 150
OEM Ford
Re: Ford FL-500S Vs Baldwin B7449 [Re: cdlamb] #4811384
07/11/18 12:58 PM
07/11/18 12:58 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
BX=75 was at 25 microns on the other Baldwin, so slightly better. But BX=2 is slightly better on the 2nd Baldwin. The diffetences aren't enough to worry about.
Moderated by  ekpolk
