PUP is now SN + ??? Formulation change??
by Lazydan. 02/22/19 04:17 PM
Got a new wireless printer/MFC
by y_p_w. 02/22/19 02:48 PM
NM
by y_p_w. 02/22/19 02:47 PM
Names of brand names quality non-pro multi-meter
by JLawrence08648. 02/22/19 02:16 PM
Lady Luck
by CourierDriver. 02/22/19 02:06 PM
Ford MPG
by Zee09. 02/22/19 02:03 PM
Canucks in need of licensed ATF+4
by StevieC. 02/22/19 12:42 PM
Viscosity of Synthetic oil in the bottle
by JLR. 02/22/19 12:35 PM
2006 Tundra trans fluid change with Toyota WS
by njohnson. 02/22/19 11:32 AM
How do you prefer your vehicle seats?
by ZZman. 02/22/19 10:35 AM
GKN awd vs the Haldex in my Chevy Equinox
by wbwanzer. 02/22/19 10:28 AM
Craftsman Tools “Ultimate Collection”
by dkryan. 02/22/19 09:38 AM
Q 50 maintenance questions
by Robertslowpoke. 02/22/19 09:19 AM
No start
by Roughneck777. 02/22/19 08:24 AM
A Quick Question for ebay Sellers...
by Touring5. 02/22/19 07:38 AM
jcthorne, duckthis1, Roughneck777, KDW, avantika31
67313 Registered Users
113 registered members (53' Stude, 2015_PSD, 2004tdigls, 007, 1978elcamino, 13 invisible), 1,842 guests, and 50 spiders.
Topics284,666
Posts4,874,819
Members67,313
Most Online2,548
Feb 16th, 2019
2013 Elantra - Cleaned Throttle Body - P0106 #4809815
07/10/18 02:30 AM
07/10/18 02:30 AM
CA
The Critic Offline OP
CA
I was replacing the spark plugs on this vehicle (102K) and decided to clean the throttle body as well (stupid me). The throttle body was not very dirty. Immediately after restarting the vehicle, the check engine light comes on and the idle began surging to 2000 rpm. I scanned and found a P0106. Removed and reseated connector - ok. Checked the PID in the Live Data for the MAP sensor and it read normally. After doing some additional research, I was told to reset the Engine Adaptation Values using a scan tool and to follow the Throttle Valve Position learning procedure found in TSB #13-FL-002. Luckily, my Autel Maxisys Elite had the ability to perform the reset of the adaptation values and after perform the adaptations reset and relearning the throttle valve position, the issue was resolved.
Apparently, the ECM on these vehicles builds a strategy based on certain airflow characteristics from the throttle body and therefore, the ECM expects to see a certain MAP voltage at idle. Since cleaning the throttle body changed the expected airflow at idle and the MAP voltage was different than the expected value, the P0106 fault code was triggered.
Moral of the story: do not clean the throttle bodies on certain cars. You can really open a can of worms.
2011 Toyota Prius - 184k - M1 EP 0W-20
2007 Honda Accord 2.4 - 134K - Mobil 1 EP HM 5W-30
Re: 2013 Elantra - Cleaned Throttle Body - P0106 [Re: The Critic] #4809816
07/10/18 02:35 AM
07/10/18 02:35 AM
Suomi
Bjornviken Offline
Bjornviken  Offline
Suomi
True, but allways disconnect the battery when you do throttle body work
Re: 2013 Elantra - Cleaned Throttle Body - P0106 [Re: The Critic] #4809820
07/10/18 03:02 AM
07/10/18 03:02 AM
ROCHESTER, NY
Char Baby Offline
Char Baby  Offline
ROCHESTER, NY
I had to do an Idle Relearn after clean the TB on the Mazda3 in my signature. I didn't get a CEL however, the idle was surging.
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic LX
Re: 2013 Elantra - Cleaned Throttle Body - P0106 [Re: Char Baby] #4809840
07/10/18 05:12 AM
07/10/18 05:12 AM
Texas
Dallas69 Online content
Dallas69  Online Content
Texas
Never clean a tb.
Only causes problems.
2009 Galant-ultra oil and filter
1987 Ford F-150 302
Smittys 5-30
Motorcraft filter
Re: 2013 Elantra - Cleaned Throttle Body - P0106 [Re: The Critic] #4809853
07/10/18 05:29 AM
07/10/18 05:29 AM
North Carolina
rooflessVW Online content
rooflessVW  Online Content
North Carolina
Cleaning a throttle valve and then performing an adaptation is the correct way to do it.
You merely discovered the procedure after the fact instead of reading it before hand.
"Zed's dead baby, Zed's dead."
Re: 2013 Elantra - Cleaned Throttle Body - P0106 [Re: The Critic] #4809862
07/10/18 05:41 AM
07/10/18 05:41 AM
Buffalo, NY
JTK Offline
JTK  Offline
Buffalo, NY
That is odd that values would have changed that significantly, especially given it wasn't dirty looking to begin with.
Like said above and I know it's a dumb question, but did you pull a main fuse or battery lead before hand?
2017 Ram 1500 4x4, 3.6L. 2016 Nissan Quest SV (Babe magnet IV)
Re: 2013 Elantra - Cleaned Throttle Body - P0106 [Re: The Critic] #4809880
07/10/18 05:59 AM
07/10/18 05:59 AM
St. Louis
MONKEYMAN Offline
MONKEYMAN  Offline
St. Louis
Thanks!
Truth alone triumphs, not untruth.
2017 Elantra SE
Re: 2013 Elantra - Cleaned Throttle Body - P0106 [Re: Dallas69] #4809959
07/10/18 07:45 AM
07/10/18 07:45 AM
Ohio
hallstevenson Offline
Ohio
Originally Posted By: Dallas69
Never clean a tb.
False
Re: 2013 Elantra - Cleaned Throttle Body - P0106 [Re: The Critic] #4810001
07/10/18 08:30 AM
07/10/18 08:30 AM
Ocala, Florida
racin4ds Offline
racin4ds  Offline
Ocala, Florida
Throttle bodies need cleaned especially around the 100k mile mark. It's very simple to avoid this headache by disconnecting the battery before you do this type of maintenance and it will relearn on its own.
I just had to replace the TPS sensor on my wife's 05 Hyundai Tucson, Since I was in there I pulled the manifold (V6) and did all 6 spark plugs as well. I pulled the POS terminal off before starting and reconnected when done. No issues at all and the car runs great now. Iridium plugs in the back under the manifold were original with 140k miles and had a gap of over .085!!! The front 3 plugs were changed recently and had normal spec gaps.. apparently a shop screwed the girl I purchased it from when he said he did a "full tune up" smile
Just say NO to thin oils and M1!
05 F350 Powerstroke
05 Hyundai Tucson
08 Legacy GT
Re: 2013 Elantra - Cleaned Throttle Body - P0106 [Re: rooflessVW] #4810024
07/10/18 08:56 AM
07/10/18 08:56 AM
CA
CA
Not true - the Hyundai service bulletin did not mention anything about needing to clear the adaptations. The bulletin only asked to perform the throttle valve position learning.
Re: 2013 Elantra - Cleaned Throttle Body - P0106 [Re: racin4ds] #4810026
07/10/18 08:59 AM
07/10/18 08:59 AM
CA
CA
This is dependent on the make. Certain males will relearn on their own (Toyota), but Nissans and apparently some Hyundais will not. I do not see how disconnecting the battery would have made a difference. Disconnecting the battery usually does not discharge the ECM to clear its memory.
Re: 2013 Elantra - Cleaned Throttle Body - P0106 [Re: The Critic] #4810083
07/10/18 09:51 AM
07/10/18 09:51 AM
Modesto,CA
mehullica Offline
mehullica  Offline
Modesto,CA
Did you spray cleaner into the bore? Or wipe down with a soaked rag?
Re: 2013 Elantra - Cleaned Throttle Body - P0106 [Re: mehullica] #4810087
07/10/18 09:54 AM
07/10/18 09:54 AM
CA
CA
Wiped with soaked rag.
Re: 2013 Elantra - Cleaned Throttle Body - P0106 [Re: The Critic] #4810088
07/10/18 09:56 AM
07/10/18 09:56 AM
Central Washington
Colt45ws Offline
Colt45ws  Offline
Central Washington
Why wouldnt it? Aren't learned values stored in volatile memory aka, memory that needs power to maintain what is being stored? If you disconnect the battery the memory discharges and becomes corrupt. Next time you run, the CPU finds the memory corrupt and zeros it out.
-Colton
2002 Ford Crown Vic PI 207k, Ex-Kootenai County, ID Unit #42
Down for engine swap
2003 Ford Crown Vic PI 86k
Pennzoil Conv HM 5W30, Fram XG2
Re: 2013 Elantra - Cleaned Throttle Body - P0106 [Re: Colt45ws] #4810122
07/10/18 10:29 AM
07/10/18 10:29 AM
CA
CA
When the negative terminal is disconnected, power is still retained inside modules. If the intent is to fully discharge the modules and reset them, one would need to remove both the negative and positive cables, then zip tie them together for a while to fully discharge the modules.
I really try to avoid disconnecting batteries if possible. Radio settings get lost, power windows will need to get reinitalized, etc....owners get unhappy.
Moderated by  ekpolk
